Question about Dyson Airblade Hand Dryer, Silver
The heater does not work very well, it takes it longer to warm up that when it was new
How do I fix my carpet cleaner
It is not an easy project. It could be several issues.
1) Heater clogged up.
2) Solenoid valve(s) not working.
3) Pump not pumping.
Here is one thing you can try. Fill the bladder with hot tap water. Try spraying form the hose only. (Do not attach any of the attachments to it. Just spray directly from the hose.) It may take a minute or so but many times it can prime itself and start working after doing this.
If it is any of the problems above this will not fix it.
Apr 03, 2016 | Bissell 1699 ProHeat Clear View Upright...
I recently purchased a 2lb bread maker. But cannot find the manual or recipe book so I can use it. I brought it from QVC. Can you tell me where I can get this information. I would love to start using...
If you want to use the bread machine immediatly, boxed bread mixes from grocery stores will have generic instructions on the back of the box that can be used universally by most bread making machines. However, if you are wanting the manual and recipies to the particular machine, sometimes the place you purchased it from will allow you to photocopy one from a new one on the shelf. You would need your receipt to prove the purchase. Google Search is also an excellent way to download copies. The contact information on the box will too. In the meanwhile, if you want to make perfect bread follow this recipe BUT>>>do not use the machine for this recipe, use a large bowl to raise the dough.
4 large bread loaf pans, lightly greased with 1 teaspoon vegetable oil each. Set aside
4-6 cups+ flour
1/3 cup evaporated milk
3 2/3 cups water
1/4 cup active dry yeast
1/4 cup salad oil
1/8 cup table salt
1/6 cup sugar
Put the water and evaporated milk in a glass bowl and microwave to 120*~about 2 minutes. It should feel very warm to the touch but not as hot as a cup of hot coffee.
while microwaving, take a second very large bowl (big enough to hold a family size bag of chips)
put the salad oil, sugar, salt and yeast in and stir till mixed.
Add the very warm but NOT extremely hot milk water to the dry mixture. Use a swizzer to mix. Start adding the flour till very thick. Take swizzer out and add more flour gradually until it can't absorb more and is no longer sticking to the sides of the bowl. Shake more flour on a clean counter top and work the dough 3 minutes until smooth and not sticking to the counter. Place dough in another very large bowl. Cover with plastic wrap, place in a warm area such as the vent area of a 225* oven to rise. Punch down after double in size (about 30 minutes). Divide into 4 equal portions. Shape and place in pans. Rise 15 more minutes. Heat oven to 375* bake till golden brown on top and a finger tapping sounds hollow.
Wrap in plastic wrap when cooled slightly to keep moist. Refrigerate loaves to keep longer.
This recipe can be used for cinnamon rolls, clover leaf buns, pizza bread sticks or all 4 if you divide it up! Enjoy....I'm also a competition baker!
Sep 22, 2011 | Vacuums
I have a micromark electronic safe at home but the battery is low therefore it woun't let me open the safe and i don't have the key
hi.
without the key, your options are very limited.
apart from destructive drilling, or expensive locksmith charges there may be one chance.
place a fan heater, or similar heater in front of the safe for 3-4 hours until the safe is warm to touch.
be careful not to cause a fire risk around the safe, or to overheat the safe. DO NOT leave unattended.
it will take this time for the heat to be slowly transferred to the battery compartment on th einside of the door, but when the batteries warm up, you may find they have a slight boost from the heat, and actually have enough power to open the safe.
there are no guarantees that this technique will work on your safe, as it is very dependent on the amout of life left in the batteries, but is worth a try as a last attempt before expensive drilling or locksmith charges.
good luck
Jun 09, 2011 | Vacuums
My heater is broken
You did not indicate what kind of heater it is.But if it is a space heater and it warms up but doesn't blow,unplug the unit look for a tiny capsule like fuse link that looks like a tiny capsule with wires on both ends either let an electrical technician replace it for you. But if the heater blows air but no heat,there is no way you can remedy it cause if the wires are broken reconnecting it will only worsen and will cause fire,better buy a new one.
Feb 02, 2011 | Vacuums
Lo longer steams
I just finished taking my wifes S3101 apart because of the same problem. I found the inlet and outlet hoses clear, so the problem had to be with the heater. I took the water side of the heater apart and found the outlet nipple clogged with dirt and sand. I live in VA Beach and my wife uses tap water. There was a lot of sand and dirt in the heater, so I cleaned all of that out, used a very small drill bit to clear the outlet nipple and then reassembled. It works fine now, and you will have to use distilled water if you want the unit to work for any period of time. The casing screws were a real pain to remove, so take your time.
Nov 30, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
ELECTROLUX OLYMPIA ONE HOSE
Usually the older hose get replaced, they just weren't made to be repaired, if it looks like something that will come off, then try either warming the sleeve up with hot water or a hair drier to see if you can work it off after it has warmed up.
Apr 10, 2008 | Vacuums
Bissell ProHeat Clear won't spray from floor nozzels but it does stray from hand cleaner
Usually when the hand tool works ok, then the heater inside the handle asm. is clogged. The water bypasses the heater when you use the hand tool. Other then that it could be a bad pump.
Apr 06, 2008 | Bissell 1699 ProHeat Clear View Upright...
I have a Bissell powersteamer proheat. The problem is that the unit will no longer spray water/cleaner out of the bottom of the unit.
Check to see if water will squirt out of the hose, if it does, then take the handle apart, the heater may be clogged. Once you get to the heater, take off the 2 water lines, dig out the clog, try to blow thru the heater to make sure it is open, then put back together. Otherwise it could be the belt, pump, seal not in place on the bottom of the tank or a clogged water line.
Mar 05, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Water and clearen not coming out.
If the modle is an old modle the heater could be blocked,or if it a new modle try taking of the of the handle and ad a small shim to the bottom of the handle plunger to make it a little bit longer ,the plunger might not be reaching the valve,
also unscrew the clear cap which which is on top of the red spinner to see if the white filter under the spinner is clean and free from debris.
when you put the cap back on make sure its not to thigt and the spinner move freely, if the suction is poor make sure the red lint filter in the clean water tank is clean
Oct 20, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Won't release shampoo
If your floor cleaner doesn't spray, chances are the heater unit is clogged. It is easy to fix if you have a few simple tools and are mechanically inclined.
Steps to fix:
- The heater unit is located inside the body of the machine, behind the power/heater switches. Remove 6 screws and split the case open.
- The silver metal "box" inside is the heater unit. Take note of how the hoses and wires are connected. Better yet, take a digital photo for reference.
- Remove the wires and hoses.
- Take the box to a work bench, and unscrew the 6 or 7 screws that hold on the lid. Don't lose the red washers that are found on the inside of the box that keep water from leaking out of the screw holes
- You'll see a "maze" where the water runs around to get heated up. Clear this of all debris. The inlet and/or outlet ports may also be clogged. I used an appropriate sized drill bit mounted on an electric screwdriver to carefully "drill" out the clogs. Make sure all the debris has been removed. I used an electric screwdriver because my 18v DeWalt hammer drill would have been overkill :)
- Reassemble to box
- Rewire and plumb the box according to your notes or reference photo.
- Put the machine back together.
Doing this saved me a $85 repair and took 30 minutes. My machine now works perfectly.
Sep 04, 2006 | Bissell 1699 ProHeat Clear View Upright...
Dyson Airblade Hand Dryer, Silver Logo
15 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
