Question about Aiwa CDC-X227 CD Player
Car cd player skips on bumps
I have a 2003 Pontiac Vibe with the factory installed CD player. It recently has started skipping. It happens to several different CDs which is why I think it's the player that's the problem. It skips even on the tiniest bumps in the road. VERY ANNOYING!!
Anyone out there had the same problem and been able to fix it? I'd really like to avoid having to buy a new CD player : (
  • ktsport777 Jan 22, 2009
    Thought I would add, that the skipping only happens when I hit bumps, in case that wasn't clear.
    Thank you! Your suggestions are greatly appreciated!!
    I will probably be waiting for some warmer weather to take a look at what you mentioned, but in the mean time I'll try one of those CD cleaning kits, and maybe, just maybe i'll get lucky and that will fix it.
    President:
  • 624 Answers
This can happen for several different reasons.
1. The dampers (oil filled shock absorbers) are leaking and need to be replaced. You can check this by taking the unit out and opening it up and then remove the CD deck. In each corner of the CD deck you will see a small rubber looking device that the internal mech floats on when a disc is engaged. It is attached to the internal mech by only a small metal peg. Check each corner for these. Make sure they are not leaking anything. It is usually a white looking substance that feels like grease. Ant time even one of them go bad or get popped out of place, it will skip on every bump.
2. Try cleaning the lens. Sometimes a dirty lens will make the CD player skip much easier than it is supposed skip. You can buy a cleaning disc at most retail outlets that sell CD and DVD players. Run it as directed in the instructions.
3. one or more springs are streched out a little. These mechs have many springs in them and if one is a little streched it will cause skipping. If you find a loose spring, it will need to be replaced.
4. Weak laser output. A weak laser will also cause a unit to skip. If this is the case the laser pick up will need to be replaced. There is no fix for a weak laser other than replacing it.
5. Spindle motor problems. A spindle motor with even a tiny bit of oxidation in the windings can cause skipping when you hit a bump.
There are also a few other things that can cause this same issue. It is not an easy thing to fix without some training on this type of equipment.
Is this an "Aiwa"  or is this a factory unit that cmae with the car when it was brand new. I don't think that Aiwa is an OEM radio, but I could be wrong. I fix aftermarket radios only.  So I am not real familiar with all the OEM models.
If this is an aftermarket Aiwa radio, you should take it to a service center to get an estimate. If it is an OEM radio, it is most likely going to be very expensive to fix and a good aftermarket radio would really serve you better.
I am sorry if this is not the answer you were hoping to get, but it is the truth so I hope you will not punish the messanger for bringing bad news.
Anything less than a "helpful" rating is a very bad rating meaning that you got no help or that the help was not related to the problem. I spent a lot of time putting this information out here for you for free, so I only ask that I get a decent rating for my trouble.
If you require any more help feel free to post another comment on this thread with any questions you may have. I will be happy to answer them for you.
Dave
Posted on Jan 22, 2009
Cd player skips
CD disk bad. (audio disc bad or scratched)
or CD dont really support disk media format , is this a CDDA or MP3
some early MP3 disc drives do MP3 very poorly
or skips when you hit bumps in the road.
only that disc skips.?
Dec 23, 2013 | 2005 Toyota Sienna LE
CD skipping
That's normal in most cars!
Jan 22, 2013 | Mazda RX-8 Cars & Trucks
Why does the CD skip and the radio channels go off air when I hit a bump?
CD skip when hitting a bump is common in factory or low end players also if your player is not secured properly the disc will move slightly and the laser loses it's place, so to speak, for a second. The radio thing could be a loose antenna wire connection, possibly related to the fore mentioned problem. Hope that was helpful.
Sep 17, 2012 | 2012 Jeep Patriot Sport 4dr SUV 2.0L...
Delco factory Radio/CD player,it gives an err msg.and ejects CD
The laser in the cd player may be dirty or has gone bad and can no longer read the disc.
Apr 17, 2010 | 1998 Chevrolet S-10 Pickup
3 disc Phillips cd player sometimes skips. It is
At some time in its life, the laser that reads the CD starts to get too weak to operate reliably. That's probably what's happening here. Unlike mechanical parts that can be inspected for wear, electronic parts tend to work fine one day, then the next, poof. The laser assembly is replaceable if you can locate the part and find someone to install it. An electronic service shop could give an estimate for repair. If you can provide the full model number, I'll see if I can find the part number.
Mar 08, 2010 | Teac AD-600 3-Disc CD Changer
Skipping
If you go out and buy a cleaning disc it may help. You should really clean a car cd player at least ounce or twice every 6 months to get the best sound and play out of the unit. You can pick these disc up at any walmart , kmart , or computer store. Hopefully this can help you out
Dec 18, 2007 | Kenwood KDC-MP228 CD Player
JVC KD-SH99 Skipping
try cleaning the lazer lens, also remember it is old and is most likly toast., the longest I ever owned a deck that didnt go out was 4 years.
Nov 12, 2007 | JVC KD-SH99 CD Player
Car cd player kipping
Is it anti-skip resistance? If not some players have hard problems playing when heavy bumps. Also is it installed correctly? Was all shipping plugs taken out?
Sep 10, 2007 | Aiwa CDC-X227 CD Player
CD's are skipping
try cleaning the laser diode with an alcohol-soaked swab. be careful not to use too much alcohol or to press too hard against the diode lens.
May 30, 2007 | Sony CDX-F5710 CD Player
Aiwa CDC-X227 CD Player Logo
3,268 people viewed this question
Top Aiwa Car Audio & Video Experts
Greg Cann
Greg Cann
fordexpert
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
