Question about Bemis 427 300 Humidifier
Not enough humidity
I have a bemus 14 gal humidifier. For some reason it is not using water like it used to. I put a new filter in it every year. I used to have to fill it twice a day but now its only once a day. Everything looks ok and the fan is working ok. The wick seems to be saturated but I cant get the humidity level up where it belongs. My house is appx. 1700 sqaure feet.
  • Anonymous Jan 26, 2009
    does not use water
    Novelist:
  • 88 Answers
Thanks for your question,
seems to me you have a calcium build up inside the unit, something has slowed down the humidification process and that would be the most likely cause, you should run some diluted (CLR) through it and this should take care of the build up, leave it set for a while with the diluted solution in it then drain it out, and refill, give that a try and it should help, also check to make sure the fan is not getting cloged with dust and clean that too, thanks again for your question, please let us know how we did,
mr.grzz
Posted on Jan 22, 2009
No Water Flow to Honeywell Enviracaire HE225A1006 Humidifier
I have same problem with no water flow on identical humidifier but was able to fix it. Removed the inlet to the solenoid valve and found (1) a small taper mesh filter inside (2) a small diameter orifice that was clogged. Cleaned the miniature filter and used a sewing needle to open the orifice and now works perfectly.
Jan 09, 2010 | Honeywell Humidifiers
Sears humidifier is running at less than 50% after only one year
If your sure you have water supply to the unit,the float switch/valve is either clogged or defective.
Jan 09, 2010 | Kenmore Humidifiers
Our Aprilaire is over 14 years old. Two
If your humidifier is working properly, then the problem lies outside of the humidifier. For example how long does your furnance run when the thermostat calls for heat? If your furnace is oversized for your home, it will heat your home relatively quickly, and turn off, while your humidifier does not have a chance to work long enough for it to increase the humidity. If this is the case, you could try to set the thermostat to run the fan in manual mode instead of automatic. This will give the humidifier a chance to increase the humidity.
Hope this helps.
Jan 08, 2010 | Aprilaire Humidifiers
I just hooked up a honneywell whole house humidifer in my 1000 sq ft home. (last week) . i now see that the humidy has been at normal living condition. my problem now is i see i sttill go thru 15-20 gals...
Well thats the big problem with bypass Humidifiers, they use alot of water, is yours running all the time, even when the furnace is shut down ? if it is, its wired in wrong, if not then there is not much of a solution for ya, is the humidity level in the home comfortable to where you can actually turn the house t-stat down ? if not you may want to incress the amount of humidity to be able to turn your house t-stat down, you should be feeling about 3 to 7 degrees warmer with the right amount of humidity, sorry I couldnt be more help, but thats the nature of that unit, just a little FYI, if you ever decide to try something different, may cost a bit more, try a steam humidifier, alot less water usage, its filtered, and pretty reliable too, thanks again for your question, hope atleast part of this helped !
mr.grzz
Jan 05, 2009 | Honeywell HE220A1019 Whole House...
Hunter humidifer
I dont know why your humidifier is spitting water out.
But it sounds like you need to clean the unit and install a new filter. Once the filter becomes used, the humidifier won't work as well. Less water will be used because the clogged filter can't hold as much. Once you replace the filter, your water consumption should go back up and you should feel a difference in your home again.
Good Luck.
Feb 15, 2008 | Hunter 33201 Humidifier
Cool Mist Humidifier Filter Drying Out
How long are you going between filter changes?
A filter that stops wicking water up and turns orange/yellow is one full of deposits.
It sounds like you have hard water. How are you filtering this water before you use it? Distilled water is the best.
Replace the filter. They don't last forever. Mine normally last a month to a month and a half.
Good Luck
Feb 10, 2008 | Honeywell QuietCare HCM-630 Humidifier
Aprilaire 400 - Mesh Screen not wet
Not happy either. I bought 3 Aprilaire 400 for my house (3 zones). I picked this style since I have attic installation and did not want to run drains. The first night I expected a major air quality improvement but no change in humidity. I have installed humidifiers before so I know the drastic improvement they make. So I watched for a season and still no humidity improvement. Absolutely nothing at all. Same exact observation as you all described. Only the bottom of the media was wet. I'm dissatisfied with Aprilaire 400. Do not buy! Since I installed humidifiers before and understand them I am converting the Aprilaire 400 to work like a Aprilaire 600. I simply unwired the float sensors, removed the floats/lid and using a knife cut some of the plastic cups so the water would drain well. I also cut open the plastic exit port some too so it wont clog from dust globs. I obviously added drains. HUGE RESULTS. On the very first cycle on the humidity in that zone went from 25 to 48. I am watching carefully. -GK
Dec 31, 2007 | Aprilaire 400 Humidifier
Lack of humidity
Try the following test, ( I will resume this is a flow through humidifier)
Spray water directly oin the filter make sure it is saturated. Some water should leak from the bottom. After 10 min measure the Humidity to see if this helped. If there is a higher level of humidity the pbm is that not enough water is saturating the filter. Check the level of the filter & water feed nozzle.
Option 2 is to connect the water feed tube to a Hot water source.
Hope this helps.
Dec 28, 2007 | Honeywell HE220A1019 Whole House...
Bemis 427 300 Humidifier Logo
151 people viewed this question
Top Bemis Humidifiers Experts
Paul Carew
Dennis
Are you a Bemis Humidifier Expert? Answer questions, earn points and help others
