Question about Panasonic PT LC55U Multimedia Projector
Panasonic pt lc55u dust filter
Need new filter
4 Suggested Answers
  • 19 Answers
SOURCE: cleaning the INSIDE of a rear projection tv - Panasonic PT-51G35
its better to see any experts near you,its risk your tv.
Posted on Oct 30, 2007
SOURCE: OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Posted on Nov 04, 2008
  • 28 Answers
SOURCE: my panasonic pt-44lcx65
The fix for the air filter problem also you are probably getting the on screen message clogged filter also. It can be repaired by relacing the light engine (VERY EXPENSIVE) or remove the light engine and clean the filter much less cost infact none if you know how.
To clean the filter you must remove light engine and you will see at the top a black housing with two screws that must be removed to remove light engine.
A service maual on how to remove light engine is very helpful wich can be ordered on the internet. Any way you want to remove 4 screws from the housing you will then see the filter and 4 more screws to remove in all four corners, remove the screws and then pry the rectangular filter out of the assembly. This may take some effert so be careful. Look at filter through light it will probably be dirty wash with water and blow it out with comprssed air look at it through to insure it is clean then reinstall .Reassemble and you should be good to go.
Posted on Feb 09, 2010
Temp light flashing
the filter will roll itself when the projector is operate.
the temp light flashing when the fans is fault,or there is much dust on the air filter
check them
Dec 17, 2013 | Panasonic Replacement Lamp For Pt-f200nt...
I need the service manual for the Panasonic PT-50LC14. Can u help. We have to change the Blue Filter and I cannot find my service manual. Thanks
It's $38.95 at Partstore at this link
http://www.partstore.com/Part/Matsushita/Panasonic/PT50LC14/Matsushita/Panasonic/SMPT50LC14/New.aspx
Sep 28, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic projector TV PT-43LC14 has a light yellow splotch on the left hand of the screen. Can this be fixed?
yes and no. it is a burn spot on the light filter on the blue lcd panel due to excessive dust and heat. panasonic does not sell individual parts of the optical engine, so you'll have to replace the entire engine. to avoid it happening again or getting worse, keep the projector cool and dust free. use canned air to blow it out.
Nov 30, 2009 | Panasonic PT-AX200 LCD Projector
My panasonic pt50lc14 says the air filter needs to be cleaned and the manual says only a technician can fix it, how do I fix it myself?
It means clean out all dust and dirt blocking Airway, yes you can do it yourself take small paint brush and remove debris.Clean off and around Lamp for starters, all Fans that may have dust and dirt on them.
Oct 04, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Air filter location for samsung dlp hl-s5086w
More or less make sure there is no dirt or dust Blocking Air way CK Fans and Lamp housing blow out all dust and dirt.
Sep 30, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Permanent blue hue down one side of screen PT ae700 panasonic replaced lamp made no differance tried compressed air no change please help
if the discoloration has a sharp pixelated edge, it may be the lcd panel. if the edge blends, it's the light filter (polarizer) that is burnt from excessive heat and dust. either one needs replacing.
Sep 09, 2009 | Panasonic PT-AE700U-EC HD Cinema Front...
Yellow tv screen
i have the same problem. I had to take the whole thing apart and found that the red filter has a burn pattern in it. I am still trying to find a red filter for it.
Feb 16, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Were is the air filter?
The air filter is in front of the tv pop off the front and it is in a screwed panel you can take it off but i vac it out and air dust it out and it works great u need to not smoke around the tv or burn candles around it hope it helps
Jan 07, 2009 | Panasonic PT-44LCX65 Television
Grennish/yellow spots pt-50lc14
I received a new blue polarizer unit from Panasonic. I installed it and it fixed my problem!!!
Duane
Apr 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT LC55U Multimedia Projector Logo
32 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
