Question about Relic Wet ZR11657 Watch for Men
FIND MODEL WET ZR11667 - Relic Wet ZR11657 Watch for Men
I bought edifice casio watch and when i use while washing hand the water goes inside at the first moment ???
unless it is waterproof you should remove electronics before going near water....
even water proof and water resistant electronics can get hairline fractures that will allow water to seap in.
once wet it will stop working.
BUT - - if you dry it thoroughly and replace batteries (if they also got wet) it can work again but you must be sure all water is dried before returning power to machine
as an example, a CRT tv i owned years ago was submerged in water for a while... of course it no longer worked.
but after three days of having a fan blow air over it it was completely dry and again worked
WARNING: only works for CRT tvs the flat screen tvs likely will allow water to seep into the screen so while you think it is dry it is still wet in the screen
Jul 02, 2014 | Watches
Relic Wet ring around the crystal
this may be silly but, in some watches you can actually rotate the outside ring. try rotateing it does it move at all? a local watch service should be able to adjust it if its locked in somehow, if you pull the plug out would it move then?
Aug 16, 2008 | Relic Wet Multifunction ZR15385 Watch
I dont know how to download free themes for my nokiaC201
http://www.zedge.net/themes/1081584/wet-screen-theme/
go to this site.. and select your phone model first so that it will install proper on your phone. just a remind. adding application on your phone can cause your to phone to get virus. at your risk.. goodluck
Aug 24, 2011 | Watches
BATTERY REPLACEMENT FOR RELIC WET WATCH ZR11657????
If you can, pop the back of the watch off, the battery will have 3 digits, and some letters, for example 375R, 325LRW, etc. the 3 digit number is the type of battery you need. If you cannot read the number, then typically, if you take out the battery, and you measure the width, and height of the battery, then find another battery with the same measurements, it will work, trust me.
i hope i helped!
Jul 17, 2011 | Relic Wet ZR11657 Watch for Men
Watch winds but will not run,it got wet...
This can be a tricky problem to fix.. But I've got something that might help you out!
http://hubpages.com/hub/How-to-Remove-Moisture-From-a-Watch
This article should get the job done. Good luck!
May 20, 2010 | Bulova Caravelle Two Tone Expansion Band...
307 2006,floorwell is wet in passenger side and has a nasty smell ,i think its antifreeze,i recently had a new timing belt ,the old one snapped and did a lot of damage,it has only started since then,could...
it is possably your heater matrix which is located under the n/s of the dashboard.
you could try using a product called k-seal which you put into the coolant bottle when the engine is hot.
what this product does is perminently seal leaks in the cooling system.
Dec 07, 2009 | Peugeot 307BR Wrist Watch
What battery number and type for a colt chrono
Depends on the year. Google however is your friend Google Breitling Source and the watch type and see which year yours is.
Assuming its a 2006 to 2010 model it takes a 394 battery. I suggest a google to Breitling source and look in the watch archives there.
Consider sending it to breitling UK, you have a watch worth at least many hundreds of pounds that is waterproof. If you nip down the local muppets he will change the battery and charge you GBP20 not GBP70 but he will not change the case seals or pressure test the watch to ensure the seals are doing their job. Worst case you write off the watch when it gets wet or when you next get sweaty which is the same thing.
Specify you want the battery change service only and thats what Breitling do.
Good luck whatever you do.
Oct 15, 2009 | Breitling Colt GMT 292/SLV/FGHT Wrist...
Setting instruction on a Relic New Relic Wet Mens Chronograph Black Watch ZR15458
Go to the home site of the particular brand of watch you own. They should have the instructions for just about every watch configuration they manufacture.
Sep 03, 2008 | Watches
LUMINOX DEAD IN THE WATER!!!
No real way to clean it yourself, you need to take it to a professional who can diassemble it, clean it then reseal...unfortunately that takes tools and the knowledge...dont try at home, if its gotten wet, it WILL need to be taken apart and worked on.
Mar 14, 2008 | Navy Seal Luminox Watch
Relic Watch Band Removal
If there are holes where the band connects to the watch and you are unable to push the spring bar out. There may be a bar connecting the band to the watch. Those are harder to push out.You might have to use a tool & hammer it with a gavel. Hope this helps
Mar 04, 2008 | Watches
Relic Wet ZR11657 Watch for Men Logo
Top Relic Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you a Relic Watch Expert? Answer questions, earn points and help others
