Question about Dell OptiPlex Computers & Internet
Shut down and show power saver
Shutdown automatic
  • Dell Master
  • 7,627 Answers
Open Control Panel, Power Options, Advanced Power settings, Change Sleep to Never, Hibernate to Never. Adjust to your preference.OR right click on a open space on the desktop, depending on the OS you are using, select Properties or Personalize, Select ScreenSaver, set time. It's a good idea to shut down your machine when not in use, even if you have a UPS, Your computer will last longer and a reboot every day resets the computer.
Posted on Jan 11, 2013
mumma_1
  • 903 Answers
SOURCE: My Dell Optiplex GX270 goes into power saver mode
this sounds like a bad power supply unit. First check that your Ram and graphics card a free from dust and dirt by removing them from their slots and cleaning them with a dry soft paintbrush then replacing them gently but firmly. Next check that all of the power cables going into the motherboard are pushed in gently but firmly. If this is done and you still get the same problem, then I suggest changing the power supply unit.
Posted on Dec 23, 2008
  • 85 Answers
SOURCE: PC automatic shutdown
logon.ddl has been missing u hv to reinstall ur operating system
formate ur pc it will solve ur problem
Posted on Jan 30, 2009
jubag14
  • 89 Answers
SOURCE: My laptop restarts automatically after shutdown
i might have to reformat your computer and if that doesnt work then take it mack to the manufacture and see what they can do about it sorry.
please rate my help to you.
thank you.
Posted on Apr 22, 2009
SOURCE: i shutdown my emachine E725 through windows it doesnot shutdown automatically and hands and ive to shut it down manually through power button
I had the same problem on E725 model, I fixed it by installing XP SP3.
Posted on Sep 12, 2009
  • 7 Answers
SOURCE: wont shutdown when shutdown butten is pressed shuts windows well i have to cut off power to shutdown.
A lot of IBM laptops do not have Nvidia graphics. Shutdown errors can be caused by many reasons including bad drivers and programs that do not shut down properly. It can be tough to isolate the specific problem. Here is what I did with my IBM laptop when it had this problem. I hope it works for you!
Windows XP Freeze at Shutdown with IBM Laptop: I had this problem while setting up an IBM T43p with XP Pro from the IBM Product Recovery disks. After much frustration I found the problem was a bad driver. In Device Manager>System Devices I uninstalled "Atmel TPM legacy device," a Trusted Platform Module driver. The T43p would then shutdown and restart without a hitch.
Posted on Jan 13, 2010
Computer keeps turning off
You didn't give much information. If the screen is just going dark be sure it is not just the screen saver. If the PC powers down, it could be over heating and shutting down the power supply. Usually if this is the case the fan runs at high speed just before the shutdown. If it is neither of those problems, it could be many things, such as a loose power cable, a defective power switch, of a defective power supply.
Jun 05, 2014 | Computers & Internet
Mid tablet wont shut down
So you need to be In the main menu interface then press the power button for about 5 seconds to shut it down. Below is the power section out of the manual.
1.2 POWER
startup: Long Press and hold the power button, the system will enter the main interface
shutdown: In the main menu interface, Press the power button about 5 second to shutdown, The system can hint "power off" option, Clike"ok". you can safely shut down.
Lock screen: Short press Power button to lock screen or unlock screen.
Remark 1.When power is empty,system will shut down automatically.
2.Illegal turn off the device,restart will scan and restore the disk,it may take longer time to enter into system
Jan 30, 2013 | mid Archos M729B Android Tablet
I'm using acer aspire 5920 ...it having problem once it is turn on it dont shutdown. i seen in some blog .there said update BIOS .i did it. it displays message automatically shutdown . But my friend...
If you show a Blue Screen, you have more problems then it not being able to turn off/shut down?? I would back out the battery so as to stop power from getting to it, AFTER you have it unplugged..then push battery back into to engage, plug the AC cord back into the PC. turn it back on and IF you still show a BLUE screen, you will need a tech to check it further...GOOD LUCK...
Sep 25, 2011 | Acer Aspire 5920 AS5920 Notebook
Hi my daughter used the mac last night same as usual. When i started it up this morning i only have screen saver plus mouse pointing device showing!!! Normal shutdown procedure was followed. thanks in...
I'd guess that it went into sleep mode rather than shutdown. Sometimes the screensaver can only be woken up by tapping the space bar..
If that doesn't do it, hold the power button down for 10 secs and this will force-shut the machine, then boot up as normal.
Regards
Jul 17, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Automatic shut off?
Usually you set this by going into the power saving settings in the screen saver settings.
You can set the monitor to shut down pretty much when you want it to from this settings screen.
Good Luck,
-a.
Jun 07, 2010 | HP 2009M Monitor
My laptop screen will not shut off. I have a Sony Vaio about 6 years old. When I power down the screen shuts off while everything is shutting down but then when everything is off the monitor turns a light...
if u r using vista sure check the shutdown button.
or press once power button it automatically shutdowns
or hold power button until it shut down
when u close the door it only standby..
Oct 22, 2009 | Dell Inspiron E1405 Notebook
Override laptop automatic shutdown after inactivity
Easily done! Right click your desktop and choose Properties. Select the Screen Saver tab and at the bottom choose Power. In the Power Schemes drop down box choose Always On and the PC will never turn off. You might also want to disable or set the time higher for your screen saver.
Please rate this solution accordingly. Thanks for using Fixya.com.
Jan 10, 2009 | Dell Latitude D600 Notebook
Mac Mini G4 turns itself ON
Have you looked into System Preferences>energy saver>schedule? Maybe it's set up to start itself. I have my mother's mac set to start up and shut down automatically. Just a thought.
Jan 09, 2009 | Apple Mac mini G4 Desktop
The shutdown window keeps coming up and my computer shuts down
you have a virus, scan your pc with nod32, you can download from www.nod32.com
Sergio
Mar 22, 2008 | Computers & Internet
Computers & Internet Logo
76 people viewed this question
Alun Cox
