Label maker not printing properly it's ink is running out how do I replace it?
    Genius:
  • 1,669 Answers
Please read the following information about your unit:
wiki.answers.com/Q/Does_the_dymo_label_maker_take_ink
Posted on Jan 11, 2013
4 Suggested Answers
  • 7 Answers
SOURCE: Ink will not print
www.ptouchdirect.com/ptouch/umpt65.html
this is a web page with the manual should help
Posted on Apr 09, 2009
SOURCE: changing ink?
I had the same problem. I just put in new batteries and it is printing fine. Are your batteries low?
Posted on Apr 29, 2009
SOURCE: My label maker is not printing properly do I need
I have a dymo letra 100 and the letters only half printout can you help me with this. John Fair
Posted on Aug 11, 2010
The blank ink wont print on my 3522 printer
First you check it printer ink cartridge label, if ink label shoot then not any paper print. Or ink full then your printer not printing then may be your cartridge damage or not proper fit in printer. Second thing is if your printer dust available then not access you instruction. Please go to printer cartridge tab and open and check it, or second thing is also go to printer setting option and check it your printer label ok or not.
I share a informative link please read it.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c03955488&cc=us&dlc=en&lc=en&product=5231946
Thanks,
HP Printer Support
May 21, 2014 | HP Deskjet 3522 Wireless Color Inkjet...
Does a letratag label maker ever run out of ink
No. As mentioned, it is either the weak batteries or dirty print head.
Replace the batteries and clean the print head to improve the quality. If nothing helps, please contact us directly for repair (see dymo.com for contacts).
Oct 13, 2013 | Dymo LetraTAG Thermal Label Printer
Shows code U165
This section explains the way to confirm the ink status and the procedure to replace ink tanks. When ink runs out or other errors occur, an error message is displayed on the LCD to inform you of the error. See "An Error Message Is Displayed on the LCD".
When printing from your computer, error messages appear on your computer screen as well.
NOTE
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder.
The machine will not print if an ink tank is installed in the incorrect position.
With the LCD of this MachineMake sure that the machine is turned on, then press the COPY, FAX, SCAN, or MEMORY CARD button. The current ink level will be displayed on the LCD for a few seconds.
g0011480_tcm14-605381.png(A) Confirm whether any symbols are displayed here.
g0011482_tcm14-605375.pngColor or black ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011483_tcm14-605376.pngColor or black ink may have run out. See"An Error Message Is Displayed on the LCD".
REFERENCE
The ink status information is also displayed on the screen that appears during printing.
An error message may be displayed on the LCD during printing.
g0011494_tcm14-605377.pngMachine detected ink out condition. See "An Error Message Is Displayed on the LCD" and take appropriate action.
(B) Empty ink tank.With the Ink LampsYou can confirm the status of each ink tank by the ink lamps. Open the Scanning Unit (Printer Cover) of the machine to confirm how the ink lamps light or flash.
  • Ink lamp is on
The ink tank is correctly set and there is enough ink remaining to print.
  • Ink lamp is flashing
Flashing slowly (at around 3-second intervals)
Ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
Flashing quickly (at around 1-second intervals)
The ink tank is inserted in the wrong position or it is empty. Ensure that the ink tank is in the correct position as directed by the label on the Print Head Holder. If the position is correct and its lamp flashes, it is empty. Replace it with a new one.
  • Ink lamp is off
The ink tank is not set properly or the function for detecting the remaining ink level is disabled.
If the ink tank is not set properly, press the g0009324_tcm14-605384.png mark on the ink tank until the tank clicks into place. If it does not click into place, make sure that the orange protective cap has been removed from the bottom of the ink tank.
If the function for detecting the remaining ink level is disabled, replace the ink tank with anew one. See "Replacing Ink Tanks".
If the lamps are still off after reinserting the ink tanks, there has been an error and the
machine cannot print. Check the error message displayed on the LCD. See "An Error
Getting the Clear Ink Status InformationClear ink is used only when printing on plain paper.
When Plain paper (Cassette) is selected for Media type and printing begins when clear ink (PGI-9Clear) is low, a message will be displayed in the LCD.
g0011497_tcm14-605385.png(A) Confirm whether a symbol is displayed here.
g0011502_tcm14-605378.pngThe clear ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011503_tcm14-605379.pngThe clear ink tank is empty. See ""The clear ink tank is empty. Replacing the ink tank is recommended." U045" and take appropriate action.
NOTE
  • The ink status information is also displayed on the screen that appears during printing.
  • Clear ink is used only when printing on plain paper. Therefore, it is possible to print on photo paper, or any type of paper other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
The following error message will be displayed on the LCD when the clear ink has run out during printing on plain paper.
g0011506_tcm14-605380.pngRefer to "Replacing Ink Tanks"If you continue printing under the clear ink out condition, see ""The clear Ink has run out. Replace the ink tank." U165/U166" and take appropriate action.When the clear ink hasrun out, printing on plain paper from the Cassette is not possible. The fax, which is received under the clear ink out condition, will be stored in memory.
NOTE
It is possible to print on photo paper, or any media type other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
Oct 01, 2011 | Canon PIXMA MX340 Wireless Office...
I have the dymo letratag. no letters come out on the paper. I can not find anywhere to put any ink.
LetraTag label makers are thermal printers, so they don't use ink - just batteries and LetraTAG tapes.
When the print starts to fade it's time to put new batteries in.
Jan 29, 2011 | Dymo LetraTAG Thermal Label Printer
My label maker is not printing properly do I need to purchase ink?
Aug 09, 2010 | Dymo LetraTAG Thermal Label Printer
Not printing ink
The print head needs cleaning. Use a swab and alcohol to clean it. If that doesn't solve the problem, then the heater in the print head needs replacing.
Sep 07, 2017 | Dymo RhinoPRO 3000 Thermal Label Printer
Changing ink?
Apr 06, 2009 | Dymo LetraTAG Thermal Label Printer
Ink will not print
Dec 09, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Dymo LetraTag 2000 hand held printer
This Unit does NOT take ink. That is one of it's "benefits." Since it uses heat transfer, im thinking it either needs new batteries, or it's heat device has been expended. This is a cheap little maker, so it isnt made to handle the abuse of an office: it's meant for a label from week to week. If you went on a label spree all over the house, you killed it. Hope this helps!
Jul 26, 2007 | Dymo LetraTag 2000 Printer
65 people viewed this question
k24674
jasbo
jasbo
