Question about Yamaha Full-Size Keyboard
The power adapter no longer works. Where can I get a replacement?
  • 2 more comments
  • margaretgv Jan 22, 2009
    The model number is PA-300. Output is 16V 2.4amp and yes I am in the USA
  • margaretgv Jan 24, 2009
    I had already goodled the part number -the results did not produce anything helpful.
    I was surprised too that the web dealers web pages you recommended did not yield an answer using their search. But the one did have aphone number and that worked this morning. By early afternoon I had two e-mails from them letting me know it was ordered, then it was shipped and about a half hour later I had an e-mail from Fedex with their shipping info.
    Absolutely terrific response and follow through. Thanks for your help.
  • honeyballs Mar 21, 2009
    Dudeeeeeee mine doesn't work either!
    and it's so old and Yamaha is like "sorry, we don't sell that product anymore."
    ARE YOU KIDDING? what am I supposed to do? this is totally bullsh'it.
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Look on the adapter and give the specifics. It should say something like...Output 12VDC @ 500ma or something similiar.
    Post that and I'll try to find something online. Are you in the US?
    President:
  • 1,901 Answers
Here is just one site where you can purchase it:
http://www.musiciansbuy.com/ADAPTER_YAM_PA_300U_PSR10.html
This is brand name at $79.
Here is another, a little higher price $83.50.
http://www.bhphotovideo.com/c/product/449747-REG/Yamaha_WH943000_PA_300_Power_Adapter.html
If you care to search online more, just Google Yamaha PA300.
Thanks for using Fixya. A Fixya rating would be appreciated.
Posted on Jan 23, 2009
  • Wayne Mineard
    Wayne Mineard Jan 24, 2009
    Thanks for increasing the rating. It's appreciated.
Replacing ac power adapter.
If the polarity, voltage, and amperage are the same, there is no reason that you cannot use this device as an alternate.
Oct 16, 2016 | Roland Music
My CTK 720 isn't powering on from the adapter anymore but battery power is working. I bought a new adapter but it still isn't powering on. Can this be repaired?
This could be a loose plug inside the unit or it could be a circuit that is bad. If the plug failed it is from physical damage from something like tripping over it or heavy use. That can be repaired by replacing the plug. If it is something like a component in the unit on a board then it becomes a little more involved.
Mar 26, 2016 | Casio CTK-720 Electronic Keyboard with...
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
I have a Yamaha digital piano 95. After it being idle for a month I plugged it in and it no longer works. The master on off switch will not come on. I've tried re-doing all of the plugs and making sure...
Here is a possibly helpful clip from Page 25 of your User Manual: "If this instrument somehow becomes disabled or malfunctions, turn off the power to the instrument, then perform the initialization procedure." So, how do you "initialize?" Turn the power off; hold down high C (the farthest right white key on the keyboard, also called C7), and turn the power back on while holding down that key. Try it. It may work for you. Another suggestion I have is to verify you have good 12 volt power coming out of your adapter. Yes, you have checked the wall outlet. Good. But have you done anything to be sure the adapter is doing its job? The best test is done with a voltmeter or multi-tester. Harbor Freight sells them for $4, and sometimes even gives them away to people who bring in the right coupon from print ads or the HF website. If you are uncomfortable with a meter, you can [CAREFULLY!!!] create a brief dead short across the adapter output and watch for little sparks. Do this with a small, insulated screw driver, and avoid bare skin contact with any "live" metal. The absence of sparks or current coming out of the adapter suggests you should replace it. Good luck. Truly.
Jul 24, 2014 | Music
Yamaha dgx 205
If you have a voltmeter, you can test to make sure that your powere adapter is putting out the right voltage. (Should say on the label something like 120v IN - 12VDC output.
If it is bad or you don't have a meter to test it... You can get a replacement for less than 10 bucks on Ebay.
If the power is good, you have to move on to power button, etc.
I would call an electronics pro...
Dec 17, 2013 | Music
Yahama PSRE413 Keyboard DC Adapter Issues
Yahama PSRE413 Keyboard DC Adapter Issues (1): First try battery power to ensure Synth works.
If it does, problem is most likely near DC socket, or socket contacts dirty / worn.
(2): Get a contact-cleaner spray (Servisol, McKenic, Kontakt, etc) and squirt into socket, then plug / unplug / twist DC plug to 'scrub' the contacts.
(3): Get a qualified tech to manually apply DC to the PCB solder-points which will verify if socket is faulty.
Aug 10, 2017 | Yamaha PSRE413 Keyboard
Casioik90tv wont work trough power
Likely a problem with the power connector or the power adapter. Make sure you are using the original power adapter as often replacements don't work and universal adapters seldom work.
Nov 05, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
Power adapter specification ct-630
Hi - look in back or under keyboard for power specs.Then go to Guitar Center and the right adapter. GuitarCenter.com has casio power adapters.
Jan 04, 2010 | Music
My Zoom H4 will no longer run with batteries. If I use AC adaptor it works fine but I get nothing on battery power
Probably the connector where you plug the AC adapter into has a switch contact that disconnects the battery when external adapter is used and it has gotten bent so when the adapter is not plugged in, it no longer makes contact to the battery power. This is pretty common for devices that use both battery and adapters.
Aug 23, 2009 | Zoom H4 Handy Recorder
Yamaha Full-Size Keyboard Logo
166 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
