Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Control panel shows "Er dH"
Control panel shows Er dH. All the normal info is gone. LG suggested I unplug it for 3hrs and plug it in. THe information on the control panel came back, but then after a few hours went back to the Er dH again.
  • fridgeowner9 Mar 18, 2009
    When this fridge was on long enough (say 45 minutes to an hour) "Er dH" would pop up and strange clicking noises would begin. When the door was open the lights would go on and off along with a relay and fan. After time the problem worsens probably because some of the components start to heat up and cannot cool down. After this I got "Er Co". I have read a lot of complaints about this fridge including some other LG made Kenmore that could represent a fire hazard! I am concerned this fridge model does pose a fire hazard as well because the interior of the fridge heats up more than the temperature of my kitchen. If left plugged in with this problem I do not think it has a fail safe to turn off. I never knew I would use my fridge as an inefficient heater.
    The LG fridges are also not Energy Star Compliant like they want you to believe. Check out this PDF from energy star also: http://www.energystar.gov/ia/partners/ma...
    It would seem that everyone except for the consumer knows about this problem. The great company Sears is should not be selling this fridge any more but I just bought mine last weekend!
    Shame on you Sears! Don't sacrifice your lifetime customers for the profit squeezed out of one stinkin' fridge. Remember that a good customer experience is not relayed to many people but bad experiences are relayed to many upon many.
The “er dh” code means a problem with the defrost cycle. It is triggered when the defrost sensor does not reach 46 degrees F within 2 hours of the defrost cycle starting. If indeed the defroster is not working, the evaporator (in the bottom of the fridge in the freezer compartment and behind a plastic cover) will eventually ice up completely, blocking the flow of cold air to the upper compartment. Use a thermometer to check the upper compartment to verify that no or little cool air is reaching it.  If the evaporator is iced up, the defrost cycle is not working. Quick fix to restore operation to the upper compartment: tape over all vent holes in the upper section to keep that cool while you work below. There are about 6-7 vent opens in the back wall and two large one on the floor of upper compartment. Remove freezer door, drawers, slide rails and pull back the plastic cover (2 screws hold it in place, one in the center and one behind the ice maker) at the rear of the freezer section to expose the evaporator. Spray hot water on the ice accumulation on the evaporator (it looks like a radiator) to melt it (remembering to sop up what flows to the drain pan at the rear). The entire operation can be done in about 30 minutes (most time is used for removing ice and sopping up water from the drain pan). All should be ok for 3-4 days depending on humidity before the evaporator ices up again.  In the meantime, order a replacement control board. You can view this by removing a panel w/ 3 screws at the rear left of the refrigerator. This panel controls all refrigerator functions, including defrost. Most likely, the integrated relay for the defrost cycle failed. Swapping out panels is a 10 minute job. Panels cost about $116 incl shipping from repairclinc.com. Shipping is about a week.  You can find a free service manual on line that will help to identify all parts and is particularly useful for removing doors and trays so you can get at the evaporator.  All in all, the customer service is useless. The fridge however is very easy to work on and amazingly simple. The replacement board has a slightly different relay for the defrost heater, so LG may have realized a problem existed with the original. It is also possible that electrical surges damaged the relay.  In any case, 10 minutes and $116 seems pretty minor to have the fridge back to new condition. Good luck.
Posted on Apr 16, 2009
  • 410 Answers
Er dh means the computer for your ref hasnt sensed a defrost cycle recently. dh is code for defrost heater. because of the electronics its kind of hard for me to tell you h ow to trouble shoot the problem but most likely failure is the def termination switch. this isnt a very expensive part and easy enough to change.
one way you will know something is wrong is you'll start to see frost build up on the back wall of the freezer compartment then the fresh food comparment will start to warm up. if it quits cooling b-4 you get it fixed let it def for about 6-8 hours to allow the ice build up to get off the evap coil. good luck peyton..
Posted on Jan 22, 2009
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Error message on the display panel that says ER dH - inside of refrigerator getting warm - water dispenser, ice, temperature control on front panel not working
ER dh means you have defrost issue that needs to be addressed asap. The evaporator has frosted up so badly that the circulating cold air cannot get to the refrigerator. You would need to get inside the freezer back panel and remove it to access into the evaporator coil area. Test the defrost circuits to see if the defrost terminator is broken. If it is, replace it and melt the ice build up as well.
Good luck
Jul 16, 2011 | LG Refrigerators
Have a LG 3 door bottom freezer with error code Er dH. Was told by tech support to unplug for 10 mins. If this fails unit needs service. Is this correct?
dh means defrost problem.replace defrost control and element,behind freezer panel.dont forget to unplug fridge before you work on it
Nov 17, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
Code Er dH
Indicates Poor Defrosting. This error occurs when defrosting sensor is not over 8 degrees C an hour after defrosting. Possible causes are Temperature Fuse, Heater not working, clogged drain, or heater relay failure.
Unplug the refrigerator and reconnect to power to reset the control panel to see if error occurs again before checking other items listed above.
Oct 16, 2009 | LG LRSC-26922 Side by Side Refrigerator
Kenmore Elite Trio Error Message ER DH
This is a refrigerator manufactured by LG and is well known for this type of malfunction. There should be two 1/4 inch screws on the outside of the freezer drawer tracks near the front that will allow you to pull out the entire door assembly. Once this is done and the unit is fully defrosted and unplugged, there are a couple/few screws in the back freezer panel. Once the panel is removed, this part is located on the upper right side of the evaperator coils. It is sometimes wedged in tigtly but should pull out with a good tug. Unplug the white harness, remove defective part and reverse this process. Good luck and happy shopping for the shoes.
Aug 25, 2009 | Refrigerators
The panel control going shows Er in temp display
ER in temp means error code next 2 letters are first letter of part giving problem or where problem located.. if " ER DH" means def heater not coming on, does not mean heater bad but def control bad not letting voltage to heater. could need main bd also
Aug 21, 2009 | LG LRSC-26922 Side by Side Refrigerator
Error message Er FF
er ff means that the control board is not sensing evap fan motor operation this means either a bad fan motor ice in the fan motor or bad control board. you can verify fan operation by opening freezer door and feeling for old air blowing from back of freezer compartment. you will have to push in the light switch to get fan operation.
for corndo that has same problem you actually have a different problem. er dh means the control board is not sensing defrost heater operation. the most common culprit is a bad defrost sensor. message me back if you need instructions for trouble shooting..thx peyton
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Error Message: Er dH
The error codes are listed in the service manual (p. 32) at the address below:
LFX25960 Service Manual
"Er dH" seems to be a defroster issue.
Aug 14, 2008 | LG LFX25960 Bottom Freezer French Door...
LG Refrigerator Defrost Error ER DH-- Defrost fuse
the fuse is in the fz compartment behind the evap cover panel once you get the panel off it will be at the top right-hand corner wedged between the evap coils
Jun 23, 2008 | Refrigerators
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
Jun 13, 2008 | Refrigerators
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
590 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
