Question about Motorola Mobility H700 Wireless Headset
Why does this chirp every 9 seconds,and how do i stop it
My wife had her phone turned off internally.turned it on and problem solved
Posted on Jan 23, 2009
After I set alarm, it chirps once then 2 seconds later it chirps once again!!
That second chirp is a status alert letting you know a zone was not able arm yet. Most common reason is that the dome light its not out yet. It arms itself as soon as the trigger goes to sleep.
May 01, 2014 | Vehicle Parts & Accessories
Smoke detector keeps chirping after battery is changed, chirps every 30 seconds. chirps come from the ceiling not the device
The chirp means the battery you chose wasn't good enough... it has to be the newest '''alkaline''' you can get hold of. If it isn't alkaline that's why you are having trouble. Upon replacement press the button to do a hard reset.
Aug 11, 2013 | Kidde Home
Alarm chirps and light flashes red
Replacement battery could be defective. Also, the battery interlock may have been damaged during replacement.
Dec 30, 2017 | First Alert SA302 Dual System Smoke...
How to program new remote to alarm
TRANSMITTER PROGRAMMING Note: System can learn up to 3 different codes max. 1. Turn Ignition ON and OFF 3 times quickly, leaving it ON the 3 rd time. (ON/OFF, ON/OFF, ON) You should hear (1) short chirp. 2. Push the Program/Override Button for 5 seconds until the siren chirps (3) times. Release the button. The system is now in programming mode. 3. Press Button #1 on new transmitter - siren will chirp to confirm programming. Repeat Step 3 within 5 sec. for up to 2 additional transmitters. 4. Turn off Ignition. Note 1: If only one transmitter is being programmed, continue pressing button #1 until dash LED flashes goes out and the system chirps to exit programming mode to prevent unauthorized codes and noise from entering the system. Note 2: Programming mode is exited automatically after 5 seconds of last code transmission or once 3 new codes have been programmed. The LED will flash (4) times indicating program mode exit.
Jan 12, 2011 | 1Way Remote Transmitter
On my remote the unlock is the only thing that works. my lock and remote start doesnt work. everything used to work before i got my transmission fixed and when i got it back nothing worked and i have been...
You could try reprogramming the remote: ignition on, press and release programming switch 3 times, you will hear one chirp( channel 1),press the lock button, press and release the switch 1 time ( two chirps, channel 2), press the unlock button, press and release switch 1 time ( three chirps) press green remote start button,press and release switch 1 time ( 4 chirps) press option button. Turn ignition off. test. If this doesn't work, try disconnecting the unit's power for about ten seconds, then reconnect and test.
Sep 30, 2010 | Car APS997A Two-Way Remote Start and...
it sounds like the chips have been eliminated, if so......
1) turn ignition "on" and then "off"
2) within 10 seconds push the valet buttons three times
3) you should get 1 siren chip indicating the chirps are now "on".......if, you get 2 chirps then you just eliminated the chirps.
May 22, 2009 | APS787 Prestige Remote Start and Security...
Rca 36" F36685
YX2 = part # 244247..................................................T.
Jan 15, 2008 | RCA F36685 36" TV
Grill-mounted K-40 continues to "chirp" every 10 seconds...
I too had the same problem and called their customer service. They told me 1 chirp means a front receiver fault, 2 chirps means a rear receiver fault. They suggested I check the wiring and to switch the front receiver with the back receiver to see if the error code would "travel" with it to determine if the receiever was faulty. I did that and the problem went away. I assume I had a connection that loosened up.
Jan 13, 2008 | UN 3000SW Radar Detector
Motorola Mobility H700 Wireless Headset Logo
54 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
