Question about Thule Atlantis 1200
Can't open or lock Thule 200 polar with key
Key is in lock will not turn, will not come out, will not lock or open. Box is not on car or filled.
2 Suggested Answers
SOURCE: How to change locks?
Just replaced the locks on an Atlantis 200 which should be the same.
Pop off the 3 rubber caps around the lock and drill out the rivets.
Inside the box pull the plastic unit away from you (bending the aluminium strip slightly but this is fine) gaining access to 2 screws. Unscrew these (I used a small ratchet with a pozi bit rather than a screwdriver) and remove the plastic unit.
You'll have to take out the lock cartridge next. Theres various wedges in the plastic which you should try to hold open then a flat screwdriver near the cog should lever the whole thing out.
To get the barrel lock out of it's cartridge you'll have to push the tumblers in from the back with a very small screwdriver and gradually work it out. (the one I did had a snapped key so I'm assuming this part is easier if you are just changing locks for keyed alike purposes)
Fitting the new lock in to it's cartridge should be easy enough. When you reinsert the cartridge in to the housing make sure that the sliding bolt (that your key turns) is fully in the open position, otherwse your key won't do a thing.
Screw the housing back on and re-rivet the points you drilled.
Dan (Rothwell Trailers)
Posted on Sep 07, 2010
The key fob has stopped working have replaced the batteries and still not working
May need to be reprogrammed:
Here's how you do a new one might work on yours:
1. Remove key from ignition switch.
2. Close all doors.
3. Open drivers door
4. Insert key and turn to ON position and within 10 seconds turn key off and remove key.
5. Within 20 seconds Close and open drivers door 3 times.
6. Insert key and turn to ON position and within 10 seconds turn key off and remove key.
7. Locks should now lock and unlock automatically to confirm you have entered programming mode.
8. Press the UNLOCK button on remote and locks should cycle to confirm programming.
9. Repeat step 8 on each additional remote.
Sep 01, 2015 | Thule 2010 Suzuki SX4 - Sedan - Base Rack...
Can't open trunk on bentley arnage
Look in the glove box. You will see on the left hand side 3 switches On relates to the electronic boot switch. Make sure it's turned on.
Apr 13, 2013 | 1999 Bentley Arnage
The lock on our Thule roofbox has jammed with key in it, it has locked, but key not turned enough to remove it. We cannot open it, or lock it enough to remove the key. Any tips to try to free it up?
I know this is old but there doesn't seem to be much on the web about this common problem. If your roof box lock appears to be jammed, key stuck in, broken off etc here is my advice based on what happened to mine. Basically the issue is not the lock but the sliding locking bar inside the box, when you lock or unlock the lock you are just turning a small Lever inside the locking bar mechanism which slides the locking bar left or right to clamp or release the 3 hinge pins on the lid. The locking bar slider is aluminium, about 4 feet long and a lot for the little key to move, especially when dirty, clogged with sand etc. I'm my case both sides were seized solid - it was assumed that the locks themselves were seized solid these were forced until the keys snapped off. One bit I picked out with a paper clip, the side I had to drill the whole barrel out. Fortunately my lid was open so I was able to free the sliders inside - wd40, gently tapping the end of the slider back and forth until it was free. New lock barrel, sorted!
May 02, 2012 | Thule 668 Frontier ES Roof Box - LL Bean
Hinge Replacement, Thule Thule Atlantis 688T 2100 Cargo Cariier
Hi Erroll,
What I believe you're referring to is the 'locking hook' -- the piece attached to the lid that slides into the lock mounted on the bottom segment of the cargo box. While it acts like a hinge in respect of the closed side of the Thule, what the mfg refers to as the hinge (or also referred to as a strut) is the spring mechanism at the front and back used to hold the lid up.
You can acquire this locking hooks online - attached a link for your convenience.
Good luck.
THULE ATLANTIS 200 from Exeter Roofracks Roofboxes
Apr 28, 2012 | Office Equipment & Supplies
Lock is jammed
Spray some WD-40 into the keyhole in the lock and wait a few minutes for that to set in. Then try to turn it again. If that doesn't work, the lock cylinder may not be inserted completely. Use the removal specific "key" that comes with Thule locks to pull the lock cylinder out, then reinsert the cylinder completely before removing the removal "key".
Feb 17, 2012 | Thule 686 Atlantis 1600 Cartop Carriers
Key broken in box how do i remove locking device
same here ... bought new lock/key from Thule but no way to get old lock out
Mar 28, 2010 | Thule 686 Atlantis 1600 Cartop Carriers
Jan 28, 2010 | Thule Atlantis 1200
Can't open one side of our thule luggage rack for top of our van
The odds of someone here being able to solve your problem is near zero. Why not go to Thule.com or call using this info:
Thule com Phone Number
Apr 01, 2017 | Thule Atlantis 1200
Windows opening
its probably because you keep the key turned for too long while locking the car.
turn the key to lock it and turn back again quickly.
It freaked me out the first time it happened me but once you get used to it, its not a big deal
Jun 05, 2008 | 1997 Volkswagen Passat
Thule Atlantis 1200 Logo
59 people viewed this question
Top Thule Cycling Experts
Michial Gueffroy
tau1618
Are you a Thule Cycling Expert? Answer questions, earn points and help others
