Bottom elements wont heat in my electic furnance
  • 334 Answers
Many electric furnaces operate in two stages, and the bottom element is only supposed to come on in the second stage.
If this is not the case with oyurs, then you aparently have a relay or "heat sequencer" that is not working.
It could be that the relay is stuck in the open position, or that its not getting 24V to the coil telling it to come on.
Check for 24V at the coil, if you have it, and do not have voltage coming out of the top of the relay, then its a bad relay.
Posted on Jan 23, 2009
  • Danny Clark
    Danny Clark Jan 26, 2009
    Were you able to find the problem?
Maytag oven won t heat up
the upper element only comes on when you broil or clean with selfcleaner. the bottom comes on when you are baking, it sounds like your bottom element is bad.
May 07, 2014 | Maytag Ovens
Dryer wont heat up
check to make sure that the element doesent have a break in it it might be hiding inside one of the ceramic holders if you have a volt meter disconect elect connectors and use ohms scale no beep or meter does not regestor bad element ps there is a thermal overload connected follow the element wires you will see it two wires check it also with meter
Apr 12, 2010 | Magic Chef CYE4000AWW Electric Dryer
I have a Ruud Electic furnance, Model # UBEA-21-J10NFJAI, it has two heating coils and one has burned open. What would cause that element to burn open?
Hi!
It could be a loose connection causing a voltage drop(higher amp draw) on either end of the element or the element shorted out(touching something to ground) or the sequencer contact that gives power to that element stuck closed and the element kept heating without the fan running or just the age of the element (burned out normally). I hope that helped!
Jan 03, 2010 | Heating & Cooling
I have a matag cre9600cce, the oven heats, but very slowly and not all the way. i set it to 350 and after an hour it is only at 210
the cre is elect so look for one of the elements not working / ( bake ) is probably is out . and the pre heat is only from the top element .. / test by open door ser to bake bottom element should go red / then set broil and it to should turn red . the one that does not repl .. mm
Dec 12, 2009 | Amana ARGS7650SS Gas Kitchen Range
Top two element work botttom two dont
if you have an ohm meter check and see if you have continuity through heating element that is bad. if you dont it is broken and or there is a fused link that is bad. if it ohms out then it may be the relay
Jan 22, 2009 | Kitchen Appliances - Others
Oven not heating up
can you see the bottom element?? if so usually , its obvious when the element goes bad, youll see the damage.TURN OFF POWER. 2 screws remove elemnet from the front 2 wires, plug in aa new one and your good
Feb 29, 2008 | Frigidaire FEF336BC Electric Kitchen Range
GE Electric Range
It is very common for elements to "catch fire" when they fail. It is really electical arching. But to answer your question you shouldnt be concerned if it ever happens to the bottom element immediatly kill the breaker it will stop instantly. dont use a fire extinguisher as it wont stop the arching. And most ovens do use the upper broil element for baking for very short intervals like 10secs on every minute or so to brown the top of product. Some models (especially older builder line ) do not
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
HOTPOINT ELECTRIC STOVE
two things---when you open the oven door do you see a button on the right or left side?if so thats a door switch and if its bad you will get no voltage to the element.the next thing is your hi limit is bad.this is a sensor that monitors the temp of the oven and if its bad you wont get any heat.some hi limits reset themselves others you have to manually reset them.let me know.
Jul 30, 2007 | GE JKP15 Electric Single Oven
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
