Question about Panasonic AG-1980 S-VHS VCR
The main light on the front panel went out on my 1980 desk editior. how much to repair?
  • pdx1240 Feb 04, 2009
    The main light in the front panel of my 1980 is so dim it can barely be seen.Can this be fixed?
  • ooog Feb 24, 2009
    I have the same problem...but I noticed that the longer the deck is on,
    the brighter the lamp becomes. However, it does not gain full
    brightness as compared with my second deck right next to it.
    Champion:
  • 221 Answers
The display on the AG-1980 goes dim mostly from old age - replacement of the display usually cures the problem, though you may need to replace some or all capacitors in the power supply.
Posted on Mar 31, 2009
I have an AVOL 42" flat screen TV has no picture. Is there a Master reset?
Hi, It also could be BAD capacitors on the back of the TV. Most likely on the main power board. You should not attempt to do this yourself unless you know something about electronics. Please take it to your local repair shop. No, there are no reset buttons to push. If the cost of repair is too much. Go buy a new one. They are alot cheaper now. good luck.
Jan 23, 2015 | Televison & Video
My carl lewis mot566 doesn't have power even though it is plugged into the mains
please see the video and test it. God bless you
However you must use the desk lamp in outlet wall, if the lamp DOES NOT turn ON the problem is the outlet, reset the c.breaker and test the wiring:white+black+green with DVOM for open, short circuit, and bad contacts and repair.
Jan 08, 2013 | Exercise & Fitness
I NEED HELP IN REPAIRING THE FRONT HEADPHONE JACK ON THE TOWER, AND WOULD LIKE TO HAVE ACCESS TO THE SHOP REPAIR MANUAL. DELL DIMENSION 2400 DESK TOP PC, THANK YOU AND KINDLY APPRECIATED !!!
You can just remove and replace the front I/o panel rather than repairing it . The part is not more than 10$. You can get the part from the following site
http://www.txcesssurplus.com/servlet/the-5850/Dell-Dimension-2400-4600/Detail
or
http://www.impactcomputers.com/d0971.html
How to remove the front panel
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/fpanel.htm
Thanks for using fixya
Proton
Aug 20, 2010 | Dell Dimension 2400 PC Desktop
No power. led display very dim
dim display on an ag-1980 may be caused by bad display module or bad electrolytic capacitors in the display power supply. "no power" is probably a bad 12 volt regulator on the main board. the main power supply is working as evidenced by the display lighting up.
Jul 03, 2009 | Panasonic AG-1980 S-VHS VCR
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
My Deskjet 640c went "dead" soon after it started. The paper became stuck and the power On/Off light went out and would not respond to my efforts. Some weeks prior to this happening I noticed that the...
check if the ribbon that goes from the control panel to the main board is attach correctly, if is ok , am afraid you might have to change the main board
Apr 05, 2009 | HP DeskJet 640c InkJet Printer
Sony Projection TV 60 XBR, wont turn on, blinking green light
This sounds like when the power came back on a surge went into your tv and burnt out the TVs main power supply or possibly burn out the flyback power converter on the TV main board!
(I am pretty sure it is either one of these things!)
Please rate answer
THANK YOU!
Jan 15, 2009 | Televison & Video
Whirpool GGw9250Pw3 no power on Control Panel Inside light works
In my case, the problem was a dead main board. The board cost $190 and the overall repair cost $335. I will never buy another Whirlpool due to this experience.
Dec 11, 2008 | Whirlpool GGW9250PL Gas Dryer
Colour Noise and Dim Display
you may have a slightly damaged power supply...although swapping the main supply chassis may solve, I have seen front panels that have an additional supply section. look on the front panel board for any TP's and probe with an O-scope. if you see a TP that may also show (+ xx V), where xx is a numerical value-may be one x only, the scope must show a straight horizontal line that is shifted vertically away from its normal (ground) position. that confirms a DC value present. then determine the DC value of the shift. Another possibility, since you invested, is to search ebay for a second unit for part swapping. look for as-is units.
May 27, 2007 | Panasonic AG-1980 S-VHS VCR
Panasonic AG-1980 S-VHS VCR Logo
317 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
