Question about Tannoy Mercury MX-Sub 10-M Subwoofer
Manuale Subwoofer attivo Tannoy Mercury Msub 10
Im trying to remove the back plate from a TANNOY TS 1001 subwoofer to replace the fuse but I cant get it off. Can any body help please.
Did you fix yours?
The fuse of my TS1001 blew, because the MosFET IRF740, another IC, and the transformer were shorted.
Called Tannoy who were not helpful and asked me to get to their authorised reseller/agent, as you cannot purchase parts directly from Tannoy. The agent obviously added a mark-up on the part.
Cutting long story short, I purchased the amplifier board for a TS801 to fit in my TS1001 because the BASH amplifier for TS1001 is no longer available/manufactured. The sizes of the amplifier plate were similar although the TS801 is 200W with 8" driver and the TS1001 is 300W with 10" driver.
I am now using a 200W amplifier with my TS1001 (Works well with the 10" driver).
Oct 08, 2013 | Audio Players & Recorders
I just bought a pair of Tannoy Mercury V4 with a broken tweeter. Where do I find a new one?
check to see if you can find it on parts-express.com that's where I get all my speaker stuff
May 28, 2013 | Tannoy Audio Players & Recorders
How do I replace a fuse in the Tannoy TS10 Subwoofer
The fuse is located under the AC input cable. Pull out the cable and you'll see there is a slot that will fitt a flat screwdriver. Pull this out and you'll find the fuse.
Jul 21, 2012 | Tannoy Fusion TS10 Speaker
No signal on subwoofer out in Onkyo TX-SR703(E) - similar to TX-SR803
Hey Tad, I have the same problem and perhaps a solution. I just moved to the other SW "pre-out" and it seems to be working..the green light is on . Whatever works i guess.
Jan 24, 2008 | Onkyo TX-SR703 Receiver
No sound from subwoofer
have you checked for the continuity of the wirings? check for the resistance of your speaker from it jack..... it should measure close to 8ohms or 4ohms using a digital multimeter (DMM). check also the sub out jack of your reciever if there is a signal from it using your main speakers if they come with jacks also (turn the volume low to prevent damage to other speakers you connect on it!
Nov 07, 2007 | Tannoy Sensys 7 Speaker
Tannoy Mercury MX-Sub 10-M Subwoofer Logo
344 people viewed this question
Top Tannoy Audio Players & Recorders Experts
 Grubhead
Grubhead
Rommel Balcita
shaqsatin
Level 1 Expert
Are you a Tannoy Audio Player and Recorder Expert? Answer questions, earn points and help others
