Question about DLX 500 Remote Car Starter
The unit just ticks when plugged in.
I think i have all the wires hooked up right but the unit just ticks when plugged in.
  • 95 Answers
Its a faulty unit. Had the same problem and brought the unit back for a new one and it worked perfectly and has ever since.
Posted on Feb 17, 2009
Oil presher guage .polarity .wires hooked right new guage new sender .sender wire off guage goes behind o its suposto peg doesnt
you need a new sending unit and stop unplugging things when there is power to them,you can ruin it
May 04, 2015 | Cars & Trucks
I am hooking up a remote start on a 99 Chevy Astro & can not find a tach wire.
Hey I'm not an expert at remote starts I've only hooked up one in my life I have two of them one in my Durango & one in my Dakota Dakota was installed by best buy & Durango was installed by pc richards I'm not positive but I think tach wires are the same color on all remote starts and mine are purple the tach wire on the Durango is hooked to the #3 fuel injector wires & the Dakota wire is hooked to the coil but the tach wire is purple look back at installation directions you might have a defective remote start unit remember I said I'm not an expert I'm just going. By what I have I really hope this helped you oh by the way the van has an automatic tranny right? Good luck
Nov 23, 2014 | 1999 Chevrolet Astro
Ticking & white smoke after replaced intake gasket
Sounds like coolant getting into the combustion chamber. Potential causes in order of significance: Intake manifold gasket (might not have been done right), Head gasket(s), cracked cylinder head, or, cracked engine block. Check the oil. If it looks like chocolate milk it means the coolant and oil are mixing
Dec 30, 2013 | 1998 Chevrolet Astro Van
Hi, i have a 2001 hyundai tiburon. im hooking up a headunit (kd-r610) i think i hooked it up right and wen i go and turn it on, it turns on for a couple seconds then shuts off. any ideas?
does your car have steering wheel controls?...if so then you might have tapped into these wires where the go into the factory radio plug. either way put a volt guage on the power wire, and turn it on and then watch for a loss or drop in voltage, if there is then trace the wire down. check for splits etc...
if the power feeding the unit is fine then it may be inside the unit.
Jan 02, 2011 | 2001 Hyundai Tiburon
The system was removed to another location and one
Yes it could. It sounds like your low voltage wires are not hooked up properly. You need to get your contractor back out there.
Joe
Sep 30, 2009 | Broan-NuTone CV353 Central Vacuum
Rca plug-in on amp came off,try to get the schematics to fix so i
just replace the whole rca unit there should not be any wires it is a plug with little pronges on the bottom
Jun 15, 2009 | AudioBahn A2300HCT Car Audio Amplifier
Have a in dash jvc kd-sx750 cds player that won't power on
if you had the speakers hooked up wrong it would just make a crackling sound when it rubs on a surface. if your vehicle has a factory built in amplifier somewhere you may have to hook up the remote turn on wire to the wiring harness to tell it to turn on.
also make sure your illumination and dimmer wire are hooked up correctly if it doesnt display any images on the screen. and if for some reason you think its shutting off because of crossed wires maybe check the ground the batt and the ignition wire ,or the red black and yellow wires. usually when something major like those three wires get crossed it blows fuses in the car taillamp fuse stereo batt fuse ect. check all those .try resetting the deck of the car battery thats all i can think of now.
May 06, 2009 | JVC KD-SX750 CD Player
Maytag De4000 Electric Dryer Wire Hookup
black and red wire, will hook to either end of terminal posts, as long as the white wire connects to the center post. the green wirewill then atach to the cabinet of the unit,( usually a green ground screw just outside the termoal box anyhow!
Apr 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
The spark igniter on my GE builtin gas cooktop will not stop ticking, I unplugged the unit from the socket and plugged it back in thinking it will reset but it did not stop ticking.
You got water/liquid in the control switch,most the time you have to replace the switch,and most cook tops require the whole string of them be changed at once.That is all the switches are tied into /pre wired together.
Jun 12, 2008 | Kitchen Ranges
DLX 500 Remote Car Starter Logo
69 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
DROPNDEAL
DROPNDEAL
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
