Question about D-Link DCS-950 Network Camera
I can't see the video serch and playback
Hi:
I can't see the video serch and play back part in my sistem, if you press that option emidiatly apear a pause that desapear when you press the pause button that is in de raigth side, what can i do?
I dont have the cd to down lodas for my cam how can i get my cam to work
Posted on Jan 22, 2009
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
Can't play back videos on my experna; memory card Sandisk class 4 8Gb. Have a canon Vixia HFR10 camcorder
Okay, ours is a different brand (JVC) but they may have some basic similarities in function. To playback video clips stored on the memory card, put the memory card in the card reader slot of the computer and put the files onto the computer. Playback the clips from your computer video or photo file. (Ours won't playback video stored on the memory card through the camera.)
To playback video clips stored on the camera hard drive through the camera, we open the viewer screen, look at the function keys on the camera body, select the "Play" button. On the screen it displays thumbnails of the various video clips. We use the toggle/function key to select from the menu containing options for playback, edit, delete, protect, etc.
May 16, 2011 | Canon Vixia HFR10 Silver Dual Flash Memory...
Hi.i have a really important question and im hoping you can help me.everytime i try to review my videos on my camera it says(video management file is broken to record/playback video,recovery is...
Select "OK" to restore. (Videos that cannot be restored will not be displayed on the index screen, but you may be able to play them back using "PLAYBACK MPG FILE" in the menu.
if the file is damaged....
Select the playback mode.Select video mode.Touch to display the menu.Select "PLAYBACK MPG FILE" and touch.Select the desired video and touc.
May 12, 2017 | JVC GZMS230 Camcorder (Black)
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
No playback on camera
Whenever you want to playback your videos, you should be in recording mode.
Press the play mode button and select the video that you want to play and then press the play/ pause button on the bottom part of the menu/ ok button.
Dec 29, 2007 | Samsung Digimax S730 Digital Camera
No Sound
The camcorder may be in what may be called "narration mode." This function mutes the playback audio so you can narrate with you own voice when playing tapes back. Check for a function like this in the playback sound menu.
Nov 06, 2007 | Panasonic NV-DS60 Mini DV Digital...
No sound when playing back video
I had the same problem. Try this: open the LCD screen so that you can access the playback buttons.Make sure camera is in playback mode. Press the "menu" button. Select "narration" . Switch narration to "off" .Now you should hear the recorded audio when your tape is playing.
Jan 03, 2007 | JVC GR-D250 Mini DV Digital Camcorder
D-Link DCS-950 Network Camera Logo
91 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
