Question about KLH Audio Players & Recorders
Klh model 9362
What is the ohm rating for these
2 Suggested Answers
  • 87 Answers
SOURCE: How many ohms is the
I would suggest you contact KLH at http://www.klhaudio.com/contact.html.
They should have that info for you.
Posted on Dec 28, 2010
I have a pair of KLH AV5001 speakers and I have them hooked up, there is sound but it's distorted and there's zero base, an instruction manual or any advice would be great, thank you.
Without knowing what they're hooked up too.. SOUNDS like your uder powering them, OR over powering them. Look at the back of the speakers the wattage is what your looking for, look at your amp, example: 1000w speaker running on 50w amp = not good.
Jul 05, 2016 | KLH Audio Players & Recorders
What is the subwoofer ohm on klh asw10-120b
Good question. prob 4 ohms cause it's a small coil, but that's not always a good indicator. Best bet is to call KLH.
Customer Support: 818-767-2843
Dec 21, 2014 | Audio Players & Recorders
I have a klh 116615p bg11 12 sub and need to know the watagew it doesnt say
This woofer was taken from a KLH Pro-71 Series. These were the top of the KLH line from ~94-99 when it was still a real company and not just a name. The woofer is rated for 5-350 watts at 8 ohms. Source: KLH Pro Series-71 Spec Sheet.
Apr 06, 2011 | KLH Audio Players & Recorders
How many ohms is the klh model 42 speaker
Dec 27, 2010 | Audio Players & Recorders
My speaker just rip.. i like to know any subwoofer is ok for replace??
it's an 8 ohm driver. It need to be VERY efficient, around 90-91db @ 1w. Measure the enclosure size LxWxH then divide by 1728. That will give you your cu. ft. internal airspace of the box. Then look for a driver that will effectively work in that space. Shouldn't be too expensive, paper cone, foam surround, 8ohm impedance. Hope this helps
Dec 12, 2009 | KLH ASW10-120 Subwoofer
Model KLH KL-2400 Reciever keeps popping fuses. Resistor in power input ckt is color coded YellowVioletYellow Gold for 470 Ohms 5% Tol. However this resistor reads 370 Ohms. Resistor needs replacement?...
470.000 ohms not 470 ohms 470k ohms at 5% tol. either the main p.s. diodes are shorted or the output and driver transtors are shorted causeing the fuse to blow....
Nov 17, 2009 | KLH KL2400 Tuner
First of all a resistor color coding of Yel-Vio-Yel is 470Kohms not 470ohms. You are probably reading some stray voltage in the circuit. Yes, both NEG terminals of the speakers are common. Usually a receiver that blows the main fuse has a power suplpy problem. Check the recifier diodes for shorts. Other than that, the output transistors may be shorted.
Check those out and post the results.
Dan
Nov 17, 2009 | KLH Audio Players & Recorders
Can't find specs/maker of klh 900b tweeter
KLH 900B tweeter specifications: 6 ohm, 40 watts. By the way, KLH's QC for speakers could be improved. One of my 900B tweeters quit because the spacing for the voice coil was way off reasonable tolerance and the body of the speaker coil base pillar (ie: magnitized part) was off-center - and cauesd the coil to ware and short. I contacted KLH but they did not respond.
Sep 19, 2009 | KLH 900B Main / Stereo Speaker
KLH Rave-12 speakers - some drivers are not working
If you place an ohm meter across the capacitors, the ohms should slowly drop as the capacitor charges. You can check continuity of the coils with continuity function of the multi tester.
Madisound.com is a good source for quality components.
Aug 16, 2009 | KLH Rave-12 Main / Stereo Speaker
158 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
