Keyboard I have a acer aspire 7520G laptop, I do not understand the keyboard. I cannot type in an email address as the @ sign does not work. Where can I get instructions for the keyboard? Thank you.
  • lovemeten125 Jan 22, 2009
    Everything else works, I just can't get the @ key working
  • Cody McLaughlin May 11, 2010
    Please Clarify for me whether any other functions work on the keyboard. Do you have any function at all?
    Sergeant:
    Champion:
  • 259 Answers
You may need to change your language sttings under control panel and also the type of keyboard you are using also in control panel
Posted on Jan 22, 2009
  • John
    John Jan 22, 2009
    If everything else works it may be a faulty Key but on a standard 101 keyboard it is Shift Key and the number 2
I have a acer aspire 7520g i have replaced the motherboard now my cam won`t work even tho i have downloaded and installed the drivers
The WEBcam is located in the laptop lid above the LCD screen. Check the cable from the WEBcam is firmly attached to the motherboard.
Apr 21, 2013 | Aspire Acer 7520-5071 Notebook
How do I disable keyboard from typing only the green symbols on the right side of keys
if you're getting " when you press @ then your keyboard is not set to english.you need to go to control panel and then region and settings and change keyboard to english.
Nov 13, 2012 | Acer Aspire 6930-6771 Laptop
Hi i have got a new keyboard and wish to change it on acer 7520
taken from http://www.batterycentury.com/acer-aspire-7520g-502g25mi-keyboard-p-152819.html
Acer Aspire 7520G-502G25Mi Keyboard Repair and ReplacementAre you considering laptop keyboard repair? You might think twice if you happen to be the lucky owner of a laptop, because replacing the keyboard rather than repairing it could be a lot less expensive. Laptop keyboard replacement on this particular model is very easy and takes just a few minutes. Here is a quick Acer Aspire 7520G-502G25Mi Keyboard repair tutorial with step-by-step instructions. Once you have purchased the new keyboard, all you need to replace the old with the new is a screwdriver and something plastic, flat and thin like a credit card or guitar pick.
Step one: Remove the two screws from the bottom of the computer that are holding down the Acer Aspire 7520G-502G25Mi Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Acer Aspire 7520G-502G25Mi Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Acer laptop keyboard.
Final step: To insert the new Acer Aspire 7520G-502G25Mi Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Acer Aspire 7520G-502G25Mi Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
May 16, 2011 | Computers & Internet
I installed Ubuntu 10.10 on Acer aspire 7520G. Everything works good, however some of the keys, like the numeric side keyboard does not work and I do not know how to make it work.
Try
Crtl+Shift+NumLock
Or
Go to :
1) System
2) Preferences
3) Keyboard
4) Click Mouse Keys tab
4) Uncheck: Allow to control pointer using the keyboard
Mar 12, 2011 | Computers & Internet
I can't insert the symbol @ on my email address when using my acer aspire one bilingual netbook
This may be set up with foreign language settings, it is possible if you press shift and 2 or shift and ' the @ symbol appears. to change this you need to go into control panel, regions and languages, then click on the keyboards tab and change the keyboard for your type.
Feb 23, 2011 | Acer Aspire One PC Notebook
My Acer Aspire 7520G gives, most of the time, no sound. Problem with the Acer Aspire 7520G 17.0" Laptop Acer Aspire 7520G gives, most of the time, no sound or audio device in windows 7. 2 days ago I...
Try installing the latest audio driver.
Download the drivers from the Acer WEB site. Make sure youselect the model of your laptop and the XP or Vista version of the drivers youthat require and it matches the Windows version that is installed on yourlaptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Feb 18, 2011 | Acer Aspire 7520-5185 Laptop
Keyboard Replacement Instructions for Acer Aspire 7520g
if ur key board is guranty period than ur keyboard is replacement by service center oterwise warrnty period only repaired by service center.thank u
Jun 03, 2009 | Computers & Internet
Messenger
driver display can't used for notebook acer 4315 email : jalmi_ganteng@yahoo.co.id
Aug 11, 2008 | Acer Aspire 4315 Notebook
Email address
Try www.hotmail.com or www.yahoo.com and click "Sign Up".
That will give a email address like Your_name@yahoo.com or SOMETHING@HOTMAIL.COM
Feb 15, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
187 people viewed this question
David Payne
David Payne
