Question about Kenmore Washing Machines
Need replacement coupling for Kenmore Washer
I am trying to locate a replacement coupling for a Sears Kenmore washer. The Model # is 91566400 and the Serial # CEO202740. The washer has 9.8 amps and the coupling goes between the motor and the pump. Please help me find this or direct me towards it! Thanks!
  • 8,197 Answers
Go to a sears service senter and they can order one for you
Posted on Jan 22, 2009
How do you install belt
usually direct drive if top load,no belt has a motor coupling,send model number so i can look up your model,sears kenmore doesn't make washers,they just put the name on it,say washer starts with 110. on model,then you know whirlpool made it.
Jun 24, 2014 | Kenmore 24032\24036 Top Load Washer
Need part number for my kenmore he2 plus washer's drain pump. I need to replace it due to a continuing F21 error code msg
Sears has a fantastic part locator on line try that just surf the sears site you ll find it ,probalby even have a number to call just in case
Mar 09, 2011 | Kenmore HE2 Plus Front Load Washer
does it agitate???. if it does not then you need the motor coupling. you need to remove the cabinet, yes, I said the cabinet, remove the pump,motor and you got to the coupling. replace all part in kit. reassemble and test. go to the website of sears parts WITH THE COMPLETE MODEL. and get the part. model starts like 110.xxxxxxxxxxx
good luck to you.
Feb 07, 2011 | Kenmore 15864/15862 Top Load Washer
My Kenmore washing machine Model #11082984120 will
it IS driven by belts you need to either replace the belts youself or call in a serviceman.
Aug 01, 2009 | Washing Machines
Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
May 28, 2009 | Kenmore 43042 Front Load Washer
Broken washer belt
This machine has no belt. It does have a motor coupling. Easiest way to replace it is to lay the machine on its back. Remove the pump cilps and slide the pump out of the way. Remove the motor clips (they may each have a 5/16 screw), and slidt the motor out. Replace the coupling and assemble in reverse order. Coupling # 285753 available at for 9.99 or from sears. Hope this helps!
Feb 02, 2009 | Kenmore 24902 Top Load Washer
Loud noise in washer center still spinning draining fine but still loud noise trying to get center out but just got fabric softner top off Sears Kenmore washer
hi. thanks for the question. the problem you are having is with the motor drive coupling. which is located at the motor and transmission .replace the coupling .thanks the appliance doc.
Oct 05, 2008 | Washing Machines
Ordering CCU for kenmore elite 45986
Are you attempting to replace the Main Computer Microprocessor, or the User Interface? The Main Computer is located inside the washer behind the wash tub, while the User Interface is behind the control panel. The term CCU sometimes gets used interchangeably and I need to be sure.
It's easier to order parts directly from Just type in your model number (located around the door opening) and you will find both of the parts I mentioned under the "Control Panel" heading. If you wish to try a local Sears dealer in your area, you can use the part numbers provided by the Sears website.
I hope this helps you. Please post back if you need further assistance.
PS If you wish to compare pricing, you can also try Both sites get their parts from the same part source. They both offer comparible pricing with one or the other often having better deals.
Apr 21, 2008 | Kenmore Elite 45986 Front Load Washer
Open Questions:
Washing Machines Logo
73 people viewed this question
Sal De
 Brian Main
Brian Main
