Question about Kohler Home
San Martine #K-3435-AA, K-3435-AB, K3435-AC, K-3435-DC toilet
Nothing needs fixing but i want to change or get replacement speakers but i am unsure weather i can and which way to go about it if i can
Part numbers of the speakers:
[12] FRONT SPEAKER BOX PARTS
901 GBOXSA125AW01 BH Wooden Box Assembly
902 CPNLSA055AW04 AY Front Panel Assembly
903 TSPC-A694AWZZ AC Label, Specification
904 LHLDZA177AWM1 AQ Super Tweeter Assembly
905 PCUSGA020AWZZ AB Cushion, Foot
906 XEBY730P10000 AA Screw, M3 x10mm
907 XEPY740P16000 AB Screw, M4 X16mm
908 XESY730P10000 AA Screw, M3 x10mm
SP1,2 RSP-ZA236AWZZ BD Woofer
SP3,4 RSP-ZA179AWZZ AR Tweeter
Code first three numbers are layout numbers, then there is the actual part code you can quote. The two letters are a price code which you can ignore and the final bit is the description.
[13] SUBWOOFER
901 GBOXSA070AW01 BG Wooden Box Assembly
902 CPNLSA030AW03 BE Front Panel Assembly
903 HDECQA136AWSB AM Cover, Edge Light
904 HDECQA135AWSB AN Panel, Edge Light
905 PCUSSA013AWZZ AD Port Cushion
906 PCUSGA020AWZZ AB Cushion, Leg
907 XEBY726P10000 AA Screw, M2.6x10mm
909 XMBY740P16000 AC Screw, M4X16mm
910 TSPC-A693AWZZ AC Label, Specification
911 PFLT-A018AWZZ AF Felt A
912 PCUSGA051AWZZ AF Support Cushion
913 PFLT-A020AWZZ AF Felt B
SP1 RSP-ZA077AWZZ BH Speaker
Full service manual here. Free
http://elektrotanya.com/sharp_cd-sw330.pdf/download.html
Apr 27, 2016 | Sharp CD-SW330 Shelf System
I want to plug an AC adapter into the DC input (normally runs on 3 AA batteries. How much output should the adapter put out?
U don't plug an ac adapter into a dc input. U need a 5-6 volt DC adapter - make sure you observe correct polarity.
Jul 17, 2015 | Audio Players & Recorders
How do I adjust FLOAT VALVE in a Kohler San Martine toilet tank ?
On the fill valve float there will be either a plastic screw or a metal bar with a metal slide clip on it. If its a screw, use a screwdriver to turn it cw or ccw to adjust water level. If its a clip, compress the clip between your thumb and forefinger and slide it up or down along the bar to set the float level. You need to test it after adjusting. Level should be 1/2" below top of overflow tube.
Aug 23, 2014 | Home
Won't start while hot, wait an hour fires right up and runs / idles /drives smooth
FORD: 1995-96 CONTOUR, CROWN VICTORIA, ESCORT, TAURUS, THUNDERBIRD
1996 MUSTANG LINCOLN-MERCURY: 1995-96 CONTINENTAL, COUGAR, GRAND MARQUIS, MARK VIII, MYSTIQUE, SABLE, TOWN CAR, TRACER LIGHT TRUCK: 1995-96 AEROSTAR, BRONCO, ECONOLINE, F-150-350 SERIES, RANGER, WINDSTAR
1996 EXPLORER This TSB article is being republished in its entirety to include the 1995 4.6L Thunderbird/Cougar. ISSUE: After a 1-4 hour engine soak time, long crank times and/or long crank to start followed by a stall may occur on some vehicles. No further stalling or rough idle will occur after the engine is running. The long crank and/or stall may be due to the Idle Air Control (IAC) Valve sticking.
ACTION: Replace the IAC Valve with a revised IAC Valve if no Diagnostic Trouble Codes (DTCs) are present. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
  1. Perform normal diagnostics and correct any DTCs as required by referring to the appropriate year Powertrain Control/Emissions Diagnosis (PC/ED) Service Manual.
  2. If no codes are present, replace the IAC Valve by referring to the appropriate model/year Service Manual, Section 03-14. Refer to the following Idle Air Control Valve Application Chart for proper IAC usage.
    IDLE AIR CONTROL VALVE APPLICATION CHART Model Year Vehicle Engine Revised Part Number PASSENGER CARS 1995 Escort/Tracer 1.9L F5DZ-9F715-BA 1996 Escort/Tracer 1.9L F6CZ-9F715-BB 1995 Contour/Mystique 2.5L F5RZ-9F715-AB 1996 Contour/Mystique 2.5L F6RZ-9F715-AA 1996 Taurus/Sable 3.0L 4-Valve F5DZ-9F715-DA 1995 Taurus/Sable 3.0L 2-Valve F5DZ-9F715-EA 1996 Taurus/Sable 3.0L 2-Valve F6DZ-9F715-DA 1995 Taurus SHO 3.2L F6DZ-9F715-CA 1996 Taurus SHO 3.4L F6LZ-9F715-AC 1995 Taurus/Sable 3.8L F68Z-9F715-EA 1995 Crown Victoria/Grand Marquis/Town Car 4.6L 2-Valve F5PZ-9F715-AA 1996 Crown Victoria/Grand Marquis/Town Car/Mustang 4.6L 2-Valve F6AZ-9F715-EB 1996 Mustang 4.6L 4-Valve F65Z-9F715-BC 1995-96 Continental 4.6L 4-Valve F5OZ-9F715-AB 1995 Mark VIII 4.6L 4-Valve F3LZ-9F715-AA 1996 Mark VIII 4.6L 4-Valve F6LZ-9F715-AC 1995 Thunderbird/Cougar 4.6L 2-Valve F5PZ-9F715-AA 1996 Thunderbird/Cougar 4.6L 2-Valve F6AZ-9F715-EB LIGHT TRUCKS 1995-96 Ranger 2.3L F5OZ-9F715-AB 1995-96 Ranger 3.0L F67Z-9F715-AA 1995 Aerostar 3.0L F68Z-9F715-DA 1996 Aerostar 3.0L F69Z-9F715-AA 1995-96 Windstar 3.0L F68Z-9F715-DA 1995 Windstar 3.8L F68Z-9F715-EA 1996 Windstar 3.8L F68Z-9F715-CB 1995-96 Econoline/F-150-350 Series/Bronco 4.9L F68Z-9F715-EA 1996 Explorer 5.0L F67Z-9F715-BA
Nov 03, 2009 | 1996 Ford Explorer
What is the best way to remove stuck toilet anchors
try rotating the entire toilet counter clockwise so the bolts are in the insert slot of the toilet flange and rotate the nut and the bolt head should line up and pop free of flange.
Oct 30, 2009 | Kohler K-3384-2 San Raphael Elongated...
Need 5C01 Code for 07/05/2009
00 = AA B7 D1 D9 CE 8E 83 AF
01 = 8E 80 D7 EF 44 93 02 2B
NTL 54 01] 07/05/09
00 = 5C 2C 26 36 CF 81 AB 66
01 = 2C 10 35 AC 06 57 BE 6F
May 07, 2009 | StarTech.com StarView SV211K 2-port KVM...
Codes update
NTL 54 01] 07/05/09
Need codes for eurovox maxv
ntl keys 5C 2C 26 36 CF 81 AB
2C 10 35 AC O6 57 BE
cw keys A7 B2 EE 5F 9D D8 69 OE
3D 82 E6 58 8E OD B3 62
TW KEYS AA B7 D1 D9 CE 8E 83 AF
GOOD LUCK
Nov 29, 2008 | Televison & Video
Home Logo
80 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
