Question about Nokia C5 Cell Phone
Nokia c5-2 phone memory full and is black out but has power,with no assess view
Cant get pc suite because memory is full for operation
    Master:
  • Nokia Master
  • 520 Answers
Hello Dear:::::
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Posted on Jan 11, 2013
  • 11 Answers
SOURCE: CA-42 cable connection via nokia PC Suite
Yes
I have experienced this problem. What you need to do is plug the usb cable into the computer before switching the computer. Make sure you don't plug the other end into the mobile phone yet.
Once the machine boots up. If you've installed nokia pc suite. It an icon will appear in the taskbar. Click on it can't remember whether its right or left click, but you need to select manage connections. Now if you are using a genuine nokia data cable you shouldn't have problems but if it isn't then you need to uncheck the usb options and check the option called 'serial'. Once you've done this a button called properties or settings or configure which is greyed out should become active. Then from the drop down box you will have various options eg. com1, com2, com3. What normally happens is when you don't have the cable plugged into the usb port only com1 will be displayed. But when the usb cable is plugged in com 3 or com 4 will appear. So you select com 3 or com 4, then OK. Wait for a few seconds then connect you other end of the usb cable to your mobile and it should recognise it after a few seconds.
Posted on Nov 28, 2007
  • 51 Answers
SOURCE: to remove installation log
hi
may be you dont save any thing in the phone memory try to save some thing in your phone memory then see
thanks
your friend from fixya!
Posted on Oct 25, 2008
CosmaP
  • 409 Answers
SOURCE: Phone memory full-Nokia N91 8GB
Go in to the message program and delete all sent and received messages.  also check the drafts and outbox.  Check that photos are being saved in the big disk not the phone memory.  Move all photos and music to the big disk.
When you have done this.  With the phone still turned on, pull the battery out.  This will cause the phone to do a restart.  Then you should be ok.
Posted on May 28, 2009
  • 523 Answers
SOURCE: n72 pc suite support on phone issue
Hi Friend,
The PC Suite which u have installed may not be properly installed so kindly follows the below link and download the free version os Latest PC Site with Software Upgrade.
After installing check it u will be able to connect the mobile and PC via PC Suite.
Then u can see all the messages and contacts,music files,datas,etc
Regards,
Ayyasam
Posted on May 30, 2009
piyushclal
  • 148 Answers
SOURCE: my nokia 5130c is not supporting nokia pc suite
Not able to connect ur phone. Thats Wierd.
well connect ur data cable to pc & phone. when u do so, u'll get options on ur phone like
1. PC Suite Service
2. Mass Storage & all..
select PC suit service & then its done.
but for PC suite service, u need nokia pc suit on ur pc too..
Posted on Aug 27, 2009
If i format my 5130c-2 phone shall i lost my messages,recordings and mant other things
no other solution only can full flashing software or format your phone
Aug 29, 2012 | Nokia Cell Phones
A general: memory full close some applications and try again appears everytime i send a message
Hi....
Try the following... *Restore your Phone once (To restore Goto Menu>Settings>Restore Factory Settings>OK(default security code is 12345)
*Clear some memory of Phone and Memory
*Scan your Phone and Memory
If problem persists you need flash your phone
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit) To back up your files *Install the Nokia PC suit *open Nokia PC suit >Select Back up
To restore Backed up data *Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset *A Computer *Nokia PC suite of your handset *Internet connection(Min speed 1Mbps) *Nokia software updater(you can download by using Nokia PC suit)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
I hope this helps... Thank you have a nice day
Feb 03, 2011 | Nokia E63 Cell Phone
Music player does not open
Try the follwing.... *check whether your phone or memory card memory full or not If memory is full clear some memory
*Scan with a updated version of updated antivirus
If problem persists you need to flash your handset
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
Jan 27, 2011 | Nokia 3110 Cellular Phone
How to see items from phone memory of nokia n81. it always shows phone memory full but cant delete anything or cant see d phone memory
You need to connect the phone to the pc using the datacable. You need to have installed the nokia pc suite installed on the computer. so when you connect the phone, it will be recognized by the pc and when you open the My Computer window, you will see a nokia phone browser folder. open it, you will see two drives. one will be your phone memory and the other you memory card.
Thank you.
Dec 08, 2010 | Nokia N81 Smartphone
Inbox doesnt oepn
Your memory card could be corrupt.
If you have a PC Suite for your phone then try to access other details from your memory card through your computer.
If you cant view your items in the memory card from the PC Suite then obviously the memory card is corrupt.
Reformatting your memory would restore it back to normal.
May 22, 2009 | Nokia N72 Cellular Phone
N73 phone memory full
just update or reinstall ur firmware...throught pc suite new version...u just need original usb cable...
May 19, 2009 | Nokia N73 Cellular Phone
How do i download songs onto my nokia 3500?
Music player
Your phone includes a music player for listening to music
tracks or other MP3 or AAC sound files that you have
downloaded from the web or transferred to the phone
with Nokia PC Suite. See "Nokia PC Suite," p. 28.
Music files stored in the music folder in the phone memory
or on the memory card are automatically detected and
added to the music library during the startup of the phone.
To open the music player, select Menu > Media > Music
player
Nokia PC Suite
With Nokia PC Suite you can manage your music,
synchronize contacts, calendar, notes, and to-do notes
between your phone and the compatible PC or a remote
internet server (network service). You may find more
information and PC Suite on the Nokia website. See "Nokia
support," p. 9.
Nokia PC Suite
You may find PC Suite and related information on the Nokia
website at www.nokia-asia.com/pcsuite.
You may find this manual with all the informatin you require at the following link:
http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_3500classic_APAC_UG_EN.pdf
Apr 20, 2009 | Nokia BNIB NOKIA 3500 Classic Unlocked/Sim...
Moving music files to mass memeory
u will have to transfer the files through connecting your phone to a computer using PC Suite
Nov 12, 2008 | Nokia N95 Cellular Phone
Nokia C5 Cell Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
