My friend has a 50inch philiphs tv the sound works but no image is there anything anyone could advised
50inch flat screen tv
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 24 Answers
Is it a LCD type screen? If it is, look close, is there no backlight, or its lit with no image? If its no backlight, the screen backlight inverter is bad. If there's backlight with no image, can be the display, connection cable or mainboard.
Posted on Jan 11, 2013
5 Suggested Answers
  • 298 Answers
SOURCE: No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Posted on Nov 22, 2007
  • 3 Answers
That problem is caused by the Y Sustainer board.
Posted on Apr 05, 2008
SOURCE: Our cat knocked over our flat screen LCD tv The
The good news is that the TV is not broke and can be fixed. You will first need to check for any cracks on the front screen of the TV. If there are any cracks then you will need to replace the screen itself, which ranges from $100 for smaller sized TV's to $500 for larger sizes. You should probably call a local repair shop and ask them for a quote. If there are no cracks then the problem may be from within the TV. If this is the case, then you will need to figure out what part of the LCD is broken. It may be either the LED lights or CCDL's (cold cathode fluorescent lamps) that are broken. You should take it into a repair shop and let them fix it, because messing with the LED's or CCDL's is very dangerous and should only be done by a professional. The LED's should cost $100 tops to replace and the CCDL's should cost about the same. Hope this helps!
Posted on Jul 01, 2011
budmrtn
  • 11361 Answers
SOURCE: no picture, sound only on 50inch lg flat screen-3
It will require in-depth troubleshooting to narrow down to find out which board is bad. Are you going to do the repair yourself and have all the tools?
Please read below:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find
Posted on Oct 13, 2011
TV SYMBOL COMES ON TV GOES BLACK NO SOUND OR ANYTHING HOW TO REPAIR THIS
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the ...the the tv turns on but there is no picture or sound and I can't seem to fix it the .... +tbones11234 I have the same on myHisense 55" TV,what did you ... The problem is when i turned it on it shows on the screen the sony logo three times then its ...
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Click Here to BUY TV REPAIR P... ... I Have a Hisense Tv in My Screen Is Not Working Right The brightness is ... Hi my TV shows the picture for a moment and then goes .... here the sounds but you cant see nothing and a sanyo flat screene.
Jan 16, 2016 | Hisense Televison & Video
What is causing PZ550 Plasma TV to display a frozen image with bars, and then a black screen after restarting the TV? Sounds and TV functions work.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 08, 2015 | LG 50 50PZ550 50 3D Plasma TV
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
How to clean lenses on philiphs 60pp9202 tv
There are cleaners out there for flat screen TV's, monitors, lenses and that sort of thing, However good old plain water will do. Clean with a damp cloth, make sure its not too wet, wring it out well, wipe over screen it should do perfectly. DO NOT use regular household cleaners as they may damage the screen.
Jan 04, 2015 | Televison & Video
Lg plasma tv 50inch older version sound but black screen
Sounds like panel fault. Contact the authorized service center for LG. Gopakumar Gopalan Google
Apr 26, 2014 | LG Televison & Video
TV just went black. Power indicator is flashing but nothing is happening. Anyone know what just happened?
Sounds like a common problem with this Toshiba 50inch. Here's another discussion:http://www.retrevo.com/c/tvhelp/blogs/show/160/tv-will-not-turn-on-power-ok. Might be worth the full power OFF/ disconnect trick, to reset things. Power supply is shutting down, maybe due to overload. Plasma screen often uses parallel driving MOSFET transistors. If one fails - it stops them all working, until it is replaced.
May 12, 2012 | Televison & Video
Hi please help we have a 50inch plasma and there is no picture coming up on the screen at all, but we do have sound what could it be thanks
There could be a fault with your connection as it seems to working ok with the sound. If not ring the manufacturars
Jul 05, 2009 | LG 50PG6000 50 in. HD-Ready Plasma TV
Oct 12, 2007 | Toshiba 50HP66 50 in. Plasma Television
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
