Panasonic ff-393 manual - Audio Players & Recorders
I BOUGHT A CENTECH OBDII 60794 SCANNER ON E-BAY AND WHEN I CONNECTED IT TO THE CAR I GOT ABOUT 6 FF 00 00 01 00 01 THRU 6,HOW CAN I RESET IT TO FACTORY SPECS?
if it was new there would have been a user manual in the packaging for that purpose
if you git it 2nd hand , there may be a user manual on line or it is a dud unit
Oct 19, 2015 | Cars & Trucks
Need schematic for laser sight 30x ff-393
You directed this question at me, but unfortunately I'm unable to provide you with a "real" solution at this time. FixYa has informed me that by providing you with this "solution" your question will then be made visible to other experts; hopefully one of them will be able to provide you with a real solution.
You might want to post this question in a category other than "Calculators."
Thank you for using FixYa.
Nov 30, 2011 | Office Equipment & Supplies
Remote control arrow buttons suddenly dont select things anymore
Read page 36 of your users manual Its all under Manual Exposure
Please rate our help ++++
Thank you for using Fixya.com
Sep 01, 2009 | Panasonic PV-DM2794 27 in. TV/VCR/DVD...
Pioneer DV 393 no region free
I think that the general unlock is:
Open disk drive> press 1,2,3,4 on remote> close disk drive
Worked on mine.
Hope it helps,
Ed
Feb 01, 2009 | Pioneer DV-393-S
Error code
SC No. Item Definition Possible Cause Related
SCs Troubleshooting Procedure Type
SC
393-
001
TD sensor error
during warming
up
393-001: K
393-002: Y
393-003: C
393-004: M
The development-unit drive
starts. TD sensor signal is 0.78
V or less.
• Loose cable
connection
• Positioning plate out
of place
• Defective TD sensor
• Development unit not
found
1. Turn the main switch off and on.
2. Check that the development unit is
correctly installed.
3. Remove the development unit and
check the connector on the rear.
4. Check the positioning plate.
5. Replace the development unit.
Hope this can help you , seems the problem is on the black development unit
Aug 12, 2008 | Office Equipment & Supplies
No remote
The only thing that you are able to program without the remote is the language, channels, and time by pressing and holding the play and FF button for five seconds until the tv turns off, turn it on again and you will get what i just mentioned...
May 21, 2008 | Panasonic PV-C1320 13 in. TV/VCR Combo
Lens filter size.
The filter size for the FZ20 is 72mm.
May 19, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
 Grubhead
Grubhead
