Question about Hoover Platinum LiNX Cordless Stick Vacuum
How do I take the handle apart on a Hoover linx vacuum?
2 Suggested Answers
  • 19 Answers
SOURCE: How to remove handle from Hoover 5445-900 upright wind tunnel vacuum
Hoover.com doesn't have a manual specific to your model but there is one similar which will show how to remove the upper handle from the body.
http://www.hoover.com/pdfs/manuals/U5467900.pdf
Do you have a replacement switch? If not I believe you can buy one from Hoover (the switch and/or the upper handle assembly). Unfortunately your model isn't listed on the website, is this a new vacuum? I recommend giving them a call, that would be the easiest way.
Also remember when working with electronics to unplug the vacuum. Even when there is no power residual electricity can remain in the wires. If you feel unsure, take it to a repairman.
Hope this helps!
Posted on Dec 22, 2007
When you turn it on the lights on the battery come on and the brush roller will turn but the suction motor will not turn on.
Hoover Air Cordless Series 3.0 Bagless Upright Vacuum ...
www.amazon.com/Hoover-Cordless-Bagless-Upright...
Amazon.com, Inc.Hoover Air Cordless Series 3.0 Bagless Upright Vacuum, BH50140 ... The batteries come pre-charged, plenty to get up and running. ... The brush will stop as soon as the handle is in the upright position for like using the attachments. ..... and in need of charge, in carpet mode, the motor runs, but the brush roller won't spin.
Hoover Air Cordless Series 3.0 review - Best vacuum cleaner
www.vacuumsguide.com/hoover-air-cordless-series-3-0-review/
Rating: 4 - ā€ˇReview by Jason Roberts
Aug 4, 2014 - Hoover Air Cordless Series 3.0 is a new upright vacuum cleaner reviewed by ... power, 2 batteries - each lasting 25 minutes, good filtration system,light ... Just as in the case of the Linx, it filters dust particles, but doesn't come with HEPA filtration. ... Multi-Floor Cleaning - you can turn the brush roll on or off.
Dec 18, 2015 | Hoover Air Cordless Series 3.0 Bagless...
Why doesn't the brush roller rotate?
Hi, this is Jim with Crucial Vacuum,
The belt may not be broken, but it may be lacking in tension and therefore unable to rotate the brush roll on its own. You're going to want to replace your vacuums belt every 3 to 6 months depending on usage. Check to see if the belt is loose, or over stretched.
Check the brush roll as well and be sure its securely locked into place. It could be slightly loose causing a lack of communication between itself and the belt. Our video can help with fitting the belt in properly with the brush roll:
https://www.youtube.com/watch?v=LRV8280PQxc
You can purchase replacement belts and brush rolls for your Hoover Linx directly from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/hoover-linx-platinum-roller-belt.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
May 05, 2015 | Hoover Platinum LiNX Cordless Stick Vacuum
Battery for Hoover Linx will not charge. Charger blinks very fast.
Jan,
your battery is Shorted. it is time to buy a new vac or a replacement battery.
sorry that is such a short hand answer but that is what the charger is telling you.
Apr 22, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Hoover linx brush motor
Locate the dimple somewhere around the edge of the two components to be separated.
Put a sheet or drop-cloth down and work on that to prevent anything from being lost if it opens suddenly. (it should be fine).
Use a large flat head screwdriver to pry it open.
Feb 06, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Linx Hoover platinum won't turn on
more than likely you'll have to order a new handle. Those machines are built in pieces so you just cant replace switch, motor, etc....
Feb 13, 2013 | Hoover Platinum LiNX Cordless Stick Vacuum
Handle on linx is bending off
I've seen them come in with that, I've seen it fixed with tape more often than anything. Low tech, low cost. Not professional in any sense of the word but it seems to work.
Good Luck
The Vac Dr
Jan 07, 2013 | Hoover Platinum LiNX Cordless Stick Vacuum
Hoover linx handheld losing suction
please go to web page from Hoover and see the videos respectively from your model, etc.
http://hoover.com/support/video-instruction-guides/
However this can be a problem:There could be a clog in the hose or the bag/tank may be full and need to be replaced or emptied. Also, check the belt to see if it is worn or broken, if it's defective replace it.7_28_2012_10_15_39_am.jpg
Jul 27, 2012 | Hoover Platinum LiNX Cordless Stick Vacuum
My Hoover Linx handle broke.
Not sure what you mean by a broken handle, but if you mean the plastic is cracking where the handle connects to the main body than I have a suggestion. We have had this happen a couple times and I tried various fixes that did not work. However, recently I found a cheap product that will strength the handle to make it stronger than new. It called Fiber Fix tape (its on Amazon). Wet the tape and wrap the handle. It is a quick set epoxy in a fiberglass like cloth. Dries very hard. Not pretty, but it works great.
Jun 19, 2012 | Hoover Platinum LiNX Cordless Stick Vacuum
My Hoover Linx is not picking up anything. Nothing seems to be keeping the brushes from spinning but they are not working. It is only 3 months old. Fully charged.
I think you have 2 problems:
1. The LiNX gets clogged somethings in the head unit and the clog is difficult to see. Remove the head (via the push button). and clean out the clog. I do this with a lenngth of coat hanger wire that I bent a small hock on to the end.
2. If the roller stops turning it can be caused by one of the power wires to the moter getting severed in the swivel connection in the head unit. This has happened to us twice. I took the unit apart (a pain) and was able to fix by soldering and taping wires. However, Hoovers design is not great in getting power to the motor and this may recur. I love these vacuums and I hope they engineer a more robust wie feeding solution.
Aug 27, 2010 | Hoover Platinum LiNX Cordless Stick Vacuum
Hoover Platinum LiNX Cordless Stick Vacuum Logo
102 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
