Samsung HL-S5679W No video No sound
My samsung went out about a week ago. It has no audio or sound. The LED light on the front will blink in no specific order and the tv clicks on and off a few times and then stays off. All three fans work. I get all correct voltages on BP41-00268B card connectors CN100 and CN 300. I get the 115ac to card bp96-01495A.
  • 6 more comments
  • mark pasley Jan 24, 2009
    Which board is the vertical drive
  • mark pasley Jan 28, 2009
    which board is the vertical drive
  • mark pasley Jan 30, 2009
    The led blinks 19 times clicks off then on then blinks18 times clicks on then off then blinks 17 times then it stays off and all three lights continue to flash
    I think the power supplies are good as far as the voltages that i am reading i dont have manual or schematic.
    how do i look at all solutions at once it doesnt let me look at them unless i repost the problem. I didnt think this tv had a lamp or ballast cause it is led.
    do you know which transistor is the horizontal output transistor and what board it is on
  • mark pasley Feb 03, 2009
    I can take internal measurments just need to know what measurments to take
  • mark pasley Mar 10, 2009
    I had a tv repairman come out and he said the led's were bad so I replaced them and it still didnt work. Then the company said they had replace the whole led engine, so they came out and did that still didn't work. So I just troubleshot it myself. The input power was good to main power supply board but the output to the led driver power board was bad so i inspected the card and found some bad caps. I read about this in some other posts and I changed 2 caps out earlier but I missed two others that went bad. I replaced them with the same caps that were in there but i hear they need to be higher voltage. Anyone know a good cap site.
    Genius:
  • 2,920 Answers
You need to just take it in and have it repaired by somoene that knows what they are doing before you spend more money on it than its worth
Posted on Feb 05, 2009
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason for this problem may have two
possibilities,one is the problem with the
power supply and the other problem may
be due to the board inside.These are the two
problems which could have caused ur fault.
thank u..
Posted on Feb 03, 2009
  • Hariharanath V Feb 09, 2009
    hi..the problem is there in your circuit board.
    check it out..
    thanks..
    Sergeant:
  • 250 Answers
No picture and sound, only a high pitch sound at switch on
Remove horizontal transistor and measure the resistance across any two pins. This value should be no less than 200ohms
Posted on Jan 30, 2009
  • 4,234 Answers
Sorry to say, but your set is a DLP set and has no Horizontal Output Transistor. The fault could be the power supply module. The best course of action is to have a detailed estimate done. Report the results here and we can walk you through the actual repair. The problem you describe is too generic for an exact solution without taking internal measurements.
Dan
    Sergeant:
  • 378 Answers
Horizontal output transistor (Q401) located on small board above the convergence module ,
  • 360 Answers
I would suspect the horizontal output transistor, it is common to both picture and soound
    Brigadier General:
  • 5,158 Answers
Run your fingers over the capacitors on the circuit board... replace all the ones that are swelled up.
Robert
  • 505 Answers
All 3 leds flash = engine error (ie lamp, ballast, colorwheel, or dmd board)
if you listen you can diagnose with just your ear...
when you turn it on, all the fans start up
then you hear the color wheel spin up (high pitched).. you will hear it come up to speed
then the ballast will fire the lamp
if you hear a short 1 second buzz sound when the lamp should fire, you have a bad lamp (even if it looks good)
if you don't hear the buzz, but hear the colorwheel, suspect the ballast..
Let me know what you hear, we can fix together, I've fixed 100 tvs with this symptom.
  • thielectronick
    thielectronick Jan 31, 2009
    This tv has no horizontal output transtor or verticle output IC. It is a DLP apparently using LED drive instead of the typical lamp and ballast (sorry). On this model all 3 LEDs blinking says "LED may be defective." Check fuses f9001 and f9002 to see if they're open, infinite ohms. If blown you need a new LED driver pcb.
    The user manual is available here -
    http://www.retrevo.com/support/Samsung-H...
  • thielectronick
    Some of these tvs give incorrect errors because of power supply capacitors. Look for bulged tops that are not flat and or black stuff coming out of the bottom. You can read the value on the side of them and buy identical uF and V values, they're called electrolytic type.
  • 11,896 Answers
1.leave your tv UNPLUGGED overnight to do a hard reset.
2.hold power buttons for five seconds or the up and down volume buttons for 10 seconds to a light reset.
it is possible a part called the "flyback" has failed.
Posted on Jan 28, 2009
  • 2 more comments
  • Nate Stansfield
    Nate Stansfield Jan 28, 2009
    The problem you are describing seems to be a Ballast issue... Does your
    TV make a clicking noise when the power is pressed? A single "strong"
    click, or multipple "weak" clicks?
    If you would like to
    replace the ballst in Your HL-S or HL-T series TV (Which includes your
    HL-S5687W) you can purchase it at the link below for only $66 bux:
    http://www.discount-merchant.com/product...
    Step by step detailed installation guide is available here:
    http://guides.fixyourdlp.com/samsung/bp4...
    When
    the TV went out, did you hear a whining or screetching noise? The HL-S
    and HL-T series lamp based projection sets are notorious for failing of
    the colorwheel... Colorwheel can be found at the below link for
    $79.99...
    http://www.discount-merchant.com/Samsung... p/samsungcolor_wheel_bp96-01579a.htm
    Installation guide can be found here:
    http://guides.fixyourdlp.com/samsung/bp9...
    I hope this helps... i don't see anything else that might be wrong with your TV other than the Lamp, ColorWheel, or Ballast...
    Please let me know the results.. It's good information for all of us here!
  • Nate Stansfield
    Nate Stansfield Jan 30, 2009
    One of your capacitors on the board or power supply are probably going out. It would be hard to diagnose exact problem without the proper testing equipment and repair manual.
  • Nate Stansfield
    Nate Stansfield Mar 11, 2009
    electronix.com or partstore.com and shopjimmy.com
    are all great sites with good prices for tv caps!
  • Nate Stansfield
    acme-sales.net is another good one i've used in the past.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your description could indicate 2 possibilities:
  • power supply problem;
  • board/component problem.
Suggested approach would be to isolate/determine which is which. This could be accomplished by checking for the absence/presence of the voltages with and without any load/connection to the boards.
This of course would require opening the unit, perform voltage measurements,determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Jan 30, 2009
    Reference and compare voltage readings from the Service Manual.
  • Louie  Role
    Without a service manual or a schematic and comparison of voltage readings, diagnosis would be inconclusive. Though there are LED light indicators, the power supply could still be a suspect particularly the voltage doubler/tripler. Additionally, it could be failure of any of the filter capacitors, again "could be any".
    At this point, rather than looking for non-existent probable faulty component or "winging" the diagnosis, or haphazardly suspecting any, might you reconsider your options and forego DIY. Call for a qualified professional.
  • 19,396 Answers
re: "It has no audio or sound. The LED light on the front will blink in nospecific order and the tv clicks on and off a few times and then staysoff."
That means that the tv is on protection mode because an internal fault had been detected.
Common faults that can cause protection are a blown capacitor or other defective component, short, lose contact or a bad voltage from PSU or convergence board.
To find the fault , you need to test the boards inside, starting from power board, if you are not an expert electronic repairer, better calling a technician.
If you have experience in repairing electronics you start by visually inspecting power board for leaking capacitors and cold solder joints.
Then you grab the service manual and follow troubleshooting diagrams with your multimeter.
Once you find the fault you can buy parts here.
You can buy service manual here.
Or training manual, that is also a training repair manual here.
If you have not used a Service manual before, better using the training manual, that is more detailed and easier to understand.
Posted on Jan 22, 2009
  • Ginko
    Ginko Jan 30, 2009
    This TV does not have a ballast, in the best case has a board that you can improperly call ballast board, that is the board that provides power to to the lamp.
    If the TV is on protection, with led blinking, but not returning any specific code, then the problem can be virtually everywhere.
    Saying it is this , or it is that will be just guessing.
    What you do in this case is visually inspecting the circuit to find a bad solder joint, or a blown component at a glance.
    When that does not work you test PSU, Convergence board, read voltages to lamp, and check for similar common faults.
    If you still get no luck you order the service manual for this model and follow the troubleshooting diagrams to finish the job.
  • Ginko
    Ginko Feb 03, 2009
    As I told you you need to perform a series of tests, as 19 blinks is not a service code, but just an erratic behaviour.
    You start testing from power board, then test ballast board, if ballast board is fine you may need to replace the lamp.
    You also need to test the DMD board.
  • 716 Answers
Unplug It And Then Hold On/off For 30 Seconds Then Release And Plug It back In. When you go to power it on hold the on off button for 20 seconds or until the unit beeps. Once you've done that try to see if you get a special number of blinks.
    Genius:
  • 1,550 Answers
Look for a cold solder joint in the vertical drive, as well as in the area around the low voltage power supplies, also check the inductors in the vertical drive for a cold solder joint where windings attach to pins, as well as any transistors in the vertical drive section.
See if there is a short in that area too, there may be a fuse, or fusible resistor to the vertical drive and audio stages that is shared by the two.
Also check the power handling inductors for a possible cold solder joint where the windings connect to the pins that pass through the PC board.
2 Suggested Answers
  • 3 Answers
SOURCE: Samsung HL-S5679W No video No sound
Check the capacitors on the power supply first. If any have domed tops or signs of leakage, replace them. I had two go bad on mine. Call electronics parts supply stores first as these are not your average capacitors.
Posted on Aug 18, 2009
Samsung HL-S5679W won't start - LED light blinking
Replace Lamp,but CK to make sure Fans are running if OK then replace Lamp Mats Has them for 99.00
1-800-628-1118
May 11, 2010 | Samsung HL-S5679W 56" HDTV
Samsung HL-S5679W - Power-up issue
There can be a few causes. One of the LED Modules has gone bad, The LED Driver board has gone bad and or the Power Supply has gone bad. You will need to have a good tech look into it.
Apr 03, 2010 | Samsung Televison & Video
Samsung tv model# HL-S5679W all three lights on front panel blink, no pix or sound owner's manual says lamp may be defective this is a DLP-LED. No conventional single lamp
The "lamp" in this set, I think, is called the "DLP" in the parts listings. That part is number: 4719-001960 and can be purchased from tritronicsinc.com for $249.75 plus shipping. Use the guest account to access this info.
Hope this helps,
Dan
Feb 17, 2010 | Samsung DLP HL-P5663W 56" TV
Where can i find a bulb for this model HL-S5679W
This is a LED TV it does not use a bulb. If you have problems you may have to change the light engine which cost around $800.
Jan 31, 2010 | Samsung HL-S5679W 56" HDTV
I need to replace the bulb on my TV model # HL-S5679W. I can not locate the replacement number for the lamp. I have been unsuccessful with contacting Samsung and need help.
This model does not use a lamp----if the LED unit is bad you may want to just forget it---
Samsung part number for the entire optical engine:
BP96-01470BIt is marked as no longer available (2006 model) and had a suggested list of 495 exchange.
Google the above part number and you will find some places selling the engine---for much more than Samsung wanted.
SORRY TO GIVE YOU BAD NEWS---no replaceable lamp in this model----the LED light unit is part of the optical light engine.
SD TECH
Oct 28, 2009 | Samsung HL-S5679W 56" HDTV
HL-S5679W won't start three light blinking
There is no lamp on this TV.. Your issues sound like a bad DMD board or bad capcitors on the power board. Remove the power board and inspect it.
Jun 21, 2009 | Samsung HL-S5679W 56" HDTV
WILL NOT POWER ON, STANDBY, LED, TIMER LIGHTS ARE BLINKING.
Jun 01, 2009 | Samsung HL-S5679W 56" HDTV
all 3 leds on the front panel blinking = lamp error.
if the tv doesn't come on, it may not put sound to the speakers.
you need to focus on the error at hand.. does the tv come up and appear that it is running and not turning itself off (shutting down)?
if it runs and doesnt turn off, then the audio matters, otherwise focus on the other problems.. you won't have audio on certain inputs, etc, don't use that to troubleshoot unless your tv is running and not shutting down.
Jan 30, 2009 | Televison & Video
Jan 22, 2009 | Samsung HL-S5679W 56" HDTV
Televison & Video Logo
197 people viewed this question
Top Televison & Video Experts
Electro Med Services...
