Question about Sony HTCT550W Theater System
Sony HTCT550W Theater System press power protector
SOURCE: push power protector
I brought the unit to an authorized Sony repair depot and they concluded that all the power transistors were fried. They replaced the system board under warranty (at no charge) and the system has functioned perfectly since. Thanks for your help. -Steve.
Posted on Oct 29, 2008
welcomejee
  • 10594 Answers
SOURCE: power protector on sony surround sound system
Power protect is an error message that some thing is wrong in your sound system and requires qualified tech.
Normally that error message appears when unit got problem in amplifier output section, either it is speaker problem or some output chip is fried.
Posted on Feb 25, 2009
  • 4 Answers
SOURCE: "Protector" error
I had a similar problem and went to Sony tech support.
Seemed my disc got stuck somehow...
Try reseting the system by holding the STOP and the EJECT and the POWER buttons together...
It should go to demo mode....
Then try PLAY to see if you can get the system to read teh disc...
then EJECT...
It took me several trys of doing this but it did work....on the 3rd try.
Posted on Oct 09, 2009
welcomejee
  • 10594 Answers
SOURCE: I have Home Theater Sony DAV- DZ151Kb. Display
Push power protect message appears when home theater got problem in amplifier output section and any output amplifier chip becomes bad, receiver set protection mode and refuse to power up to avoid further damage in circuit board.
It is very hard for novice to troubleshoot what output chip is defective out of six amplifier output ICs in unit, check by professional is needed to solve this issue.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on Jan 14, 2011
Testimonial: "Thanks for the support, it really is a very good recommendation I will check if you are getting voltage to the integrated and review the external components. "
dunnbiker
  • 8546 Answers
SOURCE: system is not switching on.put
There is no 'switch' or control for Protection.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 03, 2011
Push power protector
if your pushing the power protector to on back its a resettable fuse an you have another insue inside shorting it out
Aug 03, 2014 | Sony Dream Home Theater System, DAV-DZ120...
If it really says, "Push power protector", there should be a reference to it in your owner's manual. Check there first.
Feb 05, 2014 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sony dz 260 sd detect
I have the same message "SD Detect" when I press (together) Eject, Forward & Function buttons after message "Push Power Protector"...
Does anyone fix it already and can share what is the solution ?
Please contact with me: dziekan_tek(at)o2.pl
Jan 29, 2014 | Sony DAV-DZ260 Theater System
MY SONY HBD-DZ810 HOME THEATER IS CONSTANTLY SHOWING PUSH POWER PROTECTOR
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Dec 20, 2012 | Sony DAV-HDX500 System
I m receiving a message push power protector
That is an internal failure message . The system is telling you either your speakers are shorted ( even cables could have shorted ) or the internal amplifier Chip has failed. its is asking you to switch off the system by pressing the power button to prevent further damage. You will need professional help to replace the STK power chip.
Mar 12, 2011 | Sony HOME THEATER SYSTEM System
SIR MY DAV-DZ110 HOME THEATER WAS FLASHING "PUSH POWER PROTECTOR" THAT WAS HAPPEN TODAY WHEN I PLUG IN AND TURN ON MY PLAYER TO TEST MY NEWLY BURN CD...
ola tengo un problema esk yo tengo el sony dav-dz110 cinema esk cuando enciendo me sale push power protector no se por k sale esto si alguien me ayuda se lo agraseria
Oct 12, 2010 | Sony DAV-DZ110 Theater System
Turn demo mode off on Sony Bravia home theater
On your remote;
Press the Home button
Scroll left to settings
System settings
Auto-start up - go through setup and select "Home" (not store)
Sorted
Dec 06, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
I have a sony DAV DZ230 home theatre system
on my home theater display it shows protector push power
Nov 24, 2008 | Audio Players & Recorders
Jun 22, 2008 | Sony DAV-DX255 System
Sony HTCT550W Theater System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
