Question about Copystar CS-1500 Copier
I'm getting c-6 400 code
I have a copystar 1500  It keep giving me c-6 400 code  What dose it mean? How do I fix it?
  • 318 Answers
This is a fixing error.But it can be caused by a power dip aswell.
Try to reset it,if the error presist then there is a problem on the fixing.
To reset-Switch the machine off,open the front cover,switch the machine on again.If it shows "open cover",press the system menu counter button.press the arrow up ones to display system settings,hold the start and # button in and press "ok"or"set"
go down with the arrows untill maintenance mode is display,press ok,then enter the number 163 and press ok.
set it for exeuteand press ok.
Then the error will be cleared.
Posted on Jan 22, 2009
Error Code E07
  • Open the drawer the printer is currently pulling from when the error message "E07" appears on the display. Verify that the paper in the drawer is the correct size and close the drawer firmly!
  • Oct 23, 2014 | Copystar CS-1500 Copier
    I have an error code C-7 980 on a Copystar 1500. What does that mean?
    This is a drum related problem. The waste toner is full. Remove the drum unit, remove toner cartridge and unscrew 2 chrome screws on on the left side of the unit. empty the waste and screw back the screws. replace toner and put back in the machine
    Oct 26, 2010 | Copystar CS-1500 Copier
    I HAVE A CODE C-6 ON COPIER AFTER POWER WENT OUT
    have a copystar#GS-1500 and after power went out, have flashing error code C-6 and 400. Worked perfect just prior. please help!
    Oct 13, 2010 | Copystar CS-1500 Copier
    C-7 990 error code just keeps showing up on copystar 1500 copier
    Shake the process unit from side to side
    and turn the power switch off and then on.
    If the problem cannot be solved, replace
    the process unit.
    After replacing the process unit, turn the
    power switch off and then on. If the problem
    cannot be solved, replace the waste
    toner sensor or the engine board
    Aug 19, 2009 | Copystar CS-1500 Copier
    Error c-6 keeps appearing
    codes that start with c6 are caused by a problem in the heater. blown thermal fuse,
    or bad heater lamp. you can access from the rear of the machine
    Jul 15, 2009 | Copystar CS-1500 Copier
    ERROR CODE "C7980". I HAVE ALREADY EMPTIED THE TONER WASTE. WHAT DOES IT MEAN AND HOW DO I FIX IT?
    Hello sir; The code you display which means waste toner bottle full, just dump it .
    May 12, 2009 | Copystar CS-1820 Copier
    Copystar CS-1500 "OP" flashing in display
    Hello, 'OP' means that the front or upper front cover is open --- close the cover securely. If the message is 'OP1" then the left cover of the document processor is open, close that securely.
    Jan 05, 2009 | Copystar CS-1500 Copier
    Copystar cs-1500 fuser temperature problems
    I had the same problem. And after spending as much time as you have. I replaced the fuser assembly. Problem solved.
    It's not that expensive and how much is your time worth?
    The hot line suggested I replace the main board and the intermitant board between the two. .......I still have them.
    Oct 31, 2007 | Copystar CS-1500 Copier
    Copystar CS-1500 Copier Logo
    161 people viewed this question
    Top Copystar Office Equipment & Supplies Experts
    Kyocera HP Expert
    Adorjani Laszlo
    Oloyede Monsuru
    Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
