Question about Apple iBook Mac Notebook
My adapter won't charge my mac notebook..and the computers fan doesnt work
I forgot i left my laptop on.when i came back.i connected the adapter to the laptop and tried to turn on the copmputer.it was then i noticed that the battery icon at the top of the screen had a black "x" in it.and i also noticed that the light on the cord was green and was not changing to orange which it usually does when it starts to charge the battery.i tried looking it up and tried to follow how to troubleshoot it by removing the battery and inserting it again..i hope maybe you can give any other ideas how to troubleshoot this problem..it seems also the directions how to reboot the PMU seems complicated ..i hope you can help me...i also noticed that the fan doesn.t turn on when the laptop starts getting hot..i hope you can give me sme good advice on what to do...thank u
  • 6 more comments
  • Anonymous Dec 28, 2007
    its so annoying!
    please help someone!
  • ansy Jan 06, 2008
    I'm going thru the same thing, I have no idea what's going on with my mac.  I left it on an now it won't charge the bettery.  And the battery icon has an "X" as well, what should I do???  I'm desperate!!!!  And if unplug the power adapter, it will shut down.... What's going on???  Please let me know what did you do to fix your problem!!
  • Anonymous May 31, 2008
    same
  • markfinnerty Jul 06, 2008
    exactly the same problem for me.
    have tried re inserting battery but to no success.
  • msbicole Nov 04, 2008
    I also have the same problem. I am able to use my laptop when it is connected to the power adapter. However, when the power adapter is not connected I am able to work. I am also noticing that the battery icon is showing an "x" in it and the adapter is only lighting up green. How can I solve this?
  • will829 Dec 22, 2008
    whenever i plug my charger cable into my computer it never works, with the sign at the top saying it has been charged fully.
  • Anonymous Mar 01, 2009
    my macbook wont charge either.  instead of an x at the batterie it says   ( Not Charging  )   help!
  • emmaduncker Apr 15, 2009
    I have the same problem with the power adapter, except, sporadically it won't charge at all, the light doesn't come on, and nothing happens with the icon in the screen, some times i change plug sockets, and it works, other times it makes no difference, i don't understand, my mac also seems to overheat as well, and i only use it for documents and research, and the occasional facebook, it's not like i'm over using it!! HELP!!
  • 23 Answers
Apple is advising all owners of MacBooks or MacBook Pros bought after February 2006 to download a software update that will help fix some battery issues. The update, available through Software Update in the Apple menu or here on Apple's site, was released to correct some battery performance problems, such as shorter than usual battery life or problems charging the battery, according to a Web page on the support section of Apple's site. But if that fix doesn't work, notebook users should contact Apple to have their battery replaced if they notice the following symptoms, cut and pasted from Apple's support document: * Battery is not recognized causing an "X" to appear in the battery icon in the Finder menu bar. * Battery will not charge when computer is plugged into AC power. * Battery exhibits low charge capacity/runtime when using a fully charged battery with a battery cycle count (as shown in System Profiler) of less than 300. * Battery pack is visibly deformed. Apple says these problems aren't safety issues, just performance-related, a relief for those who remember the massive battery recall of last summer. Apple had to recall 1.8 million batteries manufactured by Sony as part of a larger recall that affected just about everyone in the PC industry.
Posted on Jul 11, 2007
  • 178 Answers
Yes I agree horthette. Also they just released the latest for the batteries. ALSO please take the battery out and let it sit for a min. make sure you shut down first. Then place the battery and apply the new update. ALWAYS THOUGH when using a full battery always unplug the power source from it. You will lose the life of the battery quicker when you are plugged in on a full charged battery.
I have both MAC AND PC AND LOVE BOTH
Posted on Feb 10, 2008
    New Friend:
Guys i need you help too ihave a macbook, that i left it on for some time, when i try to open it wont turn on nor even charge the chargers green light glows, now iam stuck and i seriously need your help.
Posted on Oct 08, 2011
  • 846 Answers
If you've replaced the battery, updated bios and reset nvram and it still won't charge i would assume there is a physical issue with your logic board. Could be that the charging port is just loose. If you're out of warranty, somebody has to open the Laptop and replace the part. The part is available on ebay. Here's a guide on how to disassemble a Laptop. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third party Laptop Repair Services.
Posted on Aug 15, 2010
Well I had a similar problem.  I think mine just got fixed but I'm not quite sure how I did it. My computer would not turn on if it was not connected with the charger, and when I would connect it, the battery would be half way charging, switching back and forth from orange to green lighting.  After leaving it charging for a good half hour or so, it got fully charged.  I turned it on and it was working just fine.  I turned it off, unplugged the charger, and turned it on again and it worked. my charger and battery are back to normal now.  I'm not sure if this helped you out, but hey I tried.
Posted on Dec 31, 2008
My lap top will not charge in Argentina with the adaptor that I bought here. The battery icon goes to calculating and then says not charging.I thought that I could charge it
Posted on Oct 31, 2008
SOURCE:
Battery not charging
this is just a suggestion not an appropriate answer
just try this!
try to unmount the battery from laptop and connect the battery, then mount the battery back to laptop
then leave the laptop goes off with out power then connect the adapter back to laptop and try to on normally.
Apr 17, 2013 | Dell Inspiron 1318 Laptop Computer PC...
Vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
My compaq CQ 61-420 US notebook won't turn on It was on and we left the room for a few minutes and came back in and it was off and won't come back on the 3 lights in the bottum left flash 3 times...
Greetings! Whenever you're dealing with a laptop computer that does not power up the first thing you want to do is disconnect the AC adapter from the laptop.The next step is to remove the battery from the laptop. Then reinsert the battery and reconnect the AC adapter. Press the power switch at this point and see if the laptop will power up normally.
Laptops are also prone to overheating. If the laptop powers up after it has cooled down and then fails again you may be dealing with an overheating issue. Try taking a standard can of compressed air and blowing out the ducts that supply fair to the cooling fan, as well as blowing off any "dust bunnies" or visible debris that have accumulated on the cooling fan itself.
Also make sure that the laptop is not sitting in an orientation that impedes the airflow to the cooling fan.
Jun 02, 2011 | HP Compaq Presario CQ61420us Notebook
Lenovo y410 laptops turns off suddenlty while using it for long hours
hi
is the computer dissipating excessive heat from bottom ? is the heatsink fan working (is it blowing out air from fan on the side ? if not, then replace the heatsink fan. This shut down occurs to advise you that something is not working well , and to avoid damage to the CPU and/or mainboard, its letting you know that.
if the fan is working fine-- are you on the computer while the AC adapter is NOT plugged in ? Are you fully charging the battery before you use the notebook without the AC adapter ? If you are NOT using the AC adapter, running on battery life only, then do this : shut down the notebook, disconnect the power adapter, remove the battery back up from rear of notebook.
reconnect the AC adpater and start the computer -- perform normal function on the computer, run it and work with it for a few hours. if the same issue occurs, (unwanted shut down) , then perhaps the AC adapter is faulty, which is not charging the battery to full capacity.
let me know what happens-- i'd appreciate your feedback w/o receiving bad rating
Nov 15, 2010 | Lenovo 3000 Y410 Laptop
My apple laptop does not charge and works only when plugged in?
Try this procedure:
  1. If the computer is on, turn it off.
  2. Disconnect the AC adapter and remove the computer's battery.
  3. Press and hold the power button for 5 seconds and then release the button.
  4. Reconnect the battery and AC Adapter.
  5. Press the power button to restart the computer
Dec 03, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My mac G4 powerbook doesnt start up. There are
It sounds like the system is corrupted. What I would do is to get your instal disk and boot up holding down the c key on your keyboard. Once you have booted up go to the file menu and run disk utility to verify and repair the hard drive if necessary. Then go to the instal menu and instal a fresh system remembering to preserve the users data so you do not wipe anything. Hopefully this will work.
Nov 11, 2009 | Apple PowerBook G4 Mac Notebook
When connected to mains adapter the 2 left side LEDs on the front of the computer {standby+mains connected]start to flash and doesnt charg
This happens when the battery will not hold a charge. You will need a replacement battery if you want that light to go away.
If the battery has not been like that too long
put in a plastic bag and freeze overnight
let thaw until room temp
insert battery
plug in jack
do not power on laptop
let charge for1 hour
then try
Apr 15, 2009 | HP Pavilion dv8000z Notebook
Toshiba M35X-S109 Doesnt Start
you may have a faulty motherboard connection, but try connecting the power adapter in without the battery and see if it runs, then replace the battery back in the compartment.
Oct 15, 2007 | Toshiba Satellite M35X-S109 Notebook
Apple iBook Mac Notebook Logo
14,020 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
