Question about Garmin nuvi 200W GPS Receiver
How do i add favourites to my garmin 2545 - Garmin nuvi 200W GPS Receiver
My device will not switch on I have been charging it all day. The charger is working
Under the circumstances iterated, your Garmin has gone to GP heaven. Repair is not cost effective with those things.
Dec 27, 2015 | Garmin Nuvi Nuvi 2595 2585TV 2545 2515...
How do I record a favourite place in my Garmin nuvi 2545?
Page 16 of the owner's manual: Saving Locations
http://static.garmincdn.com/pumac/nuvi_2405_2505_series_OM.pdf
Feb 26, 2015 | Garmin GPS
How do I delete items from recently found? How do
When you want to add a place to your favourites
  • Press WHERE TO
  • Enter the address
  • Instead of pressing GO press SAVE at the bottom of the screen or press VIEW MAP and then SAVE
It will be saved to your favourites folder and the keyboard will come up for you to give it a name.
You don't delete items from recently found. A certain number of items are kept there and overwritten as new ones replace older ones.
Jun 17, 2011 | Garmin nuvi 255W GPS Receiver
How to write adress to Favorite in GPS Garmin nuvi 265 WT
  1. Press WHERE TO and type in the address
  2. Instead of pressing GO press SAVE which will be at the bottom of the screen
This will save the address to Favourites and give you an optoin to give it a name.
If you're at an address and you want to add it to favourites press the car on the map screen.
You'll get a message asking do you want to save your current location. Select YES and it will be saved to favourites.
Nov 21, 2010 | Garmin nuvi 265WT Car GPS Receiver
How to add a n address to favorites??
  1. Go to the screen that says WHERE TO and VIEW MAP
  2. Press WHERE TO and enter the address.
  3. Instead of pressing GO look at the bottom of the screen and you'll see a button that says SAVE
  4. Press SAVE and it will be saved to your favourites. You'll then get an option to give it a name. Type in something that you'll recognise again.
Alternatively if you drive to a location and you want to save it to favourites you can press the car icon which shows your location on the map and it will give you an option to save it.
Occasionally when you save a location the satnav gives it a default name. You can change this by going to Favourites.
  1. Press the name of the place saved
  2. Instead of pressing GO look at the bottom of the screen and you'll see an option to EDIT.
  3. Select EDIT and you can change the name to something you'll recognise.
Oct 23, 2010 | Garmin GPS
How do i add an address to favorites?
When you press WHERE TO and enter an address you want to go to instead of pressing GO press SAVE, on the bottom of the screen. The location will then be saved in favourites and you will get an option to name it. Also when you're driving if you come to a location you want to save press the car on the map screen. You will be asked "Do you want to save your current location" Press YES and it will be saved to favourites.
Sep 13, 2010 | Garmin GPS
I have a Garmin Nuvi 205W and have saved a number of places as favourites. However, when I want to share the location with friends by giving them the map coordinates of these places I cannot find how to...
To view the coordinates of a saved location on your nuvi
  1. Touch Tools (wrench icon)
  2. Touch Settings
  3. Touch System
  4. Turn ON the GPS Simulator
  5. Touch OK
  6. Hold Back to return to the main menu
  7. Touch Where To?
  8. Touch Favorites
  9. Select a favorite location
  10. Touch Show Map
  11. Touch Set Location
  12. Hold Back to return to the main menu
  13. Touch Tools1
  14. Select Where Am I
Here you will see the coordinates for the saved location.
1. For nuvi 200 series units that do not have the Where Am I feature, skip the above steps 13-14. The coordinates can be found by pressing the vehicle icon on the View Map page.
Instructions on Backing up and restoring Favourites can be found at
http://www.garmin.com/garmin/cms/cache/offonce/us/support/searchsupport;jsessionid=72CF55C22FEF1BA5AA08FFCAC89B9E59
Aug 12, 2010 | Garmin nuvi 205W GPS Receiver
Free updates or downloads for a garmin streetpilot c330
There are no free map updates for the StreetPilot Series.
The newer models do come with a free update that must be downloaded within 60 days of purchasing the system.
There are utilities for adding POI (Points of Interest) as well as Browser plugins that can be used to add Favourite Locations from Google maps. these updates are available from the garmin website.
Dec 08, 2008 | Garmin StreetPilot C330 GPS Receiver
How to transfer garmin nuvi 250 favourites to sd card
take the CD card out of the Nuvi and mount it onto your PC in a separate drive (via card reader or something similar).
Connect the Nuvi to your PC and copy "/garmin/gpx/current.gpx" from the GPS drive to the drive with your CD card.
Should you ever want to load these onto a new GPS, just add that same file to the corresponding folder on your new Nuvi.
Aug 02, 2008 | Garmin GPS
Garmin nuvi 200W GPS Receiver Logo
114 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
