Question about Ovens
I need to replace GE model JKP07G0D2BG with a new oven. What size it this old oven?
. How do I figure out what size oven this is so that I know what to replace it with?
captaynkyrk
  • 170 Answers
SOURCE: replace oven ignitor for ge profile oven
If you go to this link: http://www.partselect.com. You can put in your make and model number in and get a diagram of your oven and see how it goes together. You can also order parts online, or at your local appliance parts store. Good luck!
Posted on Jul 20, 2008
Krazytech
  • 725 Answers
SOURCE: I actually have a very
WB44X0200 BAKE UNIT 208/240V
this bake element should work I would take your old one with you and compare the way it mounts to the connections..
Posted on Aug 16, 2008
dgjtex
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
SOURCE: I need the squematic wiring GE 24" Built-In Gas Oven
I have the same problem -- did you ever get this question answered?
Posted on Jun 14, 2010
  • 311 Answers
SOURCE: I have an old GE
Measure it yourself- it is right there in your house. Why make it complicated?
Posted on Sep 24, 2010
Thinking about buying a new GE range that has a 3000 watt specification ... our home is sixty years old and wondering if the wiring (240 v) can support the wattage. I don't know the wattage of our old...
Calculating necessary breaker size using ohms laws, says 3000 watts at 240 volts would use 12.5 amps and most range circuit breakers are 30 amp so it should be find
Aug 01, 2011 | GE Ovens
I have a GE wall oven, model # JKP07G004B0 and I would like to replace it. I need to know which new one will fit the space.
Since it is so old the diminsions are no longer available online and the only way to get the size is pull it out 4-6 inches and measure height,width and depth of the cut out portion of the cabinet it fits into
GENE
Jul 30, 2011 | GE Ovens
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
Feb 28, 2009 | GE 24" Built-In Single Gas Wall Oven
Dec 27, 2008 | GE JKS05 Electric Single Oven
Replacement for built in oven/microwave
Hello tippett_631
Welcome to fixya,
You said, ,
22 years ago you built the house you are currently living in. The above oven/microwave oven was built in. You are interested in replacing this unit with a new unit but it must be the same size. ? by the way i You would be happy with a double oven versus the microwave/oven duo. You have measured across the front of the unit and it only measures 26" across. Any assistance you could give us would be greatly appreciated.
I can help you!
The front is 26 inches.
And how high is it from the top to bottom?
Also when I sell a wall oven I always send out the installer to check the hole or cutout size.
Most of the time no wall oven fits with out at least one cut!
Do you have any room to cut a little on all sides?
What is your model number now. And what color do you want now??
I will send you some GE wall oven models and sizes so you can check your self if it will fit. usually they have to cut at least one side to fit it in the old hole!
Sep 25, 2008 | GE Ovens
Ge oven not sure the model it is 12yrs old
Check all connections to control board. If all check ok then replace control board.
Nov 16, 2007 | GE JKP15 Electric Single Oven
Ovens Logo
255 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
