My laptop icons and text are displaying in large form and are very dull. Also, my wireless does not work any more and doesn't even recognize the signal. Please assist.
  • kevhale2 Jan 23, 2009
    I forgot to mention that I am running, not by choice, vista home. At any rate, I bumped up the resolution and it looks better but not like it used to. The wireless issue still remains. I can't even find the wireless hardware on my laptop anymore. This one is confusing. Any suggestions?
    Genius:
  • 1,102 Answers
Control panel display
then settings you need to change to a higher resolution
control panel
network connections
see if your wireless connection shows if it does right click if says
enable then click enable if not right click and repair
have you upgraded anything on your system
let me know if you need other solutions or if your connection does'nt show
Posted on Jan 22, 2009
  • DEKR
    DEKR Jan 23, 2009
    right click my computer properties hardware then devices
    see if network shows in there
    did you try all the steps was it at least showing in control panel network connections
    do you have a system restore
    and finally did you upgrade from xp to vista
How do i reduce the text and icons on my laptop display/screen
Assuming you have a Windows system:
  1. First make sure you don't have the type size and icons set to a large size. Right click on your Desktop and choose 'Personalize'. Then in the lower left choose 'Display'. Make sure that you have selected 100% as the size of text and icons. If you have, proceed to #2
  2. Make sure that you are displaying at the native resolution on your laptop. If Windows doesn't have the right software drivers (instructions) for the display it will use some generic drivers which will work but will make everything appear large and potentially slightly fuzzy. Verify the potential resolution of your laptop with HP by looking up the model on their website and then checking the screen resolution. Then right click on your Desktop and pick 'Screen Resolution' from the context menu. Verify that the resolution is the same as the HP's listed resolution. If not, change it to match. If you can't change it to match that means you don't have the correct video card driver installed on your notebook. Go to #3
  3. To install the correct video driver for your notebook, go to the HP Support site and click on 'Detect my product'. This will install some HP software that will recognize your system and load the appropriate updated software drivers for all components. You want to specifically find 'video drivers' but it will probably be OK to let others found by the website be installed. Install the video drivers and then if the screen isn't displaying at the correct manufacturer resolution, go back and repeat the instructions in step 2 to manually set it.
That should get everything displaying at the correct size.
Drivers Downloads
Feb 18, 2015 | HP Pavilion Computers & Internet
Why doesn,t my computer connect with my modem & doesnt even connect though a wired conection ???wifi says no nework in range??? when the modemis right beside it???
If you have a laptop check all sides to see if there is a switch to turn it on, if not look at the keyboard and see if there is a wireless icon on any of the keys .If found Press the FN key and the wireless key to turn on.
Oct 03, 2014 | IBM ThinkPad Computers & Internet
Hiya, i'm having some problems with my Acer Travelmate 2410. I'm trying to get the LAN to work. When I press the button the front for wireless, I get a 'Wireless LAN disabled'. I've...
Well usually the wireless and the non-wireless NICs are two diffenerent cards, so I would be surprised that both cards are deffective at the same time... firs you need to verify if your DHCP supplies you with an IP address when connecting, try to notice the icone close to the clock (bottom write corner of the screen) if it has a small yellow dot moving sidewaise for a long time (wired or wireless) than your computer is not receiving any IP, check if you can connect to your network with an other computer to see if it works, if not than it's not the computer that has a problem but rather your DHCP server/router... if it does work than scan your non working computer with an antivirus it is probably infected...
Aug 08, 2011 | Acer Aspire 5050-3242 Notebook
How to change icon size on laprop
Try to go to this link, on how you change icon size.
http://www.techtalkz.com/windows-7/516049-how-change-font-size-icon-size-windows-7-a.html
AnEspera
Apr 18, 2011 | Computers & Internet
SIZE OF SCREEN. LETTERS ETC WAY TO LARGE WHO PUT IT BACK TO NORMAL SIZE
Hold down on the Apple in the upper left-hand corner of your screen.
1. Select System Preferences
2. Click on the Displays icon
3. Selecting a higher resolution will make things smaller in the screen.
· As example: x1024 768 icons and text will be large, 1280 x 1024 icons and text will be smaller.
Aug 21, 2010 | Apple Mac OS X
All icons and text appear very large and dull
This could be two problems right click on the main desktop computer screen go down to properties and click on that, then go to settings Change the screen area of your computer to a more also click on advanced and change the font size to small that should solve the problem you can also look at views under explorer to small
Jan 22, 2009 | Toshiba Satellite A10-S100 Notebook
Windows vista lare icons and text
In changing the icons to normal, did you reset the screen resolution? If not, set the resolution lower, apply, then reset it back to the original (usually 1024x768), then apply.
Aug 12, 2008 | Toshiba Satellite P105-S6207 Laptop
Text size very large after update
check display drivers are loaded if not load display driver it will work.
Jul 10, 2008 | Computers & Internet
Dell C840 Increasing resolution increase screen size and vice versa
Laptops when running in non native resolutions sometimes tend to use a small area, so that the bluring of text is not noticeable. The reason is that laptop text is only sharp in its native resolution, and in your case the possibility is that your native resolution is 1600x1200 (If you can post the exact model or a link with your machine configuration, I can confirm what the native resolution is).
However you can make the icons and text larger, the best way is to and change the font size in windows (display settings) from the normal to large or extra large. This makes all the fonts much larger and easy on the eye, and it also will keep the text large as you are still running it in native solution mode.
Dec 09, 2007 | Computers & Internet
WiFi not recognized on Compaq laptop
this can happen sometimes, just go to network connections in control panel, right click on the wireless icon and click dissable (or press the rellevant button on your notebook) Restart pc and then right click on the icon again and select enable. There should be an icon in your taskbar, right click and select view network connections, and then see if your router is listed and click connect.
Sep 25, 2007 | NetGear WGU624 Router
Open Questions:
Acer Virus Removal ' Remove Acer Virus - DataAlign ' Call +1888784-9316 Since those early days of laptop production, Acer has grown to offer devices in just about every category. From netbooks to high-powered gaming units, there is likely to be a laptop computer made by Acer to fit the needs of just about any consumer. While many consumers consider products made by companies like Dell or Sony to be at the higher end of the laptop spectrum, savvy consumers are beginning to realize that although they are priced competitively, support acer laptops do not lag behind in quality at all. As the company continues to grow, there is speculation that they may also enter the tablet and smartphone markets as well. For the all-round support of Acer customers, we have trained a team of highly skilled, certified engineers with excellent knowledge for all issues particularly faced with Acer products. Technical support is provided 24/7 every day on our toll free helpline called acer computer support number. Issues faced by Acer customers: • Black laptop screen issues • Stretched images on laptop screen issues • Laptop heating up followed by forced shut down • Window update issues • Crashing issues All these issues can be resolved by our round the clock available highly experienced tech support team with dedication and professional attitude, contact acer support. Our services: Get all your queries, issues and complaints sorted out most efficiently and in the least time with most effective results that stay for the longest duration by contacting our Acer Support team members by calling on acer customer service. Contact our technical support team for any assistance regarding issues concerning Acer Products by acer product support phone number. Get all your troubles sorted out in a matter of few minutes by most courteous and experienced technicians.
Jun 20, 2018 | Acer Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
