Power lead fused,  need new one, can't find a dealer in Perth to supply
  • John
    John May 11, 2010
    Most printer cables are similar what type of printer and is there a dealer on the web that can post a cable
  • Thomas F. Schneider May 11, 2010
    make and model of printer?
  • 41 Answers
Yes absolutely , go to www.eBay.com
Posted on Jan 22, 2009
I have a 2 year old Meos 192B TV. It works perfectly on 220V but not on 12V. What could the problem be?
I suspect there is not enough power to run the TV. Does it work in your vehicle with the supplied power lead.
Jan 31, 2017 | Televison & Video
Locating fuse in bernina activa 220
Generally, there is no fuse issue. The problem will be a failed power supply (L-PCB). Suggest that you visit your Bernina dealer and get a new circuit. THe cost will be about $150.00.
Aug 04, 2014 | Bernina Sewing Machines
No power
Get a new power supply / cord. If the light on the TV doesnt even turn orange then its the power supply for sure.
Apr 18, 2014 | Televison & Video
Yamaha no power
you need to check the power supply input of your amplifier using a multimeter set your tester into a dc voltage reading.then measure the power input you must have a DC voltage supply reading..open the cover check the fuse an open fuse will turn the unit to no power.there are causes of blown fuse a shorted power transistor at the circuit will blown the fuse you need to replace faulty transistors before putting up a new fuse...check also the diode at the power supply section ,faulty diode could lead to the same problem..
Sep 30, 2011 | Yamaha P-2500 Amplifier
I have a new Toyota RS2000 that I was bought as a gift. I received it without a manual which I have now obtained, but now I have gone to use it the power lead does not seem to fit into the machine. Is it...
It is quite possible that you were supplied the wrong lead, seeing that the manual was missing, the contents of the package might well have been tampered with. Contact the person who gave you the machine and ask them to either check with the dealer, or go see the dealer yourself, even if you see another dealer for these machines, I am sure they will be willing to help you.
Jan 30, 2011 | Vacuums
Ignition problem: I have a gas hot water system: RINNAI CORPORATION; MODEL:REU-2008W-A the panel display temperature as 40C, when open the tap, the temperature display dropped to 12C, and no...
This is an error code 12, not 12 degrees. You have a short on your low voltage side by the sounds of it.. First disconnect the controllers inside the heater. Turn of the power first, 2 screws top and bottom to take the frnot panel off. Follow the low voltage wires (not the power point ones) to the PCB on the ride side and disconnect them both. Panel back on, power on and try the heater again. If this fixes it you have a short circuit in the controller or the wires leading to it. If not the most likely short circuit is on the thermal fuse which loops around the heat exchanger. This will need an expert, Perth has plenty north and south of the river. Give Rinnai a ring first, they have some good staff in Perth who might help.
Dec 02, 2010 | Rinnai Water Heaters
The on light doesn't come on. I suppose the power supply is gone.Can I get another power supply for an I560 and how much to replace it?
check fuse in power supply cable plug, a dc volt meter on the output leads will show if working, check makers web site for dealers and price
Jul 06, 2010 | Office Equipment & Supplies
No power - have checked fuses, power leads and master switch
Well yes, there a problem in the power supply modual.
It does sound like a failing power supply , becuse of the
fact you don't get charge up spark from the plug , wich is normal
affter it's been off /unpluged for 20 min or so .
check the resistance of the plug coming from the set with a volt meter if you have 10 meg ohms or higher,
it's an open circuit and more than likely a 1.50 fuse in the power
supply. If the fuse blows instantly then it's a shorted output transistor or rectifier diode in the switching power supply.
Be a shame to pay 300.00 plus for a stupid fuse.
hope that helps a little . if you have any questions just comment
an i'll respond
Rob
Oct 03, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Dryer is not heating up
Hi there
I think that you are going to need a new heating coil, sorry . I would contact your local appliance dealer to see how much a new one would cost.
best regards mike
Mar 24, 2009 | Kenmore Elite HE4 Electric Dryer
k24674
jasbo
jasbo
