Question about Dishwashers
Dishwasher blows breaker just sitting there off.
  • bob collins
    bob collins May 11, 2010
    Did you unplug to confirm?
    Scholar:
  • 93 Answers
Are you sure the unit is off ?
If you have unplugged the unit and no breaker tripping occurs and tripps when machine is plugged in but switched off chances are you plug socket(on the wall) is the culpret here in which case I suggest you get a qualified electrician out to have a look.
Posted on Jan 22, 2009
Dishwasher trips breaker. Breaker only resets of door is opened
wires rubbing inside dish washer , surprising its not blowing fuse in dish washer plug .
Mar 25, 2013 | Dishwashers
Hi everytime we use the dishwasher it blows the circuit breaker now we cant even trip the breaker to use the dishwasher and ideas ?
disconnect dishwasher and put wire nuts on lines try to turn on breaker if goes on than u have a short in the wiring of the dishwasher -open panel and check connections if look good than start testing lined and components with an ohm meter for short ----if breaker doesnt go on check wire feed for short
Jun 28, 2011 | Asko 1385 Dishwasher
The dishwasher wont turn on. I'm not sure if is fused or not. How can I fix it?
Many dishwashers, due to their power consumption, are on their own house circuit. It may have blown the house fuse or circuit breaker. Ours does it about once every 6 months or so. I just reset the circuit breaker. I'm sure an electrician would tell me to replace the dishwasher or have it serviced to determine why it periodically blows the circuit, so if it has blown the circuit breaker, you should determine why before running it again (unlike me!).
Nov 07, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
Blows Circuit Breaker
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 03, 2010 | GE 24 in. GSD6660GSS Built-in Dishwasher
No power
well if your main power that supplies the dishwasher is good then you need to replace the main control unit of the dishwasher
Jan 31, 2010 | Dishwashers
Keeps blowing the fuse in the house
Try to turn off everything else that is on the same circuit then turn on the dishwasher. If the breaker still trips then the circuit breaker might be malfunctioning or the dishwasher might be defective (in which case the circuit breaker is doing exactly what it is designed to do.) I would bet that it's the dishwasher thats causing the problem. Check with the manufacturer to see if there are any recalls on that model.
Aug 17, 2009 | Creda Dishwashers
Dishwasher wont turn on
The dishwasher is generally on a separate circuit so if that circuit breaker kicks, or that fuse blows you won't see anything else turned off. Go to you panel and check to see.. If it is a blown fuse, replace it with a new one of the same amperage. If it is a kicked circuit breaker turn the breaker all the way off and then back on.
Apr 07, 2009 | GE GSD3800G - Multiple Color Built-in...
Maytag MDB7130AWB dishwasher blows circit breaker.
These have been known to leak water into the door panel. If so the water can cause a short. Your breaker is keeping the machine from lighting up. Check any seals that may have been braeched in the door. Start at the dispencer latch
rubber.
Mar 07, 2009 | Maytag MDB7100AWB Dishwasher
Dishwashers Logo
87 people viewed this question
Top Dishwashers Experts
