Question about Kitchen Appliances - Others
Should you grease bearing on rival meat slicer
Grease bearings
Levyathos
  • 60 Answers
SOURCE: Grease wheel bearings
Hi... You remove them with a 20-24mm wrench. Wash them in solvent in order to get rid of the old grease, and repack them with high quality bearing grease that you can obtain from a regular part store. Pack as much grease as possible in them, then put back. You should be good for another 50,000 miles.
Posted on Aug 21, 2008
SOURCE: Globe commercial Meat slicer
Hi, I have working on meat slicer my whole life and can help you.
What normally happens is this. The bearings in the knife hub (this is the unit that the knife attaches to and spins) is starting to fail.
The gear on the knife hub is made out of a fiberous material and the worm gear on the motor is made out of metal, so when the bearings start to fail and cause resitance in the hub, the metal motor gear starts to eat the fiber gear on the hub and eventually wears a big chuck out of it. Then the motor spins free and doesn't make contact with the hub gear.
How you can check if this is the problem is this. You need to keep the power switch on machine in the off position and turn the blade a 1/4 of a revolution. Then turn the machine on, what should happen is that the blade will spin some and stop again.
The proper fix for the machine would be to rebuilt the knife bearing unit and replace the hub gear, motor gear and hardware.
In regards to the Chefmate. This is a design flaw of Globe and I told them about this when the machine first came out! The know is on a steel shaft that goes thru the aluminum body. The steel shaft starts to corode and also rust, then it freeze in the frame. What has to be done is this. This assembly needs to taken about sanded, lubed and put back together. The best way to permently fix this is have a machine shop machine the frame out and install a Oilite Bushing, these are impregnated with oil and it will never lock up again.
Where are you located? Let me know if I can answer any other questions for you.
If you have any other questions, you can call me on my cell 201-274-6274 or e-mail me at njrealestate@earthlink.net. Thank you
Best regards,
Scott
Posted on Dec 27, 2008
SOURCE: model 1101E Rival Food Slicer - grinds to a holt.
Im looking for the nut or bolt that holds the blade
Posted on Feb 23, 2009
  • 580 Answers
SOURCE: Where can I get a user manual for a Rival electric
Here is a link for manual for all Rival Appliances online and downloadable http://www.rivalproducts.com/help.aspx?helpNav=5
Posted on Aug 07, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: I have a Gelatao Magnum Plus that makes a horrible sqeaking noise
Maybe blade assembly it's loose, or bearing are dry, if you can take apart, use grease on the shaft and bearings. or replace motor.
Posted on Dec 23, 2009
Need the blade retainer screw for the Rival model 1030-6 meat slicer
If the need is for a Rival 1030Vx series slicer, contact lallin@juno.com for the threaded shaft and other parts, some new, some recycled. Available as of 8/17/17, several recycled threaded shafts in stock.
Jun 01, 2017 | Rival Kitchen Appliances - Others
The blade on my meat slicer is making a horrible noise and the blade stops when I try to slice any meat
Sounds like the shaft bearing has gone bad. If you can access or dismantle the blade shaft from the motor housing, (NOTE: unit must be unplugged first, ie NOT connected to any power supply) you can try to lubricate the shaft/bearing with a silicone grease. Odds are this will not solve your problem for long.
If it is an expensive unit, and you do not want to discard your investment, try finding a kitchen appliance repair centre for a more permanent solution.
Jan 24, 2017 | The Kitchen Appliances - Others
Bolt and washer for rival meat slicer mod 1101e/3
Meat Slicer Parts ' eBay
www.ebay.com/bhp/meat-slicer-parts
  1. Cached
  2. Similar
Meat Slicer RIVAL 1101E/4 Motor Plastic Washer Replacement Part Vintage ... Rival Food Slicer Meat Motor Holder SCREW 1101E-5 Accessory Spare Part.
Rival Meat Slicer ' eBay
www.ebay.com/bhp/rival-meat-slicer
  1. Cached
  2. Similar
Vintage Rival Electr-O-Matic Deli Meat Food Slicer 1101E-2. $45.00; Buy .... Meat Slicer RIVAL 1101E/4 Motor Plastic Washer Replacement Part Vintage. $7.99.
Food Prep & Choppers - Rival Products
www.rivalproducts.com/...manuals/food.../food-prep-and-choppers-manual.html
  1. Cached
  2. Similar
HM-743 - Rival® Hand Mixer Instruction Manual · 1042-WN - Rival® Folding Food Slicer Manual · CN-742 - Rival® Electric Can Opener Instruction Manual ... rival meat slicer mod 1101e 3 Google Search
Dec 23, 2016 | Rival Food Processors
I have a very old Globe slicer. Black oil or grease is appearing across the front plate as I slice.
it is most likely an oil seal on the shaft behind the slicer blade
if it is then you will have to pull the seal and take it to a bearing and seal shop and have it matched up
remember that any lubrication used has to be in conformance with food production standards ( not car oil or grease)
Nov 02, 2015 | Kitchen Appliances - Others
Rival Meat Slicer Model 1037 Pin for blade
i too need a pin for this modle. has anyone solved this problem for that person?
Nov 21, 2009 | Kitchen Appliances - Others
Ineed the replaement bearing numbe for Abamaster meat grinder 1 hp 110v Model #FGS12. Thanks, Peter.
If it is a ball bearing, there will be industry standard numbers on the old one. If you take it to a bearing supplier, they can also measure and match to a replacement.
Find a local bearing supply house, or if you can find the number on the old bearing, buy one online.
Aug 10, 2009 | Northern Industrial Tools Electric Meat...
I need to know where to get a meat slicer tray?
I also bought one at a yard sale, complete and in the box. It did not have a meat tray with it, nor a picture of one on the box, nor any mention of one in the instructions. I just use a plate, and it works fine. Sorry.
Best regards, --W/D--
Aug 08, 2009 | Rival Food Processors
Globe Meat Slicer Model # 500 motor runs blade not turning
Fiber gear on blade hub stripped. deep socket required to remove hub. DON'T CUT YOURSELF!! remove motor, used food safe solvent to clean grease out of housing. Fiber gear held on with snap ring. Replace gear, repack housing, put hub and motor back and start slicing. Routinely check to make sure gear is lubed.
Oct 30, 2008 | Berkel 827E Gravity Feed Deli Meat Slicer
Kitchen Appliances - Others Logo
48 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
