Question about Kenmore Dryers
Model # 110.86562500
Need directions to switch dryer door from left to right side
  • 619 Answers
SOURCE: Kenmore MT0305342 electric dryer, currently
Hi , it can be transfer to left side , as long having design holes nut attached to screw the door.
Posted on Jan 25, 2008
SOURCE: Need to change door from left hand to right hand open on kenmore HE2
I am looking for the same answer on the washer. You can definitly change the dryer. The holes are on the other side under black tape.
Posted on Jun 26, 2008
j_del
  • 1586 Answers
SOURCE: When I switch the left
Sounds like a blown turn signal bulb. Park the car with the engine running and the left signal activated, and see if either of the bulbs are flashing. If only one of them is, then change the other. If neither is flashing, you may have a blown fuse. If that isn't it, I'd suspect that the switch itself, inside the column, is bad.
Posted on Jul 21, 2008
tzweeb
  • 318 Answers
SOURCE: Can you switch the side the doors open and close.
sorry but the washer can not be changed. its strike has a lock and can not be reversed. the dryer can be changed, but the best thing to do is move the units and get some longer hoses for the washer.
hopefully you can switch the position of the units, but if not then you will be doing the laundry dance every time you do wash.
Posted on Jan 31, 2009
Maytag317
  • 1136 Answers
SOURCE: i want to switch the doors from left to the right side
Hi, The parts are interchangeable (hinges & handles)
You should have some small plastic plugs/caps that are covering the holes already drilled for the change. Once you remove the doors and then remove the plugs, just reinsert the plugs into the old holes and switch hinges and door handles to the opposite spots.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
Posted on May 26, 2009
Want to switch the side the door opens on my lg dryer
The directions for reversing the door can be found on page 13 and 14, with pictures of the operation. Open the door to reverse. Check the 10 screws that need to be removed (6 on the left, 4 on the right). Remove 4 dummy screws with a screwdriver. Remove the two screws from, and disassemble, the latch. Hold on to the hinge while removing 4 screws from the hinge (to prevent the door from dropping). Remove the door from the cabinet cover. Move the door to the left side and insert a hinge into a hinge hole. Hold on to the hinge while screwing down the hinge (to prevent the door from dropping). Insert the latch to the right side and install the screws. Screw down the 4 dummy screws to the right side. Check that the door closes and latches properly.
Feb 02, 2013 | LG SteamDryer 7.3 Cu. Ft....
Dryer does not stop when you open door
The door switch is sticking. Door switch is around the door opening and is located where the door would push it in when the door is closed. It may just need cleaning or putting back in its rightful place or it may be broken and need replacing.
More info, let me know.
Charlie
Mar 30, 2011 | Whirlpool LER8648L Electric Dryer
How do you replace a belt on model 11060622990
Unplug the dryer.
Remove the lint filter.
Remove the 2 screws at the lint filter opening.
Use a putty knife between the top lid and the front panel to release the clips.
They are about 2 inches in from right and left sides where the top meets the front panel.
Lift the lid towards the rear of the dryer.
Look inside the top right and left corners of the front panel and remove the screws holding the front to the cabinet. Remove the door switch wires and set the door aside.
Place the new belt over the drum,ribbed side towards the drum.
Look under the drum for the belt tensioner. It is S shaped with a wheel on it.
Place the base of the tensioner in the slots below the motor pulley.
Feed the right side of the belt through the opening under the wheel with the smooth side of the belt touching the wheel.
Place this side of the belt over the motor pulley with the ribbed side touching the pulley.
Replace the front panel.
Hook up the door switch wires.
Replace the panel screws.
Reattach the top lid and lint filter screws. Replace the lint filter.
Plug in the dryer.
Jan 03, 2010 | Kenmore Dryers
Dryer won't heat. I need to check the thermal
need model number,if filter is on top,pull it out and take out two screws.get staight blade screw driver and put it in seam between the top of dryer and the cabinet and pop up on left and right side,{there are two clips holding the top on,one on the right the other on left side}, unplug door switch wires on right side and you'll see two 5/16 screws one on left and other on right around 4 inches down from the door switch,now grab top of front panel and pull up,there are two clips on bottom of cabinet that panel clips into,you'll see the fuse on the top of blower wheel housing,the fuse could also be located in the back of dryer too that's why you should send model number,hope this helps,while your in the dryer see if it needs to be cleaned out,that's what usually pops the fuse,check the lint filter duct,vac the inside of dryer and blow out the vent line,make sure the flapper is blowing open outside
Nov 07, 2009 | Dryers
My dryer does not heat up. I need to take panel off in order to replace. How do i do that?
Nov 04, 2009 | Kenmore Dryers
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drier Belt Replacement on GE model DDG7580
Open the door and remove four screws which go into the dryer top. Swing top back. Take out the screw on each side holding the dryer front to the side panels near the open top. Tilt the dryer front forward and lift it off the bottom pegs, then swing it to the side. Leave door switch wires connected. Lift up slightly on drum to allow the belt to be placed around drum. (grooves of WE12X82 belt touch the drum) Belt goes down from the left side of the dryer directly to the grooved motor pulley, then around the belt tensioning pulley and back to the drum. Your model has a removable panel at the bottom side of the back which will allow easy access to the motor pulley area.
Nov 10, 2008 | GE DVL223GB Gas Dryer
Zanussi ZDC67550 Dryer, door swing change?
Hi
just reversed the doors in 15-20 mins. It worked for me. You do need to be a competent DIYer to do this.
If in doubt, do now't. Get in an engineer
Disconnect from mains (obviously)
Remove top using 7mm nut driver/spanner
Remove 2 cross-head screws holding the door - Door will come away from dryer.
Remove 2 cross-head screws holding the white top and bottom blanking plates
pull out the switch blanking plate
Locate the PINK wires connecting the switch/latch mechanism inside the dryer at the top. This will be taped to a blue wire.
Unscrew the 2 smaller cross-head screws holding the latch/switch assembly whilst holding the pink wire to stop the mechanism dropping inside the dryer.
Pull up the latch mechanism and unravel the black tape holding it to the blue wire.
Drop the latch assembly down the lefthand side of the dryer and refit using the 2 small cross-head screws.
Retape to the blue wier and feed the PINK wires through the plastic retainers.
Fit the white blanking plates to the RIGHT handside of the door opening.
Swap the hinges and the switch latch on the door (don't lose the spring !!!, refitting the hinge blanking plates(ease these out with a small flathead screwdriver covered witha bit of insulating tape to avoid damage.)
Fit the door using the 2 cross-head screws you have left
Refit the top.
Connect to the mains and switch on to the sound of £80 you have just saved yourself !!
Electricity kills Be careful
Oct 03, 2007 | Whirlpool GEW9250P Electric Dryer
Dryers Logo
43 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
