Question about Led Lenser/Coast/Zweibruder Coast LED Lenser T7 High Performance LED Flashlight HP8420 167 Lumens 4 x AAA SpeedFocus
My T7 led flashlight won't shut off
How to disassemble a zoom focus flashlight
Ultrafire/CREE XML XM-L T6 LED 1600LM Flashlight Torch ...
? 27:39
https://www.youtube.com/watch?v=lsPdC-xgxTU
Oct 15, 2013 - Uploaded by Richard Lloyd
Here is a link to this CREE XML XM-L T6 LED 1600LM flashlightat ... 1600LM Flashlight Torch Lumen Zoomable Review/Disassembly/Mod.
CREE Flashlight - How to Fix Frequent Problems - YouTube
? 8:04
https://www.youtube.com/watch?v=zJpQAvum0bM
Dec 21, 2010 - Uploaded by motorbiking
How to repair your flashlight if the LED stops working, if it changes mo... ... Mini Cree Led Q5 Ultrafire Flashlight Torch Adjustable Focus Zoom ...
Disassemble HausBell CREE Flashlight (replace battery ...
Jan 19, 2016 | Cameras
How to chnage batteries
The four AAA alkaline batteries are securely held in a battery pack attached to the tailpiece, which incorporates the T7's push button "Quick Cycle" selector switch. Unscrew the tailpiece, remove battery cartridge and refill with 4 "AAA" batteries. Slide the cartridge back in the torch and screw the tailpiece back on.
Kevin
Dec 18, 2014 | LED Lenser T7 Flashlight
Where do i send my light to be repaired
Not to many places are around anymore that I know of that fix appliances whether it's a flashlight or whatever, unless you know somebody personally that fixes items on the side as a hobby. Maybe sometimes the company of the product offers a repair or replacement. But sometimes the cost of that process out ways the cost of a new one. That's partially the reason most places don't repair.
Feb 17, 2014 | Streamlight Stinger Led Flashlights Led...
My Emerson 9X Power flashlight doesn't work
short circuit causes this problem, no hope better replace it by expert.
Oct 22, 2012 | Emerson Led 9x Led Flashlight 4-pack...
Trunk won't open
can you access it from the back seat.? you might have to remove the bench seat and then the back rest to shine flashlight to see if indeed something is jammed in the latch.
Aug 12, 2017 | 2007 Chevrolet Corvette Convertible
Pelican 7060 flashlight manual
FlashMax G179 - Waterproof CREE LED Flashlight
Adding the particular FlashMax G179 water-proof, powerful DIRECTED Flashlight. This kind of torchlight will be one thing to seriously acquire anxious about. It really is really potent. Remarkably resilient. Water-proof. And also makes use of Cree LED's, and that means you realize you'll get white colored mild together with decades regarding program using this attentively developed Flashmax DIRECTED Flashlight.
Apr 17, 2012 | Pelican 7060 LED
Maglite 2aa back cap won't come off
SOUNDS LIKE IT IS CORRODED. PUT A FEW DROPS OF RAPID TAP TAPPING FLUID OR A FEW DROPS OF THIN MACHINE OIL AROUND THE CAP. LET IT SIT FOR A FEW DAYS AND TRY IT AGAIN.
Feb 03, 2012 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
What kinds of a flashlight the brightest?
Check out this WEB site for super bright LED flashlights.
http://www.nextag.com/super-bright-led-flashlight/stores-html
Nov 28, 2011 | Camping, Backpacking & Hiking
I have an Xacta Mirage light, I believe it is LED. The bulb seems to be brned out and I cannot find any information regarding replacement bulbs. Can you help?
I cannot find any info either, so lets "figure" it out. Does the "bulb" look like an interchangable (replace-able) bulb - LED's "almost" never need replacing (for the most part) and manufacturers always solder them in. I'll assume that you cannot twist (or un-screw) the bulb.
Now what to do...if you really like this flashlight - you could open it up, un-solder (or cut leads) the LED and put a new one in. The LED to use is:
- one that can handle the voltage - measure voltage (with volt meter) at the burned LED with flashlight on (keep track of polarity, which wire is negative/positive for the new LED),
- you will check for a flat (fish eye magnifier) top surface or round top,
- check for size (diameter) of the LED.
Now match that up to an LED at www.digikey.com They will have higher prices but, you are only buying 1 LED and they have the biggest selection to better match you old LED.
There are lots of new flashlights out there and getting a new one may be a good option.
Jul 12, 2011 | Camping, Backpacking & Hiking
Led Lenser/Coast/Zweibruder Coast LED Lenser T7 High Performance LED Flashlight HP8420  167 Lumens 4 x AAA SpeedFocus Logo
359 people viewed this question
Top Led Lenser/Coast/Zweibruder Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Led Lenser/Coast/Zweibruder Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
