Question about Kyocera FS4020DN (A4) Workgroup Mono Laser (Duplex+Networked) 128MB 1200dpi 45ppm 600 Sheet Printer
Kyocera fs 4020 problem is: call service 2200
leroyal
  • 2120 Answers
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Posted on Jan 23, 2009
  • 66 Answers
SOURCE: CALL SERVICE 7410:0002988
the 7410 error may be a drum unit that is not pushed in properly or it could be the following
defective drum EEPROM drum needs to be replaced or
defective engine PCB
the above suggestions assume that it is an original Kyocera drum
hope it helps
Posted on Mar 21, 2009
  • 66 Answers
SOURCE: Kyocera FS-4000DN, CALL SERVICE 6030:0159631
this error indicates a problem with the fuser unit.
if you are an end user, you will have to check warranty status with you nearest service agent and have the fuser replaced free or get a quotation if it is out of warranty
SOURCE: CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
Posted on May 25, 2009
  • 46 Answers
SOURCE: showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
Posted on Jun 12, 2009
Kyocera call service 4200:040797
Means that the laser unit is off. You should check the cables for the laser unit
Jun 27, 2014 | Kyocera Mita FS-3820N Laser Printer
Kyocera FS-3920DN call service 2000:0011742
The call service 2000 is about the main motor. Pull the Developer Unit and then the drum unit out of the printer and check if the gears on both units are moving freely. Then turn the printer on without the 2 units and see if the motor is functioning. If your the motor moving then the message displays on printer will be 7410 (because you have the drum unit outside). There is a possibility that the transfer roller is damaged.
Mar 26, 2014 | Kyocera Fs-3920dn Laser Printer
The display on the Kyocera FS-4020 Printer says "No Multi Copies, Press Go" what causes this and how to fix it? thanks
Go to menu.
scroll down to device common
scroll right
scroll down to ram disk
if it shows off:
press ok button now question mark blinking
scroll down to on
press ok button
press menu button
Oct 08, 2013 | Kyocera FS4020DN (A4) Workgroup Mono Laser...
Kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Feb 02, 2011 | Kyocera FS-1016 Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
Kyocera FS-3900DN Ecosys Call Service 2200:0100998 Help please our printer has stopped working
The Call Service 2200 is a drum motor error. The motor or gears might need to be replaced. First remove and re-seat both the developer and the drum unit. The developer is directly under the toner cartridge - lift it up then out first, then open left side door remove the waste bin and press the button on the drum unit just above the waste bin pull the unit out (carefull not to touch the drum surface). Re-seat both units. If this does not work call in a Kyocera Tech.
May 07, 2010 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
Kyocera fs-2000d printer
A KYOCERA-MITA technician has to upgrade the firmware.
Jan 31, 2009 | Kyocera FS-2000D Laser Printer
Kyocera fs-1920 (call service 6400:0040085) help!
the printer will require a need new fuser unit or a new power supply.
let me know if you need more help
Oct 24, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS4020DN (A4) Workgroup Mono Laser (Duplex+Networked) 128MB 1200dpi 45ppm 600 Sheet Printer Logo
107 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
