Question about Panasonic KX-TGA470S Cordless Phones
How to turn ringer off on kx-tga470
There is no ringer option in the menu. I can turn the phone volume down but that doesn't totally help.
    New Friend:
Ftp://ftp.panasonic.com/accessory/phone_fax/om/kx-tga470_mul_om.pdf
Here is the exact manual And Thank you. I could not understand the pdf. Your exact instructions above fixed my Bell with a Line across it meaning No Ringer is Fixed. Excellent explanation above.
From their pdf.... Ignore this part ya'll....Their pdf is foreign to me, they show or press for Off (I'm stuck at off mode) --> huh? lol That would get me in more trouble, I think. I want sound back on this 1 phone, not lose it on all 3 of my phones. Geez how confusing this manual can be? Thanks again for clarifying this.
Posted on Jun 29, 2017
SOURCE: ringer
1. Press Menu button
2. Press multibutton "down" repeatedly to display "settings BS", then press multibutton "right" {>}
3. Press {2} two times
4. Select the desired setting by pressing {1} for low, {2} for medium, {3} for high or {0} for off.
5. Press multibutton {>}, then press on/off button
Thats it....
Have fun
Posted on Jun 24, 2008
CORDLESSGURU
  • 106 Answers
SOURCE: Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Posted on Mar 23, 2008
SOURCE: phone ringer
You can download the manual for a very similar phone, the KX-TG2302 at http://service.us.panasonic.com/OperMan/findmanual.aspx?cat=TEL and you can figure out all the features of a KX-TG2303. The simple answer is: while you are not using the phone, press the up or down volume button and it should turn the ringer back on. To turn the ringer back off, press and hold the down volume button until you hear two beeps. You can adjust the volume while the phone is ringing. The manual will tell you how to change your ringer tones, etc.
Posted on May 22, 2007
SOURCE: Panasonic KX-TD7896 Phone phone no longer rings only vibrates
Is there an 'M' on the display? If so, that means it is in 'meeting mode.' All you have to do is press and hold the star key (*) and that will take care of it.
Posted on Dec 22, 2008
cnavarro
  • 2460 Answers
SOURCE: My Panasonic KX-T7730 has a humming sound when the
It would play music if you had a music source plugged into the cabinet.
Without picking up the handset, press "1". Your humming should stop. It's the command for Background Music ON/OFF.
Carl
Posted on Mar 18, 2009
HOW TO TURN ON THE RINGER
I think you may need to up the volume to hear the ringer sound. See page 21 of the manual at this site. Follow the menu instructions to change ringer tone and volume. Hope this helps.
http://s3.amazonaws.com/szmanuals/728dfc6337002162ae227f0b1b714819
Aug 07, 2014 | Panasonic KX-TGA402N-R KX-TGA402N
Cannot switch off "ring off" on Panasonic portable handset KX- TG2511
Which part of the manual is not clear?
You press the MENU/OK button, use up/down-arrow to select "Handset Setup" and press MENU/OK, use up/down-arrow to select "Ringer Setup" and press MENU/OK, use up/down-arrow to select "Ringer Volume" and press MENU/OK, use up/down-arrow to select the desired volume and press MENU/OK.
Nov 18, 2013 | Panasonic Lands Phones
Don't know how to increase the ring volume?
To increase the volume for the ringer, the volume buttons located on the charging stand can adjust the volume. To change the ringer volume on the phone instead of using the stand, go to the menu on the phone and type 1 then 1 again. This will take you to the ringer volume screen. You can select between the options:{1}: Low {2}: Medium {3}: {0}: Off.
May 06, 2011 | Panasonic KX-TG5632 Phone
How do I turn off the ringer off or lower the ringer setting on my Panasonic cordless phone model #KX-TG5432?
Note, in these instructions: {V} = down on Navigator key (large key in center of phone) {^} = up on Navigator key {>} = right on Navigator key
4 volume levels (high/medium/low/off) are available. The default setting is HIGH. 1 .Press {MENU}. 2. Scroll to "Ringer setting" by pressing {V} or {^}, then press {>}. 3. Scroll to "Ringer volume" by pressing {V} or {^}, then press {>}. 4 Press {V} or {^} repeatedly to select the desired volume. To turn the ringer off, press {V} repeatedly until "Off ?" is displayed. 5' Press {Save}. Note: When the ringer volume is set to off, the handset will display "Ringer off", and will not ring for outside calls. The handset will ring at the low level for intercom calls.
Apr 06, 2011 | Panasonic KX-TG5432 Digital Dual Cordless...
Phone shows ringer is off..how do I turn it on?
Follow the steps
Press Menu--->Ringer setting--->Ringer volume----> press up button to ON the ringer.
You can reduce ringer volume by down arrow and increase volume by up arrow.
Thanx
Jul 24, 2010 | Panasonic KX-TG2343 Cordless Phone
I cant turn up the volume on the second cordless phone. how is this done/
Do you want to turn up the ringer volume or the call volume?
To adjust the volume of the ringer press the UP or DOWN arrow on the pad to bring up the main menu. Move to the 'Handset setup' icon and press OK. Select 'Ringer Setup' and press OK. Now select 'Ringer Volume' and OK. (At this point if you have 2 incoming lines you will need to select the correct line). The display will now show the volume, use the UP and DOWN arrows to adjust the volume. When finished press the OK button, then press the CALL END button to return to the main screen.
Adjusting the call volume is easier. When you are on a call use the UP and DOWN arrows to alter the volume.
I hope this helps.
Jul 19, 2010 | Panasonic (KX-TG1032S) Phone
Panasonic KX-TG2343 cordless phone
I'm not sure about changing the amount of rings, but you can turn down the ringer.
1. Press the "menu" key, just below the "off" key.
2. Press the down arrow until you reach "Ringer setting," and then select this by pressing the key just below the screen on the right side (directly above "off" key) .
3. "Ringer volume" appears on the screen - select this the same way as you selected "Ringer setting."
4. Use the arrow keys to change the volume, and then press "Save" by pressing the same key you used to select.
Dec 09, 2008 | Panasonic KX-TG2343 Cordless Phone
Ringer not working
On the base press the volume up [^] key. Repeat pressing to get higher volume. Press volume down [V] for reducing the volume. Press and hold volume down for two seconds to turn ringer off. On the handset, you can use the menu to turn ringer on and off.
Nov 19, 2008 | Panasonic KX-TG2313 Cordless Phone
Panasonic cordless phone,
press menu,scroll down to ringer settings,hit select,scroll to ringer volume and hit select then press up the round button in the middle until you hear it make a "ring" sound. adjust your preferred volume and hit save.
Oct 16, 2008 | Panasonic KX-TG5632 Phone
Phone ringer
May 10, 2007 | Panasonic KX-TG2303B/WH Digital Cordless...
Panasonic KX-TGA470S Cordless Phones Logo
1,434 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
