Question about Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
What power cord and adaptor will work with a sharp lc-w
Sharp Aquos LC-20B4U-S 20 in. EDTV LCD Television
jerryg50
  • 1689 Answers
SOURCE: Sharp 20" LC-20B4U-SM
I cannot say pariculary for this model, but on some models of TV sets, if the channels are not programed as part of the channel list, they are muted.
Turn on the TV, and perform the channel auto setup.
Jerry G.
Posted on Apr 12, 2008
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
  • 308 Answers
SOURCE: I have a Sharp AQUOS LC-19SB14U 19' LCD TV that won't power on
The main power transistor in the power supply appears to have failed. It has also blown the fuse. Not a job for the DIY'er unless you have serious electronics experience.
Posted on Apr 11, 2010
jdvillanueva
  • 2098 Answers
SOURCE: Need user manual for 42"sharp aquos lcd tv
Hi Rebecca,
Please click this LINK to download the Pdf file format of Sharp LC-42D65U User Manual.
Click "Download Document", enter your email add, enter the confirmation no., and then click "Download". It is a safe website, I used it personally.
Hope I helped you.
Thanks for using Fixya.
Jdvillanueva
Posted on Jul 09, 2011
  • 4 Answers
SOURCE: Sharp Aquos LC-37GD6U 37 in. HDTV LCD.
Try to check the program if its not auto OFF and its not try to check the wires or the power chord.
Posted on Nov 08, 2011
I have 20 LCD Sharp TV Model No. 20B4U-SM made in 2003.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ..
Sep 10, 2016 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Sharp 20 LCD TV
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
I have sound but no picture on my tv sharp aquos 20 inch
if you mean have sound but no Pic.or no raster, horizontal section is the culprit. most problem is at the Horizontal output section that drives the Flyback transformer. Pull out that HV cap & test them to ground if there is some arc coming out. No arc means failed output section or the flyback transformer need to be replace..
Sep 25, 2013 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Looking for a stand for Sharp Aquos LC-2084U-SM
Go to shopjimmy.com and get a universal stand. It attaches to the back of the TV just like a wall mount
Nov 08, 2012 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
6 yr old 30 sharp equos. When I turn on red light flashs green and turns back to red immediately and no picture.
I have the exact same problem. Check to make sure the AC power box isn't making a ticking noise. It could indicate a faulty box. I'm getting mine checked out asap. I'll let you know how it goes!
Jun 19, 2010 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
I am getting a black square in the upper left corner. How do I get rid of it?
Press CC button on the remote control until you see CC/TT OFF.
Closed Captioning or TeleText is the cause of the problem.
Dec 28, 2009 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Were can i buy a replacement powr cord
Are you looking for power adaptor or just a power cord?
Part number for adaptor : UADP-0243CEPZ
Part number for ac cord : QACCD3097CEPA
Both parts are available from Sharp.
Nov 30, 2009 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Jerry G.
Nov 20, 2007 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Sharp Aquos LC-20B4U-S 20 in. LCD EDTV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
