Question about Nintendo DS Console
I get a blank white screen when loading the ds lite with ttcard
I put the games on the micro sd card and put it into the tt card and insert it into the ds lite. turn the power on and all we get is a blank white screen. we then continue to turn power on and off until it finally loads and sometimes it will just go off in the middle of a game. We just recently got the tt card so I am hoping it is sometime we are doing and not a faulty card. please help me if you can.
thanks
  • 1 more comment
  • deb1947 Jan 22, 2009
    I use the usb to put the games onto the micro sd card. Do you mean insert the usb with the micro sd card in it and then backup the card to the computer and then right click etc as stated by you.
    thanks
  • Anonymous Mar 02, 2009
    every time i turn on my dstt it turns white screen and i have to turn it off and on to make it work
  • linfei Apr 17, 2009
    that's exactly what i did but it is still just white screens that i see. after playing crono trigger once after 10min the game just froze and ever since all i get is a white screen when starting the tt. what shall i do, no formating helped
  • 132 Answers
Backup the card to your computer, then right click the memory card in my computer and go to properties then click format and when its done copy everything back onto it and you should be all set!
Posted on Jan 22, 2009
  • Derek Powers
    Derek Powers Jan 22, 2009
    Yes that is exactly what i meant, hope you figured it out!
My ds freezes when loading the R4, or it says that there is no game in the ds slot
Stuck on Loading Screen This usually indicates that the software kernel on the micro sd memory card has become corrupted. It can also happen if the micro sd memory card is overloaded with games, music and video files etc. The solution is to reinstall the kernel software on the micro sd card and ensure the micro sd memory card is not overloaded. Leave about 25% memory free.
download SDformatter and format the sd card with that, place all the files on there, none in folders..
  • Download the correct software kernel from the manufacturers website
  • Unzip the files using a suitable programme such as Win Zip or 7 Zip.
  • Open the folder containing the unzipped files and copy the 4 files (Moonmemo, Moonshl2, R4iMenu and R4.dat) to the root of the memory card.
  • At this point put the memory card into your R4 card. Start your console and ensure the R4 card is operating correctly.
  • You may have to run an upgrade file at this point
Mar 24, 2014 | Nintendo DS Lite Console
New R4 card wont work !!!!
First make sure you have the correct kernel for the card. Go to the website where you purchased it and download the current firmware. Next copy all of that onto the micro sd card. Build folders in you sd card, very simple right click...new folder... enter... then label them correctly .. Label one movies... music... games.. etc... then put your files into the correct folders.. Another common error is that people use to high of a sd card.... some r4 cards only accept up to a 2gb micro card If you use one that is too big it will stick on the loading screen ... If none of this works reload all the software onto the card and start from scratch... hope this helps
Jan 05, 2010 | Nintendo DS Lite Console
My micro sd card doesnt work
probably your memory card has had it...if it will let you reformat it, re-install flash card drivers and chuck a few games on and see what happens...also check inside card slot and make sure all the contact pins look nice and straight. if you can also just try a new memory card in the meantime to put your mind at rest concerning the problem coming from the ds...highly unlikely.
Aug 02, 2009 | Nintendo DS Lite Console
My son got a NDSTT and played games on it for a week, now all it says is MENU? on the top screen of his DS - how do i fix it?
What i would suggest is to take the micro sd card and delete the menu folder and the menutt.dat and anything else associated with the main menu settings. Drag and drop the games folder or games and saves to the desktop and then format the sd card in FAT32.
I appreciate this may seem a little extreme but i have had quite a lot of experience with NDS flash cartridges and the problem you describe usually happens when the menu.tt file becomes corrupt.
Once the sd card is formatted, re install all the nesessary software (you should have these 3 files on the sd card :
TTmenu folder
ttmenu.dat
ttmenu.sys
but, DO NOT put any games onto it until you have placed it into the nds and turned it on allowing the TTcard to build a menu for the games to be loaded from.
Hope this helps
Jun 04, 2009 | Nintendo DS Lite Console
R4 cart not loading
instead of copying and paste send the files to the micro sd thats what i do no problems at all
May 22, 2009 | Nintendo DS Lite Console
TROUBLE WITH NDSTT CARD AND A BLANK WHITE SCREEN
http://ca.youtube.com/watch?v=ojzZeO2RAkc watch this video for instructions on how to repair.
Jan 22, 2009 | Nintendo DS Console
NDS TT
have u ever tryed blowing in it or get a q tip and dust it out that may happen every 2-3months if u leave it alone the dust will get in it and it wont read the card
Oct 26, 2008 | Nintendo DS Lite Console
Nintendo DS Console Logo
1,149 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
