Question about Dell W3201C 32 in. LCD Television
I have a Dell 32" LCD flat screen TV about 4 years old. After the tv is on for about an hour, it gets horizontal lines that go faster and faster and then vertical lines appear too. If you turn it off for awhile, it is okay again. But, after about another hour..same thing.
Please do not operate the same this is due to the sync separator problem which needs an mechanic or service center services . if you continue then the problem will cause a damage to the screen .
either the ic needs to be changed or some small condenser or a loose or dry solder connection.but remember not to open it your self and repair . pl send it to service center and let them handle the same.
Posted on Jan 22, 2009
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
Lexsor 32" widescreen LCD TV
sounds like av panel needs replacing................
cheers
Mar 26, 2011 | Televison & Video
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
Jul 08, 2010 | Samsung LE32A457 32 in. LCD TV
Lcd tv has black cloudy line from top of screen about 1 inch wide and 4-5 inch long down the screen
This problem is not just for Philips. I've found similar complaints online for JVC, and my Vizio 32" LCD has the same problem. In my case the TV is about 3 years old and has a lot of hours on it.
Oct 23, 2009 | Philips Televison & Video
Horizontal line at top of screen in any hd format with componet or hdmi. model is sv470m. the tv isn't even a week old.
Get into the TV menu and locate the H (Horizontal) and V (Vertical) picture options. . .increase the V until line at the top is gone.
Oct 20, 2009 | Vizio SV470M LCD TV
4-year old Dell 32
I can fix your tv for you. I am in Glen Cove, NY. email me at masterhu (at) yahoo (dot) com.
Jan 22, 2009 | Televison & Video
HORIZZONTAL LINES ON FUNAI LCD TV
HI,THERE ARE BAD CONTACS ON THE SCREEN DRIVER RIBBON WIRES,ITS A JOB TO GET TO THEM,AS YOU ALMOST HAVE TO REMOVE THE WHOLE SCREEN PANEL,TO SEE THEM,A JOB FOR A TV TEC IF YOU ARE NOT SURE!! THANKS
Jan 02, 2009 | Dell W2606C 26 in. HD-Ready LCD Television
Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Jul 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Dell W3201C 32 in. LCD Television Logo
100 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
