Question about Panasonic Viera TH-42PX80U Plasma TV
Every 10 minutes my Panasonic plasma 720p turns mute
A message appears like this:Now in picture refresh mode now going to reset
  • 4 more comments
  • jklee Jan 30, 2009
    I have the TH-50PZ 800 U and have the same problem! It won't stay on the station I have it on for more than 10 min! It goes back to an original channel setting!
  • Anonymous Feb 06, 2009
    Same message on mine!
  • HEFFPART Feb 08, 2009
    i HAVE SAME PROBLEM. I don't want to see the refresh message every 3 min. Can this be turned off??
    heffpart@aol.com
  • Naragj Feb 09, 2009
    Same here just bought my TV yesterday it refreshes and resets my sleep settings.
  • Anonymous Feb 10, 2009
    WILL THIS SOLUTION SOLVE THE REFRESH MESSAGE EVERY 3 MINUTES? OR GIVE YOU THE ABILITY TO STOP IT?
  • HEFFPART Feb 10, 2009
The problem is it is locked in store mode. I had to call panasonic to fix it, this is what they had me do.
1 hold the volume down on the tv while holding the menu button on the controller.
2 after the screen changes to the check menu, hold the off switch on the tv untill it turns off.
3 unplug the tv for 30 sec.
4 plug it back in and turn on the set.
5 select home option
6 your done.
Posted on Feb 17, 2009
From the instruction manual - if store mode is selected:
• Unplug the TV and plug it again.
•  Press and hold down the front POWER button.
You will be prompted to chose between STORE and HOME mode... select HOME.
The other suggested solution did not work for me.
Posted on Feb 15, 2009
I stumbled onto the answer from another post, the tv was set to STORE and not HOME since i bought the floor model, to reset the tv to change to home
1. Hold down the volume button on the TV
2. Hold down the OK button on the remote
3. After a few seconds your TV will reset and show a reset menu thingy
4.Unplug your TV for one minute at this time
5. When you plug it back in it gives you the option to set your tv to HOME and basically lead you thru the initial setup process
Posted on Feb 10, 2009
The above solution worked for my panasonic plasma also, different model but still worked.
Posted on Feb 11, 2009
Explain the flashing red lights for Panasonic plasma tv repair. what if I have no lights and no picture or sound
Panasonic Customer Phone Number Shortest Wait Best Support
800-211-7262
CALL CUSTOMER SERVICE AT THE PHONE NUMBER ABOVE.
  • Average Wait: 8 mins - Mon-Sat 8:00 AM - 9:00 PM EST Sun 12:00 AM - 5:00 PM EST
YOU MIGHT ALSO CHECK THIS VIDEO OUT:
Nov 17, 2014 | Panasonic TC-P42C2 Plasma TV, 41.6 -...
The volume in my tv dont work
Try setting back to factory default
Power off tv
Unplug power cord to wall
wait approx 10 minutes
Plug cord back in
power on tv main menu will appear follow on on-screen instructions to reprogram.
Apr 13, 2013 | Panasonic Tc-p50c2 50-inch 720p Plasma...
My volume on my 50plasma tv
Power off tv
Plug cord back in
Panasonic plasma panasonic th-p42x10a green led on but tv takes long time for picture to appear
check for swolon capacitor in power supply or try to go in service mode and reset tv by pressing vol_ on tv and press recall button continious from remote tv will go to service mode then press vol_ on tv and ok from remote hold ok untill tv reset then unplug and turn on again.
Mar 06, 2012 | Panasonic TH Televison & Video
Panasonic Viera keeps going into picture refresh mode. How can I stop this?
The tv is on "store" rather than "home" setting. If the message "going to refresh mode" keeps appearing every 5-10 minutes, do the following:
-Unplug TV from wall and leave it for about a minute.
-Plug TV back in and follow "initial setup instructions" (can be found on page 14 of manual).
You will be given the choice of "home" or "store" settings. Change it from "store" to "home".
-Done.
Aug 20, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Pansonic th-42pz80u hdtv
I had the same problem.  The TV is in store mode.  Unplug it for a few minutes, then plug it back in and select Home mode.
Nov 10, 2008 | Panasonic PT-40LC12 40" Rear Projection...
I GOT A PANASONIC PLASMA TV 2 DAYS AGO..SINCE THEN EVERY 5 MINS A MESSAGE SHOWS UP ON THE MIDDLE OF THE SCREEN SAYING: "NOW IN PICTURE REFRESH MODE. GOING TO RESET SETTING" HOW CAN I FIX THIS...
  • If TV doesn't power up, use remote power on while holding down the button on the set
  • You will be prompted to chose between STORE and HOME mode... select HOME
You should be good to go.
Jul 09, 2008 | Televison & Video
Picture Refresh Problem
Used Panasonic Concierge Chat and they had me do this:
press volume down on the TV (not the remote) and then press menu on the remote for 10-15 seconds to bring up a check screen. After that, unplugged TV for one minute. Plug TV back in and set up for Home. Can exit out of the rest of the set up. So far so good......this was happening only periodically for me, so we will have to see if it works. I was also having to go to TV Video and select Component 1 (cable for me) every time I turned on the TV, but the above action fixed that. Now it goes to the input that was on when the tv was last turned off. Concierge is free. Very cool.
Jun 09, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Keeps going to refresh mode
This is the Panasonic Customer Service Answer:
you need to reset the unit to get it out of store mode sir
make sure the unit is on and we are not in any menu screens
press and hold the volume down button on the front panel
and ok on the remote at the same time until the words self check appears on the front of the screen
once self check is displayed unplug the unit from the wall for one minute
after one minute plug the unit back in and it will go back through first time setup
make sure you pick the home mode
Apr 19, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic Viera TH-42PX80U Plasma TV Logo
1,774 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
