Question about Garmin nuvi 205 GPS Receiver
When i plug my car charger to my GPS it turns it to PC mode and im not able to use my GPS while its charging.
  • 2 more comments
  • kathymccain Jan 28, 2009
    Yep - same problem with me. I can only use this while it's running on batteries - never while plugged in. What gives?
  • oldbarbri Jan 29, 2009
    I have exactly the same problem, when I plug the Nuvi into my car charger I get a picture of a PC and it freezes on that until I unplug the Nuvi. Basically, I cannot use the Nuvi 205 when it is plugged in. This has been going on for a few weeks already.
  • medai08 Feb 27, 2009
    my device Nuvi 205w can't detect USB Device when plug in to PC
  • fredcohiba Apr 11, 2009
    When powered via the USB charger, my Garmin locks up with a screen showing a computer connected to the garmin and then the unit freezes and will not operate until I unplug it from the power.
Here is a nice trick to use the Garmin while charging with a USB cord or a wall charger: with the Garmin unplugged keep your finger on the battery icon for about 10 seconds until the diagnostic screen comes up. Then connect the USB cord and press EXIT; the Garmin will reboot and you will be able to use it normally.
Posted on Feb 14, 2009
Garman 225w won't start, stops after "loading
The micro usb port is at the back. Connect Vehicle Power Cable to the nüvi and connect the other end to your computer, your nüvi does not operate as a GPS unit - it goes into some sort of charging mode. However, if you FIRST turn on the nüvi in the battery mode then go into the test mode (press the battery icon for about 8-9 seconds) from the main screen, THEN PLUG in the USB cable, and finally exit the test screen, your nüvi will restart (reboot) and it will operate just like it was plugged into the cradle connection in your vehicle.
This mode will charge the battery
AND operate as a GPS.
It works with my computer USB cable, my cell phone charger and my car charger for my cell phone.
Don't forget to turn off the nüvi before unplugging.
Jan 08, 2011 | Garmin nuvi 255W GPS Receiver
My garmin nuvi 255W does not charge in the car with the car charger. It freezes at the first screen and I can't get past that screen. I found my home charger and plugged it in and now the battery is...
You need a genuine Garmin car charger to both charge and see directions at the same time. If it is a non - Garmin lead you can't charge and use at the same time. the Garmin at the same time. Otherwise the unit just goes into sleep/pc mode. It took a long time to get to the bottom of this, so I thought I'd pass the information on...
Nov 13, 2010 | Garmin nuvi 255W GPS Receiver
Have a phone charger 12 volt that fits and charges the nuvi 200 but with it plugged in it wont show anything but a computer and nuvi on screen. unplug and it works but only for a while til needs a new...
thats because the phone charger is wired different to the gps charger , u need a genuine charger, if when pluged into pc it takes longer to charge, best to have gps turned off while charging from pc..... if it still does not work/ hold charge battery in unit gone , caused by being in active for over 3 months
Dec 29, 2009 | Garmin nuvi 200W GPS Receiver
PC Mode
You will always get the PC mode. Its programed to do that when you plug in the AC power.
Aug 21, 2009 | Navigon 2110 Series Satellie GPS Receiver
Not taking a charge
could be a few problems or just a single one.
I will suggest the simple one first.... get a new battery
they shouold last 2-3 years but seldom do because of the way people use(abuse) them ALL gps should be charged fully on an AC charger and run in the car on the DC powere AFTER the engine has been started. remove plug when stopping the engine to do shopping and only reconnect it whenh the engine is again running. doing this prevents battery shock and protects the SIIRF chip from damage by spikes. the siirc chip is what connect to sattelites for you.
If when connected to the AC chareger for 10 minutes you can turn it on ( whilst still connjected to charger) and program it that willo confirm that the battery is the culprit.If you cannot
get display and function whilst on charger then the problem is serious and also expensive to repair.
Jun 22, 2009 | Navigon 2100 Portable GPS Receiver
How do know when my Garmin 855 is done charging?
Turn it on without being connected to the charger and check out the battery indicator - that will give you a bearing on battery condition.
Sep 20, 2017 | Garmin Nuvi 660 GPS Receiver
Charging doesn't display map when charging
I learned that with the unit off - hold the on button down - don't release it. A PRE-BOOT MODE message will appear at the bottom and may flash. Continue holding down the start button. The first time I did it a series of dots came on the screen and I was instructed to touch each one. After that it started as normal. I plugged into a wall charger and but git the pc and nuvi icons again. I repeated the process - holding the on button on and let the PRE-BOOT MODE appear and kept holding but this time a different message came on and then the PRE-BOOT MODE appeared again. I let it go and took the unit to my car and plugged it into the Garmin car charger and it worked as it used to - normal. However, when I plugged it back in the house to the wall charged I got the pc and nuvi icon again. It appears that I am using the wrong wall charger as a previous writes stated. But the nuvi still worked in the car plugged into the nuvi charger. I hope this helps.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
Navigon 5100 gps
Try turning it off and turning it back on while it is still plugged in and see if that works.
Oct 23, 2008 | Panasonic Navigon 5100
NAVMAN S70 S Series - is it possible to charge the unit and use it at the same time - when plugged into cigarette lighter in the car and plugged into bottom of GPS unit, the unit seems to assume this is a...
Some chargers will 'fool' the satnav into thinking they're connected to a pc, my S90 was just the same. I bought a car charger on eBay that said in the description "These are purpose designed car chargers so that you can also continue to use your devise whist charging it will not go in to PC sync mode." I bought one of these and it now lets me use the satnav and charge at the same time, whereas my other car charger wouldn't let me.
May 27, 2008 | GPS
I have a nuvi 200 that wont run when it is hooked up to a power supply
Vehicle Power Cable to the nüvi and connect the otchapin.screen1.jpgher end to your computer, your nüvi does not operate as a GPS unit - it goes into some sort of charging mode. However, if you FIRST turn on the nüvi in the battery mode then go into the test mode (press the battery icon for about 8-9 seconds) from the main screen, THEN PLUG in the USB cable, and finally exit the test screen, your nüvi will restart chapin.screen2.jpg(reboot) and it will operate just like it was plugged into the cradle connection in your vehicle.
Don't forget to turn off the nüvi before unplugging."
Mar 01, 2008 | GPS
Garmin nuvi 205 GPS Receiver Logo
875 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
