Question about Zyxel Prestige 660HW Wireless Router (PRESTIGE660HW)
How to disable sip ALG to prevent VoIP calls disconnecting on DSL service
What are reasonable prices for SIP trunking?
A cheap SIP trunk service is the great solution for a company which is in the process of converting traditional telephone service to VoIP system. However, if the company has PBX system, then it is not necessary to replace all equipment and you can use SIP Trunking which is less expensive. SIP Trunking allows your existing PBX system to Internet for VoIP connection. In SIP, bandwidth matters a lot to get proper network throughout the use. Also, features like:
1) Efficiency of data connectivity
2) Sharing of international voice calling across enterprise
However, the price of SIP Trunking also matters. The price of the service depends on the plan you're taking. Different companies have different plans having features along. Reliance Global Call is a prominent company offering SIP Trunking solutions. The enterprise SIP Trunk allows you to have international long distance calls under cheapest price.
May 16, 2017 | Computers & Internet
What are the advantages of SIP for VoIP?
SIP (Session Initiation Protocol) is an application layer protocol that is based on IP. It is a major communication standard mostly responsible for VoIP (Voice over IP) telephonic system. In the traditional phone networks, ISDN (Integrated Services for Digital Network) is considered as the communication standard designed for the transmission of voice traffic. Both ISDN, and SIP are usable with equal reliability; however, in ISDN system, the clients need to pay for the data service, and voice service separately, while in the SIP system there is no separate charge for data and voice. Thus, SIP is just good for the customers as it decreases the telephone charges drastically.
Reliance Global Call-Enterprise is one of the most reliable and popular SIP trunk providers over VoIP. It helps to install SIP trunk at the organizational levels, enabling to cut international call rates like local calls. Moreover, the users can connect their landlines, as also mobile lines with the SIP trunk service for VoIP.
Feb 22, 2017 | The Computers & Internet
What are SIP facts?
Well, do you know about the combination of hardware and software that allows you to make phone calls through the Internet? In fact, you can even make voice calls anywhere in the world free of cost. It's called Internet telephony. SIP stands for Session Initiation Protocol and it is the telephony signal procedure meant for VoIP (Voice over Internet Protocol) sessions. SIP connects, monitors, and disconnects VoIP calls. Even IM (instant messaging) applies an adapted edition of SIP. Here are some more SIP facts:
SIP can establish real-time sessions for teleconferencing, video conferencing, and online gaming by utilizing networks linked by IP protocols and IP addresses.
SIP allows your Internet Service Provider to incorporate necessary IP phone facilities with the internet and online chat.
SIP server provides usual telephony aspects like individual mobility, call forwarding, time-of-day routing, on the basis of the location of the person you are calling.
SIP users can utilize instant messaging applications to deliver video and voice messages for free.
So, in order to enjoy free video conferencing and call forwarding services, choose Relicanceglobalcall that can be used for hardware as well as software based SIP phones.
For more details visit :
Corporate Calling Cards
Aug 26, 2016 | Cell Phones
M phone wont call out.. it has a constant dial tone ..can you help me?
Might be a firewall setting in your router. See if you can change the SIP ALG setting. If it is off, you need to turn it on.
Here is a site that will help you identify the SIP ALG in your router:
http://www.nextiva.com/support/how-do-i-identify-sip-alg.html.
May 31, 2015 | magicJack Plus
How to do internet settings manually on nokia e71
BEFORE YOU BEGIN, please note the following:
On the Nokia E71 some of VoIP settings are hidden by default, and you will need Nokia's new VoIP SIP application.
This application can be used to configure VoIP settings on your Nokia. You can create new VoIP profiles and modify the existing ones, and create and modify VoIP parameters and NAT/Firewall traversal settings and that are normally not visible on the device UI, such as codec settings and SIP domain-specific NAT/FW settings. It is also possible to save all the VoIP profile settings to a text file. It also enables VoIP over WCDMA which means you can make VoIP call over 3G Internet connection.
Using your PC you can download free Nokia SIP VoIP application from here or you can check Nokia web sitefor latest version.
Extract and install SIS file using Nokia PC Suite software on your PC.
Once installation is complete you will be able to see "SIP VoIP Settings" application under Applications menu on your Nokia, which you will need in STEP 5 of this configuration guide for better voice quallity or enabling VoIP over 3G Internet connection.
Here you can find Nokia E71 SIP settings for voip setup and SIP client configuration guide with VoIPVoIP service.
STEP 1 Go to Tools / Settings / Connection / SIP settings. Create the following profile
Profile Name: VoIPVoIP Service
Profile: IETF Default
Access point: (your WLAN AP name)
Public user name: 5551231234@sip3.voipvoip.com ( Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. When recorded your phone will show sip:5551231234@sip3.voipvoip.com )
Use Compression: No
Registration: "Always on "
Use Security: No
STEP 2 You do not need to enter Proxy Server settings
Proxy Server Address: none
Registrar Server:none
Realm: none
User Name: none
STEP 3 Enter the following for Registrar Server settings
Registrar Server: sip3.voipvoip.com (When recorded your phone will show sip:sip3.voipvoip.com)
Realm: voipvoip.com
User Name: 5551231234 (Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. )
Password: Enter the password that you chose when you signed up for the service.
Transport Type: UDP
Port: 5060
STEP 4 Go to Tools / Settings / Connection / Internet Tel. Settings
Create a new profile for "voipvoip"(555123xxxx), name it "voipvoip"
Choose "voipvoip" as Preferred profile
STEP 5 For better voice quality or in order to be able to make VoIP calls over 3G internet connection you need to use Nokia SIP VoIP Application you installed.
Go to Applications on your phone and click on "SIP VoIP Settings" application. Choose VoIP services/VoIPVoIP (or the name of your VoIPVoIP account Internet profile.)
Click on "Profile Settings" and find "Allow VoIP over WCDMA" option and change it to "ON" This change allows VoIP over 3G connection on Nokia phones.
For better voice quality go to Codecs and delete all codecs except G729. There should be only G729 codec left under codecs setting
STEP 6 Reboot your phone. Once your phone is back on it will automatically register to VoIPVoIP.
Once it is registered you can start making calls.
Default call type: To switch between normal GSM calls or VOIP calls, navigate to Tools / Settings / Call / Default call type. Select Cellular to make normal calls to the phone number or Internet to use VoIP to call the number or address
Make Calls!
To dial any phone number that is part of the NANP (North American Numbering Plan), you must dial:
1 + Area Code + Phone number
To dial any phone number that is outside of the NANP (North American Numbering Plan), you must dial:
Country Code + City Code + Phone number
For example if you want to call Brazil (country code 55) phone number in Rio de Janeiro (city code 21) you must dial 5521 and phone number. + sign can also be used and number can be dialed as +5521xxxxxxx
BUT RATHER THAN FOLLOWING THESE PLS CALL TO YOUR CUSTOMER CARE THEY WIL GIVE THE SETTINGS. SAVE THEM. THEN FOLLOW THE INSTRUCTIONS. THIS DOES NOT COST ANY COST. PLEASE TRY THIS
Jul 07, 2010 | Nokia E71 Smartphone
I have Nokia E72, how can I connect to VOIP service in our office?
go to Tools > Settings > Connection > SIP settings
Profile name: any
Service Profile: IETF
Default Access point: select your access point
Public user name: sip:your-voip-ext@voip-server.com
Use compression: No
Registration: select your preference
Use security: No
Proxy server: empty/no settings
Registrar server:
> Registrar server address: sip:voip-server.com
> Realm: asterisk
> Username: voip-ext-no.
> Password: voip-password
> Transport type: Auto
> Port: 5060
Then go back to Connection > Internet Tel.
create profile and select the SIP settings you just created.
May 06, 2010 | Nokia E72 Smartphone
Disable SIP AL
connect to the modem through telnet and type
application unbind SIP 5060 saveall
Aug 28, 2009 | Computers & Internet
Softphone will not dial out
canceled my softphone and will replace it
Mar 15, 2008 | Lands Phones
Polycom Soundpoint IP 501 - URL call is disabled
This in it's most basic description means that the phone is unable to register with the SIP server, most likely for lack of internet connectivity or a firewall blocking the packets.
If you've verified connectivity and opened the proper ports and the phone fails to initialize and still getting “URL Call Disabled” or all of the above parameters are correct, update the firmware for the router. This can usually be done within the router configuration. Then reboot in order, the cable modem or DSL, the router or switch, then the phone. This may solve the problem.
If still having the same issue, confirm in the router configuration for settings such as SIP proxy, gateway, or application layer or any configuration setting for SIP or VOIP. If any of these do exist, make sure they are turned off as these may only confuse or adversely affect many implementations.
Jan 08, 2008 | Polycom SoundPoint IP 501 IP Phone
Zyxel Prestige 660HW Wireless Router (PRESTIGE660HW) Logo
47 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
