Question about Whirlpool WED5600XW Dryer
Show how to take apart wed5600xw dryer - Whirlpool WED5600XW Dryer
Tip
My dryer drum will not turn...."how to change your dryer belt"
There are many styles and different models of dryers but the one thing they all have in common is the dryer has a belt that turns the drum.In the procedure below we will show you how to take apart your dryer,change your belt,and show you the correct threading of your belt. Here is a typical Kenmore dryer idler pulley(it has a plastic wheel on it) motor/pulley (the pulley is attached to the backside of the motor) and the belt configuration.Note the picture below.
Each different model dryer also has a different lint trap location. This location will have a bearing on how your dryer is taken apart and how to change your belt.
Note the location of your lint trap and choose the correct video on how to take your dryer apart. There are two different locations,on top,and in the door.
This video will show you how to take apart your dryer and change your belt if the lint trap is on top of your dryerhttp://www.youtube.com/watch?v=CFnXwmUb4f4
lint trap on top
This video will show you how to take apart your dryer and change your belt if the lint trap is inside of your door. http://www.youtube.com/watch?v=rtATa0a28bE
lint trap in door
This video will show you how to take your dryer apart and change your belt with the control panel in the front side panel rhttp://www.youtube.com/watch?v=zpUqCrLaI7g
control panel in front
This video will show you how to take apart your Maytag L shaped dryer and change your belt.
http://www.repairclinic.com/PartDetail/Belt-Drive/1246110?modelNumber=LDE8424ACE#repairHelpVideoTabs
L shaped dryer
If you happen to run into an issue with your belt and pulley configuration all the diagrams are here click on the linkhttp://www.repairclinic.com/Dryer-Belt-Diagrams
If this has helped you please consider giving us a 4 thumbs up on our rating.This procedure has saved you a minimum of $125.00
Thanks in Advance and Thank You for using Fixya!
on Mar 21, 2011 | Dryers
How do I take apart admiral dryer model ade7005ayw
You can use Google search your model numbers an it show you a video on how to take your dryer apart the right way .
Mar 03, 2015 | Admiral Dryers
WED5600XW whirlpool dryers not starting
Hello Moezz;
My name is Peter. I am a retired field service appliance technical.
Unplug the dryer prior to the start of any work!
There are three areas that you need to check.
1.) Door Switch.
Open the dryer front door. In the upper left is a small pin that sticks out. Push the pin. Do you hear a click? If not you have a bad door switch. You need to remove the top cover to access the door switch. Having accessed the switch, remove the two contact wires. With a multi-meter set to the lowest ohms, put one meter lead on each contact, while pressing the switch in, the meter should read '0' if it is good. If you do not have a meter, join the two wire leads together and start the dryer. If it starts you have a bad switch.
Part number W10411936 - $22.00
2.) Poor Air Flow
If you do not have good air flow the dryer will not start. On the back of your dryer is a hot air distribution manifold. It is held on with several screws. Remove these screws. Inspect the lower connection and check the blower wheel for obstructions.
3.) Thermal cut-off fuse.
On your burner funnel there is a fuse. You will need to remove the dryer front panel to access. You need to Ohm it out as described above.
4.) Motor Pulley Start Switch.
On the end of your motor is a pulley. There is a lever arm switch that contacts the belt when you start the dryer. Move the lever arm. Do you hear a click? if not your have a bad starter switch.
Nov 30, 2014 | Dryers
Quiet wash 1 doesn't drain
the pump could be siezed or blocked. burnt rubber smell from the drive belt. look under the machine and try to turn the pump pulley
Apr 17, 2014 | Whirlpool WED5600XW - 27", 7.4 Cu Ft, He...
How to replace all parts of front panel
If you go to http://www.repairclinic.com you will save yourself TONS of time and hassle. I took my dryer apart three times. When the pro finally showed up all he could say was, "How did you get the dryer apart like this. I have never seen this happen. Where do you work?" As my girlfriend was in the corner shaking her head. It was a good day.
Feb 08, 2013 | General Electric DBSR463EGWW Dryer
Need diagram of belt installation for dryer DV218AEW
Hi mcpitts...
Click on the link to find your model number link http://www.repairclinic.com/Appliance-Parts
Here is the process for taking your dryer apart mentioned above.
You will need to decide which video fits your machine appearance.
Please take time to rate me
Aug 10, 2011 | Samsung DV218AEW Electric Dryer
Idler pulley is loose
See this link:
http://repair2000.com/wpoolbelt.htm
This should show you how to route the belt for your Whirlpool dryer.
Also - here is a short pic:
May 21, 2010 | Whirlpool LER5636P Electric Dryer
I need help putting my dryer back together
Here is a couple of websites that shows the breakdown and parts of dryers, maybe they will have your model to help show where the two springs go.
http://www.appliancepartspros.com/index.aspx
You could also try this website.
http://www.partselect.com/
Good luck,
I hope this helps
Oct 06, 2009 | Kenmore 67082 Electric Dryer
Whirlpool WED5600XW Dryer Logo
49 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
