Question about Gateway GT5098E PC Desktop
I have a gateway model gt5098e and I need to add video card to support two monitors. what kind of video card fits this model
    Sergeant:
    Champion:
  • 242 Answers
With your 300 watt power supply I wouldn't get a video card thats too beefy. Here are a list of video cards:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010380048+1069633099&Configurator=&Subcategory=48&description=&Ntk=&SpeTabStoreType=&srchInDesc=
If I were you I would upgrade your Power Supply too.
Please rate my response, thank you.
Posted on Jan 22, 2009
Gateway GT5040 Graphics Card
This model Gateway desktop computer has a built-in video card.
Connect the monitor to the Gateway motherboard video port and the boot up and go into the BIOS and select disable the built-in video.
Shut down then connect the monitor to the 8800GTX video card and boot up the Gateway computer. The video should then appear in the monitor.
Feb 14, 2013 | Gateway GT5040 PC Desktop
What video cards fit into a gateway profile 6
You won't ba able to fit a video card in this computer. Because it is a all-in-one PC.
May 26, 2012 | Gateway Computers & Internet
Gateway with 2 data ports
The "Connect monitor to alternate video port" message suggests that it is the motherboard video port. Since your computer has a video graphics card, the motherboard connections are disabled in the BIOS. (This avoids conflicts.)
Many video cards have several display ports each of a different type (VGA, DVI, HDMI, DisplayPort (less likely on a low-end desktop)) . Some of these cards can drive two monitors at the same time. Look at where your current monitor is connected, then consider an adapter to connect the second monitor to that video card. (For example, a DVI to VGA adapter will let you connect a VGA monitor cable to the DVI port.) Some DVI ports will let you run two monitors from the one port with a splitter.
Gateway has support documents for their computers here: http://support.gateway.com/us/en/support/default.aspx . You'll need to use the model number and look for the User's Guide, Top Answers and support documents tabs.
The only way to use the blocked port would be to enable it in the BIOS (usually press F2 on start up for Gateways). Press this key repeatedly from power on until it responds. I frequently miss the timing, just shut down and try again. However, first you would need to remove the graphics card drivers (uninstall program (Catalyst for AMD/ATI) and the drivers) from your Windows OS. Then remove the graphics card from the desktop. Since this requires opening the computer, you will need to be careful to remain grounded relative to the computer. (Use a ground strap or work carefully touching a metal surface of the case.)
Please add a comment with your computer's model number and I'll be glad to give you specifics on running two monitors from your system.
I hope this helps.
Feb 21, 2012 | Gateway GT5694 Desktop Computer
I have a Gateway 5228. The cpu boots but the monitor is not receiving any signal so goes to power save. The video card is built into the motherboard but there is a card slot available. Can I add a video...
Sounds to me like the integrated video has kicked the bucket. You should be able to buy a slot load card and it will work fine.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jun 28, 2011 | Gateway Computers & Internet
I need a driver for my gateway monitor model nl2501. Wont go higher than the 640 by 480 point. Bad picture
You don't need a driver for you monitor, you need a driver for your video card. The first step is to find out what video card you have. Once you have loaded the proper video card drivers you will be able to see higher resolutions to select from in your display settings box.
Dec 19, 2009 | Gateway Computers & Internet
Suggestions for new graphics card on Gateway 300s
just check what motherboard version your computer is running on and just advise the supplier to supply you with a graphics card that well fits for that motherboard.....
Oct 11, 2009 | Gateway (6000736) (4 MB) Graphic Card
Screen goes off showing VGA with cable on the screen
This looks like a bad cable connection. Try using a new cable for the connection between the computer and monitor. If that does not work test you computer on another monitor to make sure you are getting signal output from the video card.Also check the monitor on another computer.This is to check and make sure the monitor is working properly.You can also try using a add on video card in the computer to see if you can use the monitor this way.If you still are having problems. You can use this web address to get customer from Gateway. http://support.gateway.com/s/PC/R/1013953/1013953nv.shtml. I hope this helps you with your problem.
May 16, 2009 | Gateway GM5259E PC Desktop
Need to replace video card
It would be the card that your monitor plugs into. If the monitor plugs straight into the motherboard, then all you need to do is add a video card and it should automatically bypass the built in one on the motherboard. Thanks and please take a moment to rate this solution with a fixya rating. :c)
Jan 27, 2009 | Gateway 500XL PC Desktop
Onboard video has failed..how do I change in bios to video card ?
first install the video card in the pci slot first so that you have access to your monitors screen for you to disable the on board video chip or video card, go to the CMOS setup by pressing del key. once there you can browse through the CMOS setup to disable the on board video chip.
Dec 22, 2008 | Gateway GM5088 PC Desktop
Monitor resolution
It is possible that it is not a monitor problem but rather a video card issue. If in your desktop display properties you have only 1 selection (640 X 480) then you need to install the necessary drivers for your VGA/Video chipset.
Pls post back video/graphics details. If you have a built-in to the motherboard, post the brand/model of your PC. If it is an add-on video card, pls post brand/model. It would be of help if you can also post your operating system.
Good luck and kind regards.
Dec 12, 2007 | Compaq FS7600 17" Flat Glass Monitor
Gateway GT5098E PC Desktop Logo
93 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
