Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Installation of new print head
How do I remove the old print head so that I can install the new one
  • 40 Answers
Go to this link. http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
Posted on Jan 22, 2009
U052 error - The type of print head is incorrect. I have not changed the print head from new, and have done all that was suggested in the on screen help list. It would appear that I have to replace the...
u Can Follow this step :
http://support-sg.canon-asia.com/contents/SG/EN/8200986100.html
if that reference can't solved, in other reference i found this statment
http://www.canon.co.uk/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MP_series/MP620.aspx?faqtcmuri=tcm:14-610963&page=5&type=faq#Print%20head%20is%20not%20installed.%20Install%20the%20print%20head.%20U051/The%20type%20of%20print%20head%20is%20incorrect.%20Install%20the%20correct%20print%20head.%20U052
" Print head is not installed. Install the print head. U051/The type of print head is incorrect. Install the correct print head. U052 Follow the directions given in your setup sheet to install the Print Head.
If the Print Head is already installed, remove the Print Head once and then reinstall it."
Nov 17, 2010 | Canon PIXMA MP600 all-In-One InkJet...
New Printer - Issue with installing printhead
first of all.. make sure that you remove the packing material from the cart or print heads and put them in properly.
then also if it it gives the same probem then try it with the old print heads.. if it doesnt gives any eror with the old ones then replace the new ones..
new ones are bad..
return them to store
Oct 30, 2009 | HP Officejet 6500 Wireless All-in-One...
Will not print text only images
OK - here is all the help I can give to someone who won't respond to questions.
Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred.
If you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
Feb 12, 2009 | Epson Stylus C46 InkJet Printer
I need instructions for removing the old print head
Hi mcclure1970, the link included will help you do just about anything. (Includes pictures). The site has many (Next pages).
If you find this help ful rate me.
Mike
Jan 22, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I just got a new print head for my kodak esp3 all-in-one printer
hello.
with the printer ON, lift the scanner/top to access the cartridges. remove the ink cartridges. lift the gray tab gently with thumb and index finger of one hand. gently pull the print head up and out with the other hand. install new print head back first, then press target with thumb gently until you hear snap/click. reinstall ink cartridges.
good luck,
-k
Dec 24, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Print head problems
take ink cart. out, there is a release button center top just below the hole in the middle of the print head. That releases the print head take out at an angle. Hope this helps!!!!!!!!!
Oct 23, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak printer
Hi Tammy,
Installing the print head is really easy. Actually, it just snaps out and the new one snaps in. The key is where you press on the print head to do this. If you go to the following URL you will see how to accomplish this. Go to:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/5300AiOPrinterUG_EN-US.pdf
This shows you how to change the print head in a 5300 model. It is similar to the others as well.
If this does not work for you. contact the 800 421 6699 number and ask them to walk you through installing the print head. It will only take a couple of minutes.
Best regards,
Ron Baird
The friendly Kodak guy
Oct 08, 2008 | Office Equipment & Supplies
HP1280 ONLY printing in PINK...
ok..that means that your color management is shot to heck..
you'll need to download new software from www.hp.com
remove the old stuff with add/remove
re install
try it again
Aug 20, 2008 | Office Equipment & Supplies
Black ink
Leanne83 and jzig - I presume your problems are solved by now. If not, please respond with a new comment.
Guest
Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred. Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're SURE you have a good ink cartridge properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try up to 3 head clean/nozzle checks again. If still nothing, post a new comment with full details of what you have done and the results.
Nov 17, 2007 | Epson Stylus C40UX InkJet Printer
Canon i9950
Seems impossible to reset the counter, is there a way to manually reset?
Oct 10, 2007 | Canon BubbleJet i9950 InkJet Photo Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
43 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
