Question about Samsung FPT5084 50 in. Plasma HDTV
No power to Samsung FP-T5084
I was watching my Samsung FP-T5084 50 inch plasma and it went dark. Since then I have tried a different but compatible power cord, a different outlet but even the red standbye light does not come on. I was wondering if there were any other simple trouble shooting things I could try or if anyone has heard of or has experienced similar problems.
  • mdgnowles May 11, 2010
    Where can I buy (online, or locally) 12 Amp, 250 volt ceramic fuses? I believe they are 20mm in length, but I could be off slightly. They fit in the power supply of a Samsung FP T5084. I need (2) of them. Thank you very much in advance.
I had the same problem twice with my Samsung FPT 5084 and it was the 12 AMP fuse on the power board both times. The bad part is you have to remove the whole back plate to get to it but once off it sits on the power board (dead center) towards the lower left hand side of it. Replace the top fuse or you can replace both. They're just regular ceramic sealed 12 AMP fuses that cost about 50 cents each.
Posted on Apr 23, 2009
Same problem. I took it to a local repair shop. They replaced a 10 amp fuse on the power supply ($2.83) and resoldered the power supply module. total cost $143.00 Works as good as new. Lots of complaints on this issue on the web--I think the TV gets too hot and blows the board after about 2 years.
Posted on May 12, 2010
Did anyone find these fuses online? 12amp 250v?
Posted on Feb 20, 2010
  • valery_kicha
    valery_kicha Feb 07, 2012
    Here you go:http://www.samsungparts.com/Products/Par... The fuse with the part number DH81-11975A is compatible with the TV.
Power light blinks clicking sound no power to screen
Posted on Mar 11, 2010
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
I need a Repair/parts manuals for Samsung Plasma, Model FP-T5084
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 18, 2015 | Samsung Televison & Video
Samsung fp-t5084 fuse fix is the replacement fuse slow burn or fast burn?
I'm certain it uses a T12amp slow blow type. I have the exact same model, you can replace the fuse. The TV will for a while, but that fuse will blow again. You will need to replace the power supply board for a more permanent fix.
Dec 21, 2012 | Samsung FPT5084 50 in. Plasma HDTV
Fp-t5084 Samsung 50" Plasma does
Hi, Here are some basic steps that will help you fixing the problem. I'm assuming that your unit is dead set without an standby LEDlight and your outlet is live.1.Power cord - check the cord it might be opened (nocontinuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse-sometimes the fuse fail because of the powersurge, replacing with new one will cure the problem, If this is the case Iwould advice you to use surge protector/AVR (Automatic Voltage Regulator).However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit thelinkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction andstill the unit didn't power up then you have an open parts on the power supply. 4.If you see that the fuse is intact , don't attempt to touch anythingbecause there some fatalcomponentsstored electricity enough to hurt you with a simple mistake only. I wouldadvice you to look for aprofessional to troubleshootthe power supply. If you want to repair it yourself make sure that you havenecessary tools and testinstrument. First check bad solder joints(re-solder allcold solder), leakyelectrolytic capacitor(sometimes it has bulged at the top but not all, you betterhave a capacitor checker), open/shorted regulator transistor/IC(mounted in heatsink), open fusible resistor (caused by shorted regulatorTransistor/IC), shorted zenerdiode. You may also replace the power supply board, this is more convenient if you are going to DIY because no soldering required. Obtain the board from your local Samsung service centers.
Also check if your unit is under warranty before opening the backpanel, it will void the warranty. Avail it because the manufacturer of yourunit will fix it for free or a little charge only. Hope I helped you. Have a nice day! Thanks for using fixya.
Aug 04, 2011 | Samsung FPT5084 50 in. Plasma HDTV
My samsun fp-t5084 is making a loud whining noise
its either a fan going out or power transformer. take the panel off and turn on the unit while being careful not to touch anything at all while power is to the device. plug it in and listen so you can identify the component. If its a transformer (it would more than likely be square and wrapped in a thick polymer sheeting.) it will be fine, possible for good. If its the fan making noise, you will typically have 9-12mths from the time you first here the sound before the perfomance is affected.
SO, to make a long story short, a hummming sound is typically the sound of electrical variations in a component, whining is normally a rubbing action within metal and plastic components.
(plastic on plastic makes a squeek, metal on metal a higher pitched squeek)
Jun 04, 2010 | Samsung FPT5084 50 in. Plasma HDTV
My Samsung FPT5084 50 Inch Plasma TV....keeps turning itself on and off. Does a solution exist to my problem. I am out of warranty,
http://www.retrevo.com/support/Samsung-FP-T5084-TVs-manual/id/2839bh444/t/2/
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=02010200&prd_mdl_cd=&prd_mdl_name=FP-T5084
Below is the service manual link from epox. ftp://ftp.epox.com/downloads/Manual/mu-8KDA3J&+11.pdf
This is usually a switchmode power supply problem, and it's shutting down, for safety reasons, so as to avoid a fire and explosion or both. Realistically you need to get a "Quote" from an authorised service agent, for repair.
May 24, 2010 | Samsung FPT5084 50 in. Plasma HDTV
Samsung FP-T5084 No picture
For a 50 inch plasma....its worth it, in my opinion y-boards cost around $149 to $189
Nov 03, 2009 | Samsung FPT5084 50 in. Plasma HDTV
I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. It was plugged into a power strip with other...
Could be the PCB, but it is hard to say. I am looking for one that has a good screen since mine got cracked (don't ask LOL) so if you are interested in selling it let me know.
Thanks!
yrk2.7t AT (replace with @ symbol) gmail.com
Oct 25, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Samsung FPT5084 50 in. Plasma HDTV Logo
4,612 people viewed this question
Jerry Greenberg
Jerry Greenberg
