Question about York Furnace Draft Inducer Blower Fasco # A224
York p3urd10n05501a blower - York Furnace Draft Inducer Blower Fasco # A224
I have a York heat pump AHP42c and the blower is vibrating excessive.
Is anything inside the blower wheel? Check both sides. It could be a paper towel or something else that was sucked into the wheel
Aug 12, 2016 | York 3.5 Ton 13 Seer Heat Pump
York lr49182c unit
www.york.com/residential/york-owners
Mar 17, 2014 | Heating & Cooling
YORK MODEL DJO6O BLOWER MOTOR WILL NOT SUT OFF
Does it run if youn pull the thermostat from the base?
Feb 25, 2014 | York Furnace Draft Inducer Blower Fasco #...
York Diamond 80 control board blew out on the blower connection
I would first check the blower to be sure it is ok. If so then the control board would need to be replaced.
Dec 11, 2013 | York Tools & Hardware - Others
CAN FURNACE BLOWER BE REPAIRED???
sorry but a search for that did not locate anything here in USA
Nov 18, 2017 | York Furnace Draft Inducer Blower Fasco #...
York "high Aux or spill limit switch open"
how can I fix the spill limit switch, also how do I found it
Mar 05, 2010 | York Furnace Draft Inducer Blower Fasco #...
Where is the furnace filter located on the York P3CGD12N08001B
Residential furnaces have exterior filter boots supplied by installer, commercial york units have filter access doors. If this is a roof top unit your filters would be in the door to the left of the blower compartment.
Nov 18, 2009 | York Yankees Bedding MLB Comforter
York diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Jun 20, 2009 | York Furnace Draft Inducer Blower Fasco #...
York  Furnace Draft Inducer Blower Fasco # A224 Logo
29 people viewed this question
Top York Tools & Hardware - Others Experts
vince
Paul Carew
Are you a York Tool and Hardware - Other Expert? Answer questions, earn points and help others
