Question about Refrigerators
Kenmore coldspot model #52522100 stopped working
Friend says it might be the relay. Where is the relay?
SOURCE: Refrigerator part wont get cold
push in door switch and make sure the light bulb goes off
Posted on Dec 02, 2007
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 172 Answers
SOURCE: kenmore coldspot - How do you remove the ice maker box to clean
Hi Cincygrl,
Well lets see, I believe you have a whirlpool made kenmore, Your model numer should start with 106.
The problem you are having is from our drain. When you freezer defrosts the water should drain down a tube and under the refrigerator into a pan. If the tube gets clogged it will leak water into the freshfood section. To clear the drain you will need to remove everything from the freezer and remove the inside back panel in the freezer. in the center bottom under the coils and the heater you will see a tiny hole. That is your drain. If it is frozen over you will need to defrost the ice or you may need to run a smaller tube into it to clear it of an obstruction. I use a small rubber hose and I just insert it into the hole and blow on the other end. If you have something in it, it should blow out. If it does not then it may have ice in it and you can pour hot water into the drain and defrost it. Once clear you should not have any further problems. But they do make a drain heater probe to keep ice from forming inside the drain. You can get one for about $6.00. Good luck and I hope this helped you. mca0824@aol.com
  • 1122 Answers
SOURCE: Kenmore Coldspot stop working
first ,do you have power to it,is the lights coming on?2-is there frost building in the freezer on the back wall?i think you have a defrost problem,let me know more-mike
Posted on Dec 16, 2008
  • 770 Answers
SOURCE: Kenmore coldspot 106.54563300 is not cooling.
Not good news, it sounds like a compressor problem. Vacuum clean everthing you can safely get to in order to make it eaiser for the repair guy, (hopefully to save money). How old is the fridge?
Posted on Jun 21, 2009
Kenmore Coldspot Model 106 9557651 stopped cooling and freezing. Mfg date is 09/95.
please make sure that the electricity supply to the unit is in order. after that check wether the thermostat is in working order and if the compressor is running. If everything is in order tou have a gas leak and the unit must be charged with gas.
Aug 07, 2009 | Refrigerators
I have a Kenmore Coldspot 106.53504300 The
you need to check if the compresser is red hot if so change the relay to a 3 and 1 overload relay very easy to in stall
trick put a floor fan pointed at the compresser let it run a while see if you notice a difference
Apr 17, 2009 | Refrigerators
Dec 15, 2008 | Refrigerators
Kenmore coldspot not making ice, and not cooling in the bottom
Your refrigerator is frosted up. Remove the inside panel of your freezer. Defrost the ice out of the coils and check the heater and bi-metal. If both are good then your defrost timer is bad. If one is bad replace and you have it fixed. Good luck.
Michael Anderson
(865)945-3808
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Coldspot Model 71182101
I have the same problem. The refrig and freezer are cold but not freezing and not cold enough. I have a friend tell me it probably is the relay. His did the same and that was the issue.
Jan 09, 2008 | Kenmore 72073 Top Freezer Refrigerator
Kenmore Coldspot Side by Side Model 51559101
I also have the same refrigerator model 106.56566400 and periodically when the power goes off in the house the refrigerator & freezer will stop cooling. Try pushing the on/off button located inside the refrigerator to the left of the digital temperature controls. Hold the button down, this turns the unit off, then press it again to turn it back on. This basically resets the refrigerator, and most of the time works to get the refrigerator cooling again. Try this first before calling a repair man.
Nov 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Refrigerators Logo
148 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
